Question about Refrigerators
Knocking noise coming from Whirlpool Gold refrigerator
Knocking occurs ocassionally mine is not a gold but still whirlpool, and the knocking noise, whick started a week ago, is slowly increasing day by day, i have defrosted my freezer, cleaned the back and still it continues. any ideas?
  • 1 more comment
  • joclayton Dec 16, 2008
    Thankyou will have a look. fingeres crossed.
  • Anonymous Apr 10, 2009
    Same rock sounds - like a rock tumbler every time it turns on then usually goes away after about 20 seconds.  So, if it is the compressor, then what?  This fridge is almost new!  Rocky sounds started within weeks of purchase.  Any more hints?  This is a Whirlpool fridge with bottom freezer.
  • Sylvia Fullerton
    Sylvia Fullerton Feb 08, 2018
    Mine is doing the same only a few months old! Grr
I also have a new Whirlpool Gold fridge (bottom freezer with French doors) and it was making a knocking sound. The knocking sound would start when the fridge kicks in and starts running to cool, and would last for about a minute or less and be a slow knock.
I called Whirpool customer service since it is new and on warranty. They sent out a technician and he said the knocking is from gas/air built up in the copper tubing for the freezer because the copper tubing is too cold, and when the fridge first turns on it forces the air through, making the knocking sound.
His "fix" was to adjust the copper tubing so that it is closer to the heat of the motor/compressor and heat of another copper line so that the cooler line stays warm so the air/gas doesn't build up. His fix worked slightly, but the fridge is still knocking, just not as bad and not as long - it knocks fast for about 5 to 10 seconds instead of a minute.
Going to call customer service again soon and see where to go from here.
Posted on Jan 05, 2010
  • 2 more comments
  • Max404 Jun 23, 2011
    It was the ice maker. I do not have water hooked up so when the metal wire is down on the ice maker the refrig. thinks it needs to make ice. I think it is the ice maker motor or something. Anyway, when I popped it all the way up the noise went away for a long time. Sometimes I think I still hear it but not near as noisy as it was. When I pushed the wire all the way up it just latched into place.
  • jlwbradley1 Jun 23, 2011
    wow! ok. thanks. I have an ice maker too but I don't use it and the bar is up all the way -- off. Has been for 2 years. I hear this knocking sound when the compressor first kicks on and it is in the back near the middle/top. The Sears guy said it was the "new" type of coolant they use moving thru the coils. Seems so odd to me that I would hear it years later vs. when we first got it. I wanted to see what "richiepope" here had to say since it sounds very familiar to that post. The "muffled" rock tumbler sound is a good explanation of how I would equate the sound. It evens out after a minute or so but it is annoying.
    Richiepope...if you get this, did you find out what your problem was? Sounds very familiar to mine. Just wondered what Whirlpool had to say.
  • scadams1057 Sep 18, 2011
    Thanks Max404 for the posting. Pushed the wire all the way up on the ice maker of my Whirlpool Gold refrigerator and the knocking noise that was driving me crazy went away.
  • Refrigerators Master
  • 5,569 Answers
The compressor is normally mounted in sound-dampening rubber shock mounts and it sounds as if one or more of these have decayed on your fridge.
Accessing the compressor from the back, you might try (gently) to rock the compressor to see if you can duplicate the noise you are hearing.
Posted on Dec 15, 2008
  • 1 more comment
  • Max403 Dec 11, 2010
    I have same problem with my new (1 year old, just out of warranty) Whirlpool Gold. It is not the compressor. Lot of dust and dander under the frig, though. I removed the rear cover and the knocking noise appears to be higher up in the refrigerator. The compressor does not move and the small plastic fan that is visible runs smooth. I do not use the ice cube maker. Wondering if may have something to do with that.
    did you ever figure out what is causing your issue? mine sounds exactly like this on my kenmore (made by whirlpool) model. It sounds like a rock tumbler for a bit upon start up. I had sears come out. I recorded the sound. He said it was probably the refrigerant moving thru the coils depending on how much coolant the compressor was calling for it could make more sounds sometimes than others? Said it was normal. But I don't always remember hearing this! I don't use my ice make either.
  • Sylvia Fullerton
    I emailed Whirlpool Corp. and told them I loved my stainless steel refrigerator with the freezer on the bottom, but I think they left a technician in it that is driving me crazy wanting out. He or she knocks all day! The response was, don't worry about it if your refrigerator has a ice maker, it isn't tearing up! Over $1600.00 bucks and I listen to that all day!
Whirlpool gold French doors freezer in the bottom it's making a knocking or rattling sound like it's coming from the back panel in freezer open freezer it stops close it starts
SOUNDS LIKE YOUR FAN MOTOR IS EITHER LOOSE OR THE MOTOR IS ABOUT TO GO OUT(NOISE INSIDE COULD BE GEAR IN MOTOR GRINDING WHILE WORKING) it stops when you open the door which shuts off he fan motor to help prevent loos of refrigerated air.
Dec 04, 2016 | Whirlpool Refrigerators
Whirlpool Gold refrigerator water leaking
If it's flooding, it's NOT the drain pan. It's probably the water valve has gotten stuck in the open position. Hope this helps!
Aug 19, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool gold makes banging noise
If the refrigerator is working fine the banging noise you hear is the isulation inside the refrigeratior walls that exand and cotract with the change of temperatures. you don t have to worried about it.
Apr 10, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool Gold Refrigerator Buzzing sound when motor is on
some thing could be toching the fan at the back of the fridge or freeze fan making noise
Apr 02, 2009 | Refrigerators
Mine does it too. I know what it is because I repair them for a living. That is the sound of ice expanding as the defrost heater comes on to melt the frost on the evaporator. The next ime you hear it make a note of the time. Every 8 to 10 hours it will go into defrost mode. The ice box will also quit working for 21 minutes.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Dec 02, 2008 | Whirlpool GD5SHAX Side by Side...
Whirlpool side by side 2005...make to much noice
freon does not make a noise a compressor can if this noise is a knock then it is coming from the compressor and to solve it the compressor has to be changed
Apr 20, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool gold refridgerator light not working and is making funny noise
Had the identical symptoms with my Whirlpool Gold GS6SHEXNB00 side-by-side refrigerator. Had a technician come on site, indicated it was the "circuit board/ timer" (Whirlpool part # 1394052). Board is accessible from behind fridge (lower left side in a white plastic housing to left of compressor).
Swapped the board out (noticed a scorched circuit on the old circuit board). Lightbulbs now work, temperature readouts also good to go.
Mar 03, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Refrigerators Logo
8,833 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
