Question about E-Machines eMachines Desktop PC
KEYBOARD IS NOT RESPONDING.TRIED DIFFERENT ONES, PROBLEM WITH CONNECTOR (NOT USB PS/2 PURPLE)i DO HAVE RXTRA USB PORTS IF I BUY NEW KEYBOARD WITH USB WILL IT WORK?
    Problem Solver:
  • 16 Answers
It should work prob just port
Posted on Dec 15, 2008
How to conect keyboard on my loptop
If it is a PS/2 keyboard (the one with the purple connector), your laptop has to have a PS/2 port, if not, you need an PS/2 to USB connector. If the keyboard is USB, just hook it up to the USB port of the laptop, and you're set!
May 28, 2012 | Computers & Internet
Number,one,three,five seven and zero not working and back space aswell
Is your keyboard connected via USB (a flat rectangular connector), PS/2 (A round connector, often it is purple), or AT connector (a round connector that is roughly twice the size as the PS/2 port for your mouse)? More than likely, it's connected via USB. Especially if it was bought within the last five or six years. If it is a USB keyboard, try plugging it into a different USB port and see if that helps. If that doesn't help then most likely the cord on your keyboard is damaged (kind of like when you have a pair of headphones that will only sound on one ear unless you jiggle the wire). If it's not the USB port (or you have a PS/2 keyboard) I would recommend you buy a new one. You can get one for as cheap as $10.
USB Connector: crasher35_6.jpg
PS/2 Connector: crasher35_7.jpg
AT Connector: crasher35_8.jpg
May 29, 2011 | Computers & Internet
Plz help me i want connect wire less keybroad and mouse thnksvjtawale2gmail.com
There are 4 possible ways in my awareness...
Method 1: Resynchronize your device with the receiver To resynchronize the mouse or the keyboard with the receiver, follow these steps. Note When you synchronize the mouse or the keyboard with the receiver, put the device near the receiver and put any other wireless keyboards and mouse at least 6 feet away.
  1. Press the button on the receiver, and then verify that the light on the receiver starts to blink.
    Note Some newer Microsoft devices are permanently bound to their receiver and cannot be reset. If your device does not have a button, skip to Method 2.
  2. If a dialog box appears on the screen in several seconds, follow the instructions that appear on the screen. Otherwise, go to the next step.
  3. Press and release the Connect Channel button on the bottom of the mouse or the keyboard.
  4. Check the green light on the receiver. A steady green light means the synchronization was successful. If the problem persists, try steps 1 through 4 again.
  5. For the Wireless Notebook mouse: This issue can occur if the micro-switch on the bottom of the mouse is not released. Use a pin or a pen to try to release the button if it is depressed.
The following example shows the buttons to push to synchronize a wireless hardware device:
Receiver Bottom of the mouse: The connect channel button Different kind of receiver Collapse this imageExpand this image 838398_receiver.jpg Collapse this imageExpand this image 838398_mouse_bottom.jpg Collapse this imageExpand this image 838398_portable_receiver.jpg Method 2: Try different portsTo determine whether the problem is related to the ports on the computer, use only the two cables that are included with the wireless desktop receiver, or the single cable that is included with a mouse. USB keyboard and USB mouseIf the USB cable is currently connected to a USB hub, disconnect the device from the hub, and then connect it to a USB port on the computer. If your device is already connected to a USB port on the computer, try to connect the device to a different USB port if one is available.
Note Only one USB connection to the computer is required, even if your device has two USB plugs. If the problem persists, disconnect other USB devices and connect only the USB plug from the receiver to a USB port on the computer. PS/2 devices Warning If you have to change a PS/2 connection, shut off the computer, make the changes, and then restart the computer. Do not plug a PS/2 device into the PS/2 port while the computer is running.If your devices are connected to PS/2 ports on the computer, verify that you have the following configurations:
  • Verify that the USB plug for your mouse is connected to the green USB-to-PS/2 adapter and that this adapter is plugged in the mouse PS/2 port on the computer. The mouse PS/2 port on the computer may also be green. If you are not sure which PS/2 port is the mouse PS/2 port, see the documentation that was included with the computer.
  • Verify that the USB plug for the keyboard is connected to the purple USB-to-PS/2 adapter and that this adapter is plugged in the keyboard PS/2 port on the computer. The keyboard PS/2 port on the computer may also be purple. If you are not sure which PS/2 port is the keyboard PS/2 port, see the documentation that was included with the computer.
If you have to change your configuration, shut down the computer, make the changes, and then restart the computer. If your mouse or keyboard has both USB and PS/2 connections, try using the other connection. PS/2 keyboard and USB mouseIf you are using a wireless mouse with a USB connector and a PS/2 keyboard, verify that the USB mouse is plugged in a USB port on the computer and that the purple keyboard PS/2 plug is connected to the purple PS/2 port on the computer. If you have to change the PS/2 connection, shut off the computer, make the changes, and then restart the computer. Method 3: Reinsert the batteries or install fresh batteriesBoth the wireless keyboard and the wireless mouse rely on AA alkaline batteries for power. Remove the batteries, and then insert them again. If the problem persists, install a fresh set of batteries in the device that you are having problems with. Method 4: Check for interferenceItems such as wireless routers, radios, cell phones, desktop fans, fluorescent lights, and large metal objects like computer cases and metal furniture may interfere with the signal of the keyboard. Try to keep such items away from the keyboard, and check the behavior of the keyboard.
Do not put the mouse or the receiver near any electrical devices, especially transmitters such as cordless or cellular telephones or other wireless mouse devices or receivers. A distance of at least 8 to 12 inches is recommended. Do not put the mouse or the receiver on metallic surfaces or objects, especially long metallic rails or cables. We recommend that you keep the mouse and the keyboard a minimum of 3 feet from metallic objects.
Nov 21, 2010 | Computers & Internet
My dell sk8110 keyboard has a round purple connector plug that fit my old computer. My new computer has only USB ports. How can I connect my keyboard to the new computer?
http://www.microcenter.com/search/search_results.phtml?keyword=usb+adapter+ps%2F2&category=
The round purple connector is refered to as "PS/2" type connector. You can find an adapter that converts PS/2 to USB connector. The above link was just to show what I was refering to. Hope this helps.
Aug 24, 2009 | Dell SK8110 Keyboard
I need to be able to use traditional mouse and keyboard ports on one computer and usb port on second computer can i convert the KVM-2 Corega swich to do this? This switch links my present two computers but...
When you say "traditional mouse and keyboard ports" i assume that you mean the green and purple PS/2 ports. If I am correct in my assumption then this is what you can do. You can buy PS/2 to USB converter for your mouse and keyboard. A simple google search should yield you plenty of shopping results. Just make sure that you buy PS/2 to USB converters, not USB to PS/2 converters or you'll probably get the wrong thing. Everything else should just be plug-n-play from there on out. Hope this helps.
Mar 14, 2009 | Belkin Computers & Internet
KEYBOARD NOT RESPONDING
Your computer should recognize a USB keyboard. Go for it.
Squido
Dec 15, 2008 | E-Machines eMachines Desktop PC
MS optical desktop 700
try one of the method below:
Method 1: Try different ports loadTOCNode(2, 'moreinformation'); Warning If you have to change a PS/2 connection, shut off the computer, make the changes, and then restart the computer. Do not plug a PS/2 device in the PS/2 port while the computer is running.
USB keyboard and USB mouse loadTOCNode(3, 'moreinformation'); If the USB cable is currently connected to a USB hub, disconnect the device from the hub, and then connect it to a USB port on the computer. If your device is already connected to a USB port on the computer, try to connect the device to a different USB port if one is available.
PS/2 devices loadTOCNode(3, 'moreinformation'); If your devices are connected to PS/2 ports on the computer, verify that you have the following configurations: • Verify that the USB plug for your mouse is connected to the green USB-to-PS/2 adapter and that this adapter is plugged in the mouse PS/2 port on the computer. The mouse PS/2 port on the computer may also be green. If you are not sure which PS/2 port is the mouse PS/2 port, see the documentation that came with the computer. • Verify that the USB plug for the keyboard is connected to the purple USB-to-PS/2 adapter and that this adapter is plugged in the keyboard PS/2 port on the computer. The keyboard PS/2 port on the computer may also be purple. If you are not sure which PS/2 port is the keyboard PS/2 port, see the documentation that came with the computer.If you have to change your configuration, shut off the computer, make the changes, and then restart the computer. If your mouse or keyboard has both USB and PS/2 connections, try using the other connection.
PS/2 keyboard and USB mouse loadTOCNode(3, 'moreinformation'); Verify that the USB mouse is plugged in a USB port on the computer and that the purple keyboard PS/2 plug is connected to the purple PS/2 port on the computer. If you have to change the PS/2 connection, shut off the computer, make the changes, and then restart the computer.
uparrow.gifBack to the top
Method 2: Install fresh batteries loadTOCNode(2, 'moreinformation'); Both the wireless keyboard and the wireless mouse rely on AA alkaline batteries for power. If the problem persists, install a fresh set of batteries in the device that you are experiencing problems with.
Method 3: Resynchronize your device to the receiver loadTOCNode(2, 'moreinformation'); To resynchronize the mouse or keyboard to the receiver, follow these steps.
Note When you synchronize the mouse or the keyboard with the receiver, put the device near the receiver and put other wireless keyboards and mouse more than six feet away. 1. Press the button on the receiver, and then verify that the light on the receiver starts to blink. 2. If a dialog box appears on the screen in several seconds, follow the instructions that appear on the screen.
Otherwise, go to the next step. 3. Press and release the Connect Channel button on the bottom of your mouse or keyboard. 4. Check the green light on the receiver. A steady green light means the synchronization was successful. If the problem persists, try steps 1 through 4 again.
Method 4: Install the latest software loadTOCNode(2, 'moreinformation'); If you are troubleshooting a wireless mouse, download and install the latest Microsoft IntelliPoint software. For more information about IntelliPoint software, visit the following Microsoft Web site:
http://www.microsoft.com/hardware/mouseandkeyboard/Download.mspx (http://www.microsoft.com/hardware/mouseandkeyboard/Download.mspx) If you are troubleshooting a wireless keyboard, download and install the latest Microsoft IntelliType software. For more information about IntelliType software, visit the following Microsoft Web site:
http://www.microsoft.com/hardware/mouseandkeyboard/Download.mspx (http://www.microsoft.com/hardware/mouseandkeyboard/Download.mspx) uparrow.gifBack to the top
Method 5: Clean the mouse lens loadTOCNode(2, 'moreinformation'); This problem may occur if you are using an optical or laser mouse and the lens on the mouse is dirty. To clean the lens of an optical or laser mouse, follow these steps: 1. Use a dry cloth to clean the bottom surface of the mouse. 2. Check to see whether the mouse functions correctly. 3. If you see dust on the bottom of the mouse, use a can of pressurized de-ionized air to blow away the dust on the lens. 4. Check to see whether the mouse functions correctly. 5. If the pressurized air canister is not available, blow dry air on the lenses by using your mouth one or two times. 6. Check to see whether the mouse functions correctly. 7. If these steps do not resolve the problem, use a cotton bud to clean the lens without scratching it.
Sep 18, 2008 | Microsoft Wireless Optical Desktop Comfort...
Keyboard not working
Minimal information to go on. Since you didn't specify whether this is a laptop or desktop, I'll respond with the assumption that it's a desktop.
Power off computer.
Install new (known working) keyboard.
If that doesn't correct the problem, your issue is probably with the PS/2 or USB port your keyboard is plugged into.
If you are using a USB keyboard, first try moving it to a different USB port, then booting. If that doesn't help, try a PS/2 keyboard.
If you cannot get a known good (working/new) PS/2 keyboard to work in replacing a PS/2 keyboard, try a USB keyboard.
Jul 22, 2008 | Computers & Internet
Wireless keyboard
wireless keyboards and in wireless mouse devices, use the following methods in the order that they appear in.
Mar 02, 2008 | Sakar 62150 Keyboard
Belkin KVM STandard 9 pin mouse/keyboard to USB COnversion
You need to have the keyboard connecter (purple) connected to your computer in order for the KVM switch to recognize it. The computer is providing some power through the keyboard connector and this is what the KVM switch is feeding on.
If you have a USB keyboard, you may want to change your KVM for a USB compatible one. If you just want to use the KVM to switch your monitor, you may plug the keyboard (purple) connector of the KVM to your computer's keyboard PS/2 port and also connect you USB keyboard directly to your computer. It should work.
Feb 08, 2008 | Belkin 2 Port KVM with Integrated Cables -...
E-Machines eMachines Desktop PC Logo
61 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
