SOURCE: Owners Manual for a 1995 Triumph Daytona 1200?
Google " service manuals triumph "
or go to www.repairmanuals.com
or try your local library. Often guys will donate manuals to the library.
You might find a free pdf service manual on this site, they have a ton of them.
http://www.carlsalter.com/motorcycle-manuals.asp
Please rate this solution. Thanks!
SOURCE: Triumph TT600 stalls during deceleration
under your air box on left side is kind of a round canister pretty small called stepper motor has 4 vacuum lines one from each carb annd 3/8 hose that runs up to air box usually 3/8 hose comes loose or falls off has to have good seal you can tell if its working look in from left side of bike through fairing when idling should see four vacuum lines pulsing if not check 3/8 hose and vacuum lines if all are intacked its probably the stepper motor they are two peice has teflon piston inside if bike ever went down oil goes int airbox down 3/8 hose into it and gumms it up run about $50
SOURCE: Hello.. 2oo8 triumph bike just shut down at the worst time
Need to check and measure the generator's stator for correct current supply and install new regulator/rectifier and battery.
SOURCE: engine oil transfer into coolant on a 1995 triumph thunderbird
You unfortunately have a bloown head fasket. Oil pressure is greater tha water pressure. R&R head gasket
