Question about LaCie Hard Disk 1TB Desktop with Hi-Speed USB2.0 USB 2.0 Hard Drive
Computer will not boot with Lacie Desktop Hard Disk connected.
Hi there, I write because I just bought a Lacie Desktop Hard Disk 1 TB USB.
I have tried to look into FAQ in LaCie's website and also googled, but I can't find my exact problem:
The hard disk works all well when the PCs are already turned on, but with two of my PCs, it is not possible to reboot either of the PCs with the LaCie desktop hard disk connected. (But on the other hand, I tested the LaCie hard disk my notebook and it works like a charm to reboot it with the Lacie hard disk connected, but since it's with my two other PCs that I am to use the external LaCie hard disk, and not on my notebook, it's no solution to me.)
What happens is simply that when I reboot, the picture remains on the first screen where one is asked whether to press del to enter setup or tab for BIOS. But if I try either of the options, nothing happens. I wanted to be able to enter the bios to see whether I could change the priorities, but since it wouldn't enter the bios with the Lacie connected, it seems to me an impossible task. Well, the "first" image just remains when trying to boot the PCs. But if I disconnect the LaCie and then try to reboot, both PCs boot perfectly well again. Both PCs are quite new and have what I think is called onboard motherboard (where the USB ports, audio inputs etc etc. are all on the motherboard and not on their own PCI slots like on older PCs). I have several older LaCie hard disks, and I haven't encountered any problems with these earlier models.
So I am curious about what the solution will be.
It is surely a big inconvenience if I will have to disconnect the USB cable from the Lacie hard disk for each time I am to restart the PCs, and wait till the PC is rebooted to connect the USB cable back to the LaCie hard disk again.
Thank you very much for trying to help me solve this problem.
Regards,
Alexander Solvang, Norway
  • 7 more comments
  • ttboy20 Dec 29, 2008
    It wont boot the computer. The screen just turns black when turning on the on-button on my laptop.
    When i disconnect it, it runs perfectly again.
  • mchafe2001 Dec 31, 2008
    Same issues with boot up. I installed it on XP and it crashed the computer. Computer recognizes drive in My Computer but won't get past bios screen when booting up and HD is attached via USB. When I disconnect the HD, the computer boots up fine.
  • jdtravellers Dec 31, 2008
    Same problem and sympton, but with my Lenovo 3000 N100 Laptop.
  • Anonymous Jan 04, 2009
    I have the same problem. Just got a lacie hard drive and can't boot my desktop pc when the drive is turned on. The system just hangs trying to boot up. If I turn the drive off, with the switch on the back of the drive, then it will boot up. After I boot up I can flick the switch to the on position and the hard drive works fine.
    JDI
  • iblip2001 Jan 09, 2009
    same problem here cant find a solution
  • andersmh Jan 29, 2009
    Same problem but with a 500GB HD. In my case it is a Dell Inspiron 530. I have tried all USB connectors on the back, front and the built in hub on the display.
  • Anonymous Jan 31, 2009
    yes same problem, boot screen then system hangs
  • Anonymous Feb 08, 2009
    I have the same problem!
    I wonder what is..
  • pirttis May 22, 2009
    I have the same problem, also using Dell 530. I contacted Dell and they blame lacio
    Problem Solver:
  • 9 Answers
Changing the boot order doesn't work. I've even disabled the third boot device option to eliminate the USB LaCie disk and the PC steadfastly refuses to boot with it turned on. This is a right PITA. It has to have something to do with the disc. I'm going to try re-formatting it to see if that works..
Posted on Mar 24, 2010
  • 39 Answers
You can enter the bios on bootup by pressing a special key to force your computer to go into BIOS mode. What key this is varies by computer, often it is F8, F10, sometines F11. Anyway, use the key for your computer, and change to boot modus to not first boot from USB.
Posted on Feb 09, 2009
My mac laptop suddenly won't recognize it
you may need to swap the usb port it's plugged in
Jun 11, 2012 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
LaCie Hard Disk USB 2.0 1 TB i lost the power
this unit is compatible with a few of LaCie power supplies, but it is generally sold with the one providing hte following:
DC Output: 12V (2A) 24W
Regards,
Jan 19, 2011 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
The lacie grand 1 tb usb hard drive will turn on but it's logo is not appearing on my desk top and I can't access any of my files from it. Any ideas?
An external storage-device has four major components:
* the USB cable
* the power-adapter
* the disk-drive inside the enclosure
* the USB-to-disk-drive adapter inside the enclosure.
One of these components has failed.
Try a different USB cable.
Try connecting to a different USB port on your computer.
Try connecting to a USB port on a different computer.
Take a "multi-meter" and measure both the voltage and amperage output from the AC adapter, and compare with the specifications on the label on the adapter.
Open the enclosure, and remove the disk-drive, and then connect it as a "slave" disk-drive in a desktop computer, to see if it works at all.
Purchase a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Get the part-number and serial-number from the label on your disk-drive, and access the manufacturer's web-site, and use "check warranty status", to see if they will replace the device, at minimal cost to you.
Nov 08, 2010 | LaCie Grand 1 TB USB 20 Hard Drive
Won't recognize drive
Have you checked the disk properties to see if the 400 GB of data is still showing. may be your data might be hidden foir some reason. can you give more details pls
May 05, 2010 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
Lacie 1 tb hard drive clicks and no recognition
Hi wes_unruh. Unfortunately that "click" , known as the click of death, can mean many things. It could be a head, System Area, scratched platters, etc. First, remove the hard drive from its casing. Then connect the hard drive internally to a computer. You might still get the click. Try a diferent angle and try many many times. Check the logic board for any signs of damage. Please DO NOT start swapping parts because there´s aligment, firmware issues and you can make things worse if you need to do Data Recovery. If you had important informacion, you need to take it to a data recovery company such as Ontrack or ADS, because they have the right equipment such as Deepstar, PCI3000 in order to fully retrieve your files. IT IS an expensive process. I hope this helps. Please do not forget to rate and provide positive feedback for our free support today. Thank you :D
May 02, 2010 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
My LaCie 1 TB shows that I only have 9.99 MB of space. Why?
You didn't run the EXE that comes on the drive.
I made the same mistake, but did a windows format before running it, so I lost the exe.
Sep 29, 2009 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
I have a lacie 1TB exteranl hard drive and i cant get it 2 read on my dvd player via usb port...any ideas
Dows your DVD player supports reading drives of 1 TB capacity?
Check if the drive works on a computer!
Aug 24, 2009 | LaCie Hard Disk 750GB with Hi-Speed USB2.0...
Lacie 1 TB Won't Load Up
Hello
OK, at the link below you will be directed to a tip i wrote on this exact error.
Click HERE.
Feel free to let me know if you have any further questions.
Kind regards
Andrea
Jun 05, 2009 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
Lacie hadr drive problem
Data recovery software.
Check this link:
http://www.software.com/view/8384/72/easeus-data-recovery-wizard-professional-4-x
Feb 06, 2009 | LaCie Big Disk External USB 2.0 1TB Hard...
LaCie Hard Disk 1TB Desktop with Hi-Speed USB2.0 USB 2.0 Hard Drive Logo
1,327 people viewed this question
Top LaCie Computers & Internet Experts
pankaj rautela
pankaj rautela
Marvin
Marvin
Alun Cox
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
