Question about Pro RX65 Radar Detector
No audio Unit is 1 1/2 to 2 years old. Has worked flawlessly and last Friday the audio has quit. I have reset the volume control countless times and reset every switch/bullon. The visual signal is working fine, dimmer works fine, the display of radar is also working, just "no beep beep Ka band"
  • 3 more comments
  • rjhart65 Mar 03, 2009
    I have the same problem. Everything seems to work fine EXCEPT there is no sound or audio of any kind. Seemed to go silent all at once (overnight).
  • dmoberly237 Apr 06, 2009
    No audio, where do you get a speaker?
  • daleheller Apr 18, 2009
    same problem here too...
    Unit was calling for calibration periodically, then it lost all audio...
  • Anonymous Apr 19, 2009
    I had the same problem. What I did was plug in a set of headphones in the headphone jack and the external audio then started working. Kinda strange but it worked.
  • daleheller Apr 24, 2009
    Same problem - Update
    I called Bel yesterday and am returning my unit. It is a flat $59.95 rapair which includes recalibration and tuning. Hopefully, it includes the new speaker. This appears to be a growing problem from on this unit...
  • 134 Answers
Hi everyone,
Bel/Escort now uses a special and proprietary "high temp" speaker which resolves issues of speakers blowing due to high ambient temperatures or heat which builds up within the speaker when it is alerting for extended periods of time. If your RX65 is in warranty and you can make a photocopy of your sales receipt, then great! All you have to pay is shipping to Bel. Bell will replace the speaker with the new version, flash your RX65 with whatever the latest firmware is, and calibrate and test your RX65 too. So, all of this is peachy if your RX65 is under warranty.
If your RX65 is out-of-warranty or if it doesn't have a serial number or was bought from a non-authorized dealer, then the service charge as I recall is $80. Thats not bad since your RD will come back working like brand new.
A note about the speakers: They are made by PUI, but the speakers are proprietary to Bel/Escort. Thus you can not buy them from any source -- not even direct from PUI.
Posted on Apr 24, 2009
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
Volume / audio control knob
Hi, did you ever get this fixed, if so for how much and where. I have the same problem with my knob, it does not control the volume level but you can still access the other functions that require you to push the knob, like a button. My remote battery is dead so I have not being able to test it, it's just the knob no longer controls the volume.
Dec 01, 2011 | Audiovox MP6312I
Hi my surround sound system keeps resetting its volume to 30- quite annoying when your trying to watch something! It was working fine for three weeks then this. There are no crossing wires, all wires...
If rotary volume control, I would work the control (with unit off) back and forth at least a hundred times to thoroughly clean the wiper. If a push button unit I would chemically clean its contacts.
If unit still does it then the volume control chip has a poltergeist in it. If there is an audio output on unit see if the anomaly also appears there to help localize its location in circuit.
Sep 12, 2017 | Audio Players & Recorders
Refrigerator model 309YBT quit working on Friday
Good day,
You did not say if it was running or not.
If not running at all, then it may be the cold control, (thermostat) that has failed. You can remove it, jump the 2 wires going to it, and see if it runs and cools.
If so, you may be able to contact your local appliance parts house for a replacement.
However, if running and not cooling, then 2 options.
1. If under 5 years, sealed system should be under warrant. Call your selling dealer for details.'
2. If over 5 years, not price effective.
Nov 16, 2009 | Avanti 309YBT Compact Top Freezer...
Canon PowerShot A80 - no display through the lens
See this link. The symptoms indicate that your CCD (image sensor) failed. Canon will repair this at no charge, regardless of warranty status. Contact them as described at the link.
Nov 16, 2009 | Canon PowerShot A80 Digital Camera
Kenwood TS50 - Max volume gives very low audio while receiving
It sound like a bad reostat in the volume control. if its under warranty send unit back to kenwood and have them replace the volume control, and possible speaker involvement.
Jul 12, 2009 | Radio Communications
Volume issues
Change your connectivity cables... and try again
May 23, 2009 | Audio Players & Recorders
Sony receiver DA5ES. Unit start arc and shoot off.
Marko,
I own the same unit (since 2001) & have had no problems. I would get it looked at & see what the issue is & what it would cost to fix. Would it be worthwhile? Well you'd have to ask yourself how much $$ you'd be willing to spend on a replacement vs repairing this unit & based on how much you'd be willing to spend, would the specs on a replacement unit measure up. You'd have to ignore things like HDMI inputs to keep it apples to apples.
I've owned various Sony components for a long time. I only had to get one unit fixed one time (a CD player that my one year old decided to do a chin-up on :( ). The unit was 7 years old at the time and my son is now 12!!. the unit still functions flawlessly since being repaired. Sony builds their stuff to last, even after beiung abused.
Dec 11, 2008 | Sony STR-DA5ES 6.1 Channels Receiver
TI-84 PLUS
just reset your calculator 2nd + 7 1 2
Oct 30, 2007 | Texas Instruments TI-84 Plus Silver...
Pro RX65 Radar Detector Logo
762 people viewed this question
Top Beltronics Vehicle Parts & Accessories Experts
John Nolan
Steve
Jerry Greenberg
Jerry Greenberg
Are you a Beltronics Vehicle Part and Accessory Expert? Answer questions, earn points and help others
