Question about Protron PLTV-32 Television
Volume adjust I can not adjust the volume on the tv anymore. I have to put it up on full in order to hear anything. If I adjust it by just 1 bar you can no longer hear anything. Thankfully the cable box got its own volume adjuster but no other input device does (DVD, VCR). Any suggestion would be appreciated. Thanks.
    Champion:
  • 217 Answers
Sounds like main board problem, probably a op amp chip on the analog circuit, geta receiver that is multi channel and hook all your other equipment to it, if the unit is still in warranty, call the store where you bought it and they will have it repaired
Posted on Apr 16, 2007
Low volume output signal.
Have you tried a different cable.
Jul 08, 2017 | Sony DVP-NS57P
I can hear them but they can't hear me
Using a microphone with computer
To use any microphone with your computer you will need to enable it in control panel. The following instructions are for Windows XP but are broadly similar for Vista and Win7
Click START, CONTROL PANEL, SOUNDS & AUDIO DEVICES
Click VOICE
In Sounds & Audio Devices Properties window locate SOUND PLAYBACK box. Click the VOLUME button. Make sure that there is not a check-mark in the MUTE box against microphone in the list of devices and that the volume slider is at the top of the scale.
Make sure the MUTE ALL box isn't checked before closing the window.
Now click the VOLUME button in the SOUND RECORDING BOX. Here SELECT microphone as an input source for recording (as opposed to un-checking mute in the playback controls).
NOTE if your microphone is not listed in the 2 sets of volume controls click OPTIONS, PROPERTIES on the tool-bar and place a check against microphone in the list entitled 'show the following volume controls' and then click OK. Same applies for Internal mic.
That should be it.
To adjust audio volume generally.
Under VOLUME tab adjust Device Volume as necessary. Also (under Loudpeaker Settings) click Speaker Volume and adjust slider to suit.
You might put a check mark in the box to show the volume control on the Task Bar so you can go straight to it to make adjustments in the future.
Feb 28, 2011 | Audio Players & Recorders
Can't hear anything, built-in speakers, volume won't change, the volume slider 'button' (in menu bar) is grey instead of blue, not on mute, and when I try to push F11 or F12 to change volume, it shows a...
If you are getting a big 'NO' symbol when using the volume keys to adjust it, it means your speakers are not being recognized as a valid output source.
Try resetting your SMC:
http://support.apple.com/kb/HT3964
If that doesn't work, it will likely need repair. Call 1-800-MY-APPLE if issue persists after resetting the SMC.
Aug 10, 2010 | Apple MacBook 13"White /2.0Ghz Intel Core2...
My new Acer Aspire one D 250 laptop has a very low volume output . All the volume controls are up including wave output but with no success
Right click on the speaker icon in the task bar, lower right hand corner of the screen.
Select "Adjust Audio Properties."
In the popup box, go down to "Speaker Volume." Click "Advanced"
In the new pop-up, make sure that "Laptop speakers" is selected. Click all the OKs you need to in order to establish that setting and clear out of "Adjust audio properties."
Now you SHOULD have much better sound from your speakers.
For some reason, my D250 keeps defaulting to "Stereo headset" which produces much lower volume sounds when a headset is not inserted. So low that you can't watch and hear a video through the speakers and understand what is being said. Once you switch to "laptop speakers" you'll be able to hear stuff. It won't be high volume, these things just don't put out high volume, but it will be reasonably audible, if this was the problem.
Nov 25, 2009 | Acer Computers & Internet
Problem with the volume
what about sound bar in the tv that shows how much is vol.
is it remain normal or go at full ..
check if it remains normal then its another problem
if it goes also full then it might be software problem
Aug 14, 2008 | RCA F25422 25" TV
Sharp Aquos LC-26D4OU HDTV volume adjustment problems
If you use a digital cable box, it could be that the volume on that isn't turned up all the way. I didn't even realize the box had volume controls until 2 years after I got it...makes a HUGE difference now
Jun 14, 2008 | Sharp LC-26D43U Television
"snow" screen, full volume, remotes don"t work
good day
due to the long time the buttons were not used, they tend to get stuck and this causes channels eighter to stay in one station or continou scanning. it could be resolved by spraying WD40 on the buttons and press it many times then dry it before operating the unit.
chris
Mar 25, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
I found that the problem was also with my HD box. I was able to turn the volume up on the box.
Mar 02, 2008 | Sharp Aquos LC-26GD4U 26 in. LCD HDTV
Protron PLTV-32 Television Logo
Top Protron Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
