Distorted TV picture
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:''Table Normal''; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:''''; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:''Times New Roman''; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}I have an RCA TV, RCA Model F32672SB and I have a clearpicture on the bottom third with distortion on the rest. The sound is fine. Ithas been suggested that I have bad caps in the vertical circuit. If so, can someonetell me how I can fix it?
Thanks, Tom
4 Suggested Answers
SOURCE: Partial tv picutre
Thanks, the set is a RCA Model F32672SB
Tom
Posted on Oct 16, 2008
  • 89 Answers
SOURCE: distorted picture on my 32" Proscan TV...(about 15 years old)
The RCA GE sets have a problem with bad solder connections in the tuner unit which also causes numerous symptoms including poor regulation, no vertical deflection, low audio or dead set.
Pulling in from the sides is either poor regulation or a bad eeprom/solder join issue
Posted on Mar 13, 2009
johnnydiode
  • 647 Answers
SOURCE: picture distorted. Vertical bending in towards centre
This indicates the Pincusion circuit is not working. Bring in for a qoute.The problem is usually a capacitor (mylar) or pincusion drive transistor or associated circuitry- depending on model. Total Repair shop cost : between $100-$200 usually.
Posted on Oct 31, 2009
I have a RCA Scenium HDLP50W151YX1 that has distorted Color (Bad Picture)
I am parting out my tv it was playing good when I shut it off we got a wall hanger we don't need this tv let me know what part you need I'll sale them cheap 2705898074 call me if you want
Oct 02, 2012 | RCA HDLP50W151 50" Rear Projection HDTV
My rca tv has a distorted picture and a really high pitched buzzing sound
Problem is in High voltage circuit and likely either the high voltage transformer or a connection right under or around it.
Jun 16, 2012 | RCA D52W20 52" Rear Projection HDTV-Ready...
My rca toshiba 50 inch projection tv is showing a 3d color curve
Need the model number to help as I am not sure of you have a RCA or a Toshiba
Dec 19, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA 27R410T Television colors are distorted
If you`re talking about colored spots in the screen, then you may have a degauss problem. It was frequent for those sets to have bad solder joint on the degaussing coil connector or thermistor next to it.If you`re handy with a soldering iron these connections would be near the a.c line input. good luck and don`t forget to unplug
Nov 01, 2009 | RCA 27R410T 27" TV
52 inch RCA Home theater-Sound is distorted/scratchy
I unplugged the tv for 5 minutes. When I turned it back on, I had sound!
Aug 01, 2009 | RCA 32V420T 32" TV
Distorted picture on RCA LCD TV
it can be replaced with a t0220 stile case dioded 220k ohm go to nte look up and do a search on the rca part #moz-screenshot.jpg 259638 search the web for the part.
Jun 29, 2008 | RCA R52WM24 52" HDTV Projection Television
Partial tv picutre
By distortion do you mean that the top part is stretched? If so, you have bad caps in the vertical circuit. If you are comfortable working inside hte set and can solder, you can fix this yourself. Please post the model number and I can give you the details.
Dan
May 28, 2008 | Televison & Video
I have the same tv. Had repair man come to my home in late april. Said it is the power convergence board. $225 for parts and labor I was told. Bad thing is part was supposed to arrive mid-may,then mid-june and now mid-july. He say's part is on back order. I'm actually going to contact RCA soon to find out if this is true. This seems to be a common problem with this particular T.V
Mar 07, 2008 | RCA P52937 52" Rear Projection Television
TV Problem
The first thing is to check to see if the fuse is blown,if so replace with a 5 amp fuse,fuse is located near were the power cord connects to the board,make sure set is disconnected from power.
Feb 28, 2008 | RCA F32672SB 32" TV
Problems with TV
Our 37 inch Sanyo LCD HDTV has a problem with the picture distorted by being too wide. This has beenia problem for the duration since we bought the TV about three months ago. The PIX Shape button on he remote does not adjust this problem. We need help in solving the problem. Thank you.
fred_story@cpmcast.net
Oct 24, 2007 | LG LRSC26980 25.2 cu.ft. TV Refrigerator...
Televison & Video Logo
98 people viewed this question
Top Televison & Video Experts
