Question about Kitchen Ranges
My DCS range continues to ignite even after the burner is lit? Any suggestions on how to rectify this situation? I appreciate your time. -Dan
  • 8,220 Answers
Each burner has a switch and all are wired into one big happy family. Every now and then a pot will boil over and liquid will get into one of these switches. Sometimes aftera day or 2 the switch will dry out and the problem will go away. To see which one is bad you would have to access them and disconnect one at a time till the ticking noise stops. Then replace that switch.
Posted on Dec 15, 2008
The ignition - clicking - continues after burner has lit - all 5 burners have this issued
Here is a tip that I wrote that will help figure out why the burner spark keepson clicking...
Gas Range Repair Burners Keep on Clicking
heatman101
Jul 31, 2011 | DCS 36 in. CTD365N / CTD365L Gas Cooktop
Ignitors still click even after burners are lit.
you have to adjust the knob after the burner lights to stop the clicking. there is no sensor to tell the oven when the burner is lit strictly manual
Aug 10, 2010 | DCS RDS-364GD-SS Dual Fuel Kitchen Range
Dcs 48" gas range igniter comes back when set on low/simmer
This is not a solution but something to think about for troubleshooting.
On the DCS there are two ports that feed gas to the burner.
One for high flame and one for simmer.
On the DCS if the flame is snuffed out on simmer it will automatically reignite.
So if the igniter will not shut off while on simmer, the sensor is bad and is trying to reignite the burner.
May 11, 2009 | DCS 24-24G-1 Gas Kitchen Range
OVEN WON'T STAY LITE MOST OF TIME & DOESN'T HEAT WELL:
Most problems with gas ranges have to do with the flame—either it isn't quite right or it's nonexistent. Many new gas ranges have "electronic ignition," a spark igniter that starts the flame as gas flows through the burners f, when you turn on a burner, it fails to spark but you hear sparking at other burners, the igniter or the burner switch probably needs replacement by an appliance repairperson. If your range has a pilot light, be sure the pilot light is lit.
have nice time..!! arte the solution!!
Apr 17, 2009 | DCS 24-24G-1 Gas Kitchen Range
DCS Range constant sparking at all burners even when lighting one
This happens to mine if there is anything on any of the burners, such as food residue or moisture. Check all the burners to see that nothing is touching the burner area where the gas jets are. Even a little water can make this happen.
Jan 02, 2009 | DCS RDS-364GD-SS Dual Fuel Kitchen Range
DCS Range Ignition problem
I agree with two of the reviews here. Every so often after a good cleaning, or most recently after some oil spilled over, I had a burner that wouldn't light. All of them clicked, but the one I wanted didn't light. So after reading the above posts, I unscrew the hex nut, removed the shimmer ring, and cleaned it, and mopped up a bunch of oil under where the ring sits. Put everything back together and lit it manually. After 30 secs of flame I shut it down and tried to light it automatically. It worked! Looks like, thanks to some folks here, that I saved myself an annoying phone call and possible repair bill!
Aug 18, 2008 | DCS 36 in. CTD365N / CTD365L Gas Cooktop
Igniter will not shut off on my DCS RGS-366 gas range
Replace the multipoint gas re-igniter, it is a blue unit behind the knobs. This unit detects the flame and stops the clicking. Call Fisher and Paykel (owners of DCS) at 1 888 936-7872, they sell parts for DCS. The old inferior unit is blue and has a whte label. The newer unit has a yellow label.
Jul 23, 2008 | DCS RGS-366 Professional Gas Kitchen Range
Ignitors continue to fire even after the burner is lit
The switch sounds like it is bad. It has ; off, lowest setting going up to highest, then light, that's what makes the spark or clicking, right. Is this the top burners and do they all do this? If the ignite module runs too long it could over heat and burn out. But if they are all doing this you have a problem with it or the relay anyway.
Dec 26, 2007 | DCS 24-24G-1 Gas Kitchen Range
Gas Burners Not Lit Completely
sounds like there isnt the right amount of gas coming out of the orifice. orifice could be partially plugged
Oct 25, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Kitchen Ranges Logo
73 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
