Question about Canon PIXMA MP160 All-In-One InkJet Printer
Ink dorops at the paper edge
When ever i print any thing dots of inks appear beside the printed design  i cant represent my collage like this i need to fix this as soon as possible i tried cleaning it through the mentanence of the printer tried doing every thing but stille the same result
  • miramar13 Dec 18, 2008
    nope i took the printer to a repare center they told me that the sponges that are in the printer are full of ink
    so when the cartlage is at rest it gets staind by the ink in the spong that falls onto the sheet while printing
    so they took it and said it 'll be washed
  • Anonymous Jan 30, 2009
    I have similar problem, but for some reason the color ink is dumping out. There was a puddle of ink in the printer. I totally cleaned it up and thought it was just that cartridge. Put a new on in and the same thing happened. I thought maybe I put it in wrong. Cleaned it up again and a third cartridge emptied. Maybe just a **** printer.
  • 100 Answers
Either decrease the printing resolution .make it lighter from its orignal print quality setting.from printer properties option.or replace the cartridges as this r leaky so this problem.
Posted on Dec 17, 2008
Image prints at the edge of the canvas
you should check the paper size loaded at the driver open devices and printers- choose HP DJ5500 driver - right click and open Printer properties-click the paper/sizes tab at the top-check that the paper size is set to ROLL- then set roll size ( 24"=A1--36"=A0---42"=A0/2A0)
now when you try to print make sure that the printing application ( EG paintshopPro) has the correct Page size (under document Properties)
and that your not strectching to fit or using the overprint commands within your printing application. the plotter should never be allowed to overprint as this model has no ay of clearing the excess ink that would be left on the platten
Dec 24, 2013 | HP Designjet 5500 (42 in.) InkJet Printer
Ink
is it the exact ink replacement or did you have a company refill it ?
Robert
Aug 29, 2008 | Canon PIXMA iP1600 Printer
Tip
How to make duplex copies with a Brother MFC-240C printer
The Brother MFC-240C is a well-performing multifunction color printer. There is a lot that it can do, but one limitation it has is the inability to make double-sided copies. If you need to make a duplex copy of something, you can do it manually by re-feeding the paper once you've copied the first side.
After the first side of the page has been printed, let the paper sit for a minute or so to make sure the ink has dried. Then, put it back into the paper tray on the top of the stack. Make sure the back side of the page (the side that has not been printed on yet) is facing down, and the lead edge of the page (the edge that was fed out of the printer first) is facing toward the inside of the printer, rather than toward you.
Once the paper is set, push the tray back in and print the document or image that you want to appear on the back of the page. If you are printing multiple pages, position the paper so that the page you want printed on first is on the top of the stack.
The MFC-240C was not designed for duplex printing, so you may run into some issues with it, especially when you are using very thick or very thin paper. With very thin paper, the ink may bleed through to the other side of the page. With very thick paper, you may have to let the paper sit for a longer time after the first side is printed, because the ink could take longer to set and dry.
on Jul 06, 2010 | Brother MFC 240C All-In-One InkJet Printer
Anything I print looks really faded.
Did you clean the print heads and/or re-calibrate the printer after installling the new ink. It is possible, however, to have gotten a faulty cartridge.
Hope this helps
Randy
Aug 31, 2012 | Canon PIXMA MP160 All-In-One InkJet...
Got the C5180 from a relative because it didn't work. I tried a new black ink tank, it doesn't print anything in black. Color print looks weak and washed out without black for shadow, and black...
The printed output is fuzzy, blurry, or grainy, or the edges of objects in the images are jagged. Solution Follow these steps until the issue is resolved. Step one: Check your paper
  • Many papers have printing and non-printing sides. Load the paper with the printing side down.
  • Use the correct paper type for the project. For everyday documents, plain paper works well. For documents with dense printing, such as high-contrast graphics or photographs, use HP Advanced paper for the best results.
  • If these steps do not help, try a different paper. Ink might not bleed as easily on heavier paper. Paper that does not accept ink well is also prone to bleeding and smearing. HP designs its inks and papers to work together.
Step two: Check the settings
  1. In the program being used for printing, click File , and then click Print . The Print window opens.
  2. Make sure the appropriate product is selected, and then click Preferences or Properties . The Preferences/Properties window opens.
  3. Click the Printing Shortcuts tab. Consider modifying some or all of the options in the Printing Shortcuts menu to increase print quality.
    • Print quality : If the quality of the printouts is not acceptable, try increasing the print quality. To print more quickly, try decreasing the print quality.
    • Paper type : If one of the options matches the paper type exactly, select it instead of Automatic .
    • Paper size : Make sure that this option matches the paper loaded in the product.
    To see additional options, click the Advanced tab, and then click Advanced Features . The Advanced Features window opens. Consider changing the following option: Ink volume : Adjust the amount of ink that prints on a page. For lighter images (less ink), drag the slider to the left. For darker images (more ink), drag the slider to the right. The lighter the ink volume, the more quickly the printout dries.
Step three: Check image resolution Make sure that the image file has enough resolution for the size of the printed picture. Although many photo applications can enlarge an image or part of an image to any size, eventually the individual pixels become visible and the whole image looks blurry. Here are some general guidelines for image file resolutions:
  • 94 pixels per cm (240 pixels per inch) for images to print on smaller format photo paper, such as 10 x 15 cm (4 x 6 inch)
  • 117 pixels per cm (300 pixels per inch) or higher for larger format photo papers
  • Lower resolutions might produce acceptable images when printed on rough-textured paper
Step four: Align the cartridges If the previous steps have not improved the appearance of the printout, align the cartridges. See the user guide for alignment instructions.
Jul 02, 2011 | Office Equipment & Supplies
My dcp165c printer print quality prints black & yellow colour. i clean print head through maintance 76 but problem cannot be solved
How is the printer printing black and yellow color? Is it a smudge?
When I print, the pages are smudged with ink. What should I do?
Description:
- If smudged stains appear at the top center of the printed page:
  • Make sure the paper is not too thick or curled.
    Also, verify that the appropriate paper is being used and that the paper type set in the machine matches the media used.
  • Make sure the paper is not curled when you print on the back side of the paper with the Print Odd Pages and Print Even Pages settings.
- If smudged stains appear at the right or left corner of the printed page:
- If smudged stains appear on the reverse side or at the bottom of the page:
NOTE: Illustrations shown below are from the representative product and may differ from your Brother machine.
  • Make sure the printer platen is not dirty with ink.
    How to clean the machine's printer platen
    1. Unplug the machine from the AC power outlet.
    2. Lift the scanner cover until it locks securely in the open position.
    3. Clean the machine's printer platen(1) and the area around it, wiping off any scattered ink with a soft, dry, lint-free cloth.
    4. Close the scanner cover.
  • Make sure you are using Genuine Brother Innobella™ Ink.
    > Brother Genuine Supplies information
  • Make sure you are using the paper support flap.
    To use the paper support flap, pull out the paper support (1) until it clicks and unfold the paper support flap(2).
Aug 03, 2010 | Brother Computers & Internet
Greenish tint to black type
This is a dot matrix printer. The way they work is there is a print head that has a heap of little needles with flat tops on them, and they push out at high speed against the ink ribbon, and the ink ribbon is pushed against the paper to make a dot. Then the pin is retracted, spring loaded.
Pretty amazing that it can work that fast, eh!
So the only thing that can influence the ink colour on your paper is the ribbon.
Are you using original Lexmark ribbons? If so, my recommendation would be to take a sample print to where you got the printer from and get them to demonstrate the print quality of one of these printers, then compare it with yours.
Dot Matrix printers will not produce print as black or as high a quality as a laser printer, for example.
Perhaps the ink ribbons you are using have a less than top quality ink in them, and there is a bit of "bleeding" going on - it can only be the ribbon.
Another thing you can experiment with to get the best print quality is the print head gap - there will (should) be an adjustment, and getting that right will make a difference to print quality.
Hope this helps you.
Apr 26, 2009 | Computers & Internet
Brother MFC 7820N Smudging Concern
  • Make sure the paper is not curled when you print on the back side of the paper with the Print Odd Pages and Print Even Pagessettings.
Sep 11, 2017 | Brother MFC-7820N All-In-One Laser Printer
Dell 922 printer alignment problem-
try this...
Aligning Ink Cartridges Your printer automatically aligns the ink cartridges when they are installed or replaced. To verify your ink cartridges are aligned, you can print an alignment page. After you close the printer unit, press the Menu button. The alignment page begins printing. During printing, the operator panel display reads Alignment Page Printing. When complete, the message reads Auto Alignment Complete. Your ink cartridges are now aligned for optimal print quality.
You may also need to align ink cartridges when characters are not properly formed or are not aligned at the left margin, or when vertical or straight lines appear wavy.
To align the ink cartridges:
  1. Load plain paper. For more information, see Loading Paper.
  2. Click Start® Programs or All Programs® Dell Printers® Dell Photo AIO Printer 922® Dell Printer Solution Center.
  3. Click the Maintenance tab
  4. Click Align to fix blurry edges.
  5. Click Print.
The ink cartridges align when the page prints.
If this helps you plz rate this fixya. Thank you kindly. If you need more help post it & I'll be glad to do what I can.
Feb 01, 2009 | Epson Printer
Canon PIXMA  MP160 All-In-One InkJet Printer Logo
Clive
Clive
old marine
old marine
