Question about E-Machines eMachines Desktop PC
KEYBOARD NOT RESPONDING
TRIED DIFFERENT KEYBOARDS.PROBLEM WITH PS/2 PURPLE CONNECTOR. IF I BUY NEW KEYBOARD WITH USB WILL IT WORK? OR ANY OTHER SOLUTION WITH CURRENT CONNECTOR?I CAN NOT LOG IN(I CAN NOT TYPE PASSWORD)
  • 41 Answers
Hi mumtazbayrak
Yes would work fine.
Regards
Go-Tech
Posted on Dec 15, 2008
    Problem Solver:
  • 13 Answers
Your computer should recognize a USB keyboard. Go for it.
Squido
How to conect keyboard on my loptop
If it is a PS/2 keyboard (the one with the purple connector), your laptop has to have a PS/2 port, if not, you need an PS/2 to USB connector. If the keyboard is USB, just hook it up to the USB port of the laptop, and you're set!
May 28, 2012 | Computers & Internet
How do I connect this keyboard to the computer
Keyboards connect several ways. Older systems use a PS/2 connector (round) that plugs into the purple/gray jack on the back of the computer. The mouse plugs into the green jack next to it.
If you have a USB keyboard, it plugs into any USB slot.
PS/2 connections must be made with the computer off. USB connections work any time. If one slot doesn't work, try another.
If the keyboard doesn't work, try another.
Nov 17, 2011 | Unitech K2724U-B Keyboard PC Desktop
Number,one,three,five seven and zero not working and back space aswell
Is your keyboard connected via USB (a flat rectangular connector), PS/2 (A round connector, often it is purple), or AT connector (a round connector that is roughly twice the size as the PS/2 port for your mouse)? More than likely, it's connected via USB. Especially if it was bought within the last five or six years. If it is a USB keyboard, try plugging it into a different USB port and see if that helps. If that doesn't help then most likely the cord on your keyboard is damaged (kind of like when you have a pair of headphones that will only sound on one ear unless you jiggle the wire). If it's not the USB port (or you have a PS/2 keyboard) I would recommend you buy a new one. You can get one for as cheap as $10.
USB Connector: crasher35_6.jpg
PS/2 Connector: crasher35_7.jpg
AT Connector: crasher35_8.jpg
May 29, 2011 | Computers & Internet
Keyboard not working
This is an older model so it is probably a ps/2 connector(purple) which you will have to turn off the computer 1st, plug it into the purple slot on the back and then turn on the pc.
Try the keyboard on another computer, if it works it is not the keyboard. If it doesn't then chunk it and get a new one.
You could get a ps/2 to USB and use that if the keyboard works. You shouldn't even have to buy one, as I am sure that someone you know has one of these converter plugs lying around.
If it DOES work and you have plugged it in accordingly to the original computer it is possible that the slot is faulty. Get a can of air and blow out the slot. If it still will not work then replace it with a USB keyboard and be done with it.
Nov 18, 2009 | Dell Dimension 8250 PC Desktop
My dell sk8110 keyboard has a round purple connector plug that fit my old computer. My new computer has only USB ports. How can I connect my keyboard to the new computer?
http://www.microcenter.com/search/search_results.phtml?keyword=usb+adapter+ps%2F2&category=
The round purple connector is refered to as "PS/2" type connector. You can find an adapter that converts PS/2 to USB connector. The above link was just to show what I was refering to. Hope this helps.
Aug 24, 2009 | Dell SK8110 Keyboard
Windows Vista, my keyboard stopped operating. I changed the old keyboard with a different keyboard that was working on another computer. Now that keyboard will not work on either computer. HP was NO h
What type of keyboard are you using? Is it a PS/2 or USB type of keyboard? If it's a PS/2 keyboard (with round purple connector), you may need to restart the computer after connecting it to the computer. But if it's a USB keyboard, there's no need to restart the computer because USB is just a Plug-n-Play device.
You need to isolate the problem. If you're using a USB keyboard, try connecting the keyboard into different USB port of thecomputer. Or try different computer to see if the keyboard is still functioning or not.
If you got the same problem after pertorming some test, it's better to consult the computer manufacturer for second opinion.
May 30, 2009 | HP Computers & Internet
Minimal information to go on. Since you didn't specify whether this is a laptop or desktop, I'll respond with the assumption that it's a desktop.
Power off computer.
Install new (known working) keyboard.
If that doesn't correct the problem, your issue is probably with the PS/2 or USB port your keyboard is plugged into.
If you are using a USB keyboard, first try moving it to a different USB port, then booting. If that doesn't help, try a PS/2 keyboard.
If you cannot get a known good (working/new) PS/2 keyboard to work in replacing a PS/2 keyboard, try a USB keyboard.
Jul 22, 2008 | Computers & Internet
Belkin KVM STandard 9 pin mouse/keyboard to USB COnversion
You need to have the keyboard connecter (purple) connected to your computer in order for the KVM switch to recognize it. The computer is providing some power through the keyboard connector and this is what the KVM switch is feeding on.
If you have a USB keyboard, you may want to change your KVM for a USB compatible one. If you just want to use the KVM to switch your monitor, you may plug the keyboard (purple) connector of the KVM to your computer's keyboard PS/2 port and also connect you USB keyboard directly to your computer. It should work.
Feb 08, 2008 | Belkin 2 Port KVM with Integrated Cables -...
E-Machines eMachines Desktop PC Logo
51 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
