Question about Sony STR-DE545 Receiver
Flashing message on my reciever
It says PROTECT and flashes How do I reset it or is there a more serious problem?
PROTECT, PROTECTOR or the letter P is flashing in the display of the A/V receiver. Solution
Flashing message on my reciever - sp.gif sp.gif Follow the steps below to troubleshoot if the word PROTECT or PROTECTOR is flashing on the A/V receivers display.
  1. Check the speaker wires and speakers for proper connections.
  2. Reduce the volume level. IMPORTANT: Ifthe receiver is played back at maximum volume level it may enter theprotect mode. Maximum volume listening will cause the receiver to runvery hot and may drain the output capacitors.
  3. Disable the surround sound option if both the A and B speakers are being used simultaneously.
  4. Ensure the top of the receiver has proper ventilation to keep it from overheating.
  5. If the message only occurs when using a DVD player, the sampling frequency may be set too high. IMPORTANT: Somereceivers provide compatibility with the higher sampling frequenciesthrough alternate connections. Consult the owners manual for specificinformation.
  6. Unplug the AC power cord for about 1 to 2 hours to reset the output transformers.
If the issue is still unresolved, service may be required. The Sony® eService Web site at http://eservice.sony.com/ can assist you in obtaining service from a Sony Service Center or locating a Sony Authorized Servicer.
Posted on Dec 16, 2008
Why is protect is flashing on display
There is a defect that is causing the light to come on. It could be a bad output transistor or some other defect that produces excessive heat. The cooling fan could be at fault too.
Aug 27, 2014 | Sony Str-d350z, Av Am/fm Reciever, Home...
My message light on the handset keeps flashing and I have deleted all messages and tried to reset it by taking the phone off the reciever and holding down the find button for 10 seconds, this causes the...
I may have already posted a solution for you from another location. But if not heres what I said.
If you also have voice messaging with your phone company, you might have voice messages stored with them. If so you need to access it with your password to clear them. To find out if you do have voice messaging, call your phone company and they can let you know and reset your password if so. The phone companys voice messaging system sends out a signal that would cause youe phone to think it still has a message waiting.
Nov 08, 2010 | Uniden Cordless Phone
My receiver is flashing "protect" how do I reset it
The protect message indicates that a problem was detected at the final stage of the amplifier and the unit has been shutdown to prevent further damage.
If the unit continues to flash protect even with the speaker wires disconnected, then the problem is internal to the unit and it will require repair not just a reset. The typical reason for this is shorted output transistors. Expect a repair cost of $25-$45 for parts if it continues with the protect message.
Please keep us posted.
Thanks,
Dan
Jun 13, 2010 | Teac AG-V8060 Receiver
Protect led flashing with hit of bass
Try a bigger amp. This one wants to be turned down. But seriously the protect can act like sort of a clipping device when the unit is trying to amplify out of a certain range. The transistors may be getting weak and need to be replaced. That said I would move this amp to the midrange or the highs and get a little bigger amp for you low low's. Hope that helps.
May 08, 2010 | Blaupunkt GTA 260 2 Channel Amplifier 400...
My reciever is blinkning 'protect' after being turned on. It starts up as normal but after the initial start it starts flashing 'protect' and after it starts flashing I can not do anything but turn it off....
It shows protect when it senses a problem with the output wires shorted or some internal fault. Try disconnecting all the speaker wires and power up again. If it still shows protect, then the fault is internal.
Mar 12, 2010 | Sony Audio Players & Recorders
As soon as i turn on my STR-SE391 reciver the protection is on
It is unlikely that the pushing of buttons caused the problem. The protect flashing means that a problem was detected and the system has shutdown to prevent further damage. The most common cause of this is a failure of the output transistors. Plan on a parts cost between $20-$40 for this repair.
Dan
Oct 31, 2009 | Sony Audio Players & Recorders
I have an old 5 in one reciever sony; i dont see any fuses and my problem is that after turning on it goes to the protect mode flashing prptect. i disconted the entire reciever so i know there are no...
No reset will help this. The problem is an internal short most likely in in one of the amp circuits. This is a relatively simple repair for a service shop. Expect a parts cost in the $40 range. Add in the local labor rate for the total repair cost.
Dan
Feb 01, 2009 | Sony STR-DE475 Receiver
My reciever is flashing the word PROTECT and will not function. It's a Sony STR-DE445
  2. Reduce the volume level. IMPORTANT: If the receiver is played back at maximum volume level it may enter the protect mode. Maximum volume listening will cause the receiver to run very hot and may drain the output capacitors.
  5. If the message only occurs when using a DVD player, the sampling frequency may be set too high. IMPORTANT: Some receivers provide compatibility with the higher sampling frequencies through alternate connections. Consult the owners manual for specific information.
Dec 15, 2008 | Sony STR-DE545 Receiver
My reciever does not work
Power Amp IC gone in your set, replace it.
Jul 30, 2008 | Sony STR-DE575 Receiver
Reciever message and interruption
i just encountered the same problem and when i discovered this posting, i thought i found the solution. when i saw that no one responded, i started poking around my equipment and discovered that one of my speaker wires was loose. i reconnected the wire and it seems to have fixed the problem. you have probably already figured out your problem, but i thought i would just share my solution anyway. Merry Christmas!
Jun 18, 2007 | Marantz SR-48 Mark II Receiver
Sony STR-DE545 Receiver Logo
649 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
