I cannot print from Microsoft Word. I can print from Microsoft Excel. I can print from E-mail. I have HP5780 printer.
  • Wimpie Hall
    Wimpie Hall May 11, 2010
    Hi juslind
    Have you tried the following?
    Go to control pannel. Open printers and faxes. Right click on printer icon. Select properties. Click on Print test page.
    Regards
    Go-Tech
    Master:
  • 461 Answers
Have you verified your printer selection is correct? Use File Print. Also try ALT+TAB to see if the print dialog is hidden behind the document - I've seen this happen with Word before.
Posted on Dec 15, 2008
Since upgrading to Windows 7, I can't print from Excel (Office 2003). When I try, a "Print to File" window pops up even though that check box is unchecked in the print window. I can print from Word and...
try to make the installed printers as a default printer and then try to print.
in case that does not work when you try to print from excel, click on the drop down for printer name and select the correct printer.
This should help you
Jul 12, 2010 | Microsoft Excel for PC
How do I delete all jobs from the printer. I have 57 and chose "select all", but it does not delete??
Try to delete the print jobs while the printer is turned ON. Also, if you are using Windows, deleting print jobs is easier when the print spooler is stopped and the printer is turned ON.
  1. Click Start => Settings => Control Panel
  2. In the Control Panel window, click to open the "Administrative Tools"
  3. Double click the icon "Services" to open it.
  4. Locate the "Printer Spooler" service, click on it to select, and click the STOP button at at top. You can right click on it and click on STOP in the context menu that appears.
  5. Now turn ON your printer. It should not print the stored jobs since the spooler is stopped.
  6. Then open your printer's folder (Start => Settings => Printers and Faxes)
  7. Select all print jobs. Then press the "Del" or Delete key in your keyboard and click on YES when prompted. Another option is to select all and then under the "Document" menu, click CANCEL.
Try your luck. I hope these help.
  1. Turn your printer ON.
Feb 11, 2010 | HP Officejet J5780 All-In-One InkJet...
I cant print on A3 paper through microsoft excel on hp1280
in excel sheet please change the page size to A3 and try to print ..... if you are using office 2007 go to page layout then go to size icon there change the page size to A3 and check .......... if you are facing the same problem please post your comment ............. while you giving print please select the document which one you want to print ..........
Dec 31, 2009 | HP DeskJet 1280 InkJet Printer
When i try to download certain files from my yahoo mail they never open they are usually followed by .xls
These are spreadsheet files from Microsoft Excel, a part of Microsoft Office.
If you don't have Microsoft Office installed, you can download (or obtain on a disc from a computer magazine) a free alternative called Open Office.
If you just want to view the files or print them, you can search for "Microsoft Excel Viewer", which is free.
Nov 29, 2009 | Office Equipment & Supplies
I have several address stored in Excel. Now I
You don't need to print labels in Excel. You can use the mail merge feature in Word to do so. Use the Excel file as the data.
Nov 06, 2009 | Microsoft Excel for PC
Printing is not happening with Outlook 2003
when you give print command from outlook mail just see which printer you selecting if have more then one printer remove it and set the default printer .when you giving print command choose the paper type also correctly.
Sep 15, 2009 | Microsoft Office Outlook 2003 for PC
How do you print envelopes?
More information is required so I will only assume you are using Excel as a database. Excel is a spread sheet program used by accountants or for mathematical formulas and ledgers. Access is the Database program, however, Excel has functions which is faster to sort and work with address, phone number, zip codes. I will confess, I use Excel as Database because it is quick and easy. I do not know what version of Excel you are using so I will describe it from Office 2007. From Excel make sure you have headers above each column i.e. First Name in Cell A1 Last Name in Cell B1 Address in Cell C1 ect.
Make sure your data is correct and case sensitive as you would like it. If you want zip+4 select the Colum and right click to format the cells using special and select Zip or Zip+4.
It is easiest to use Microsoft Word for the next step rather than format the cells, add page breaks, and customize the print size.
Save your document as an Excel document where you can find it to import it into Word.
Open word and select Mailings then Start Mail Merge and Step by Step Mail Merge.
Select Envelope and next. Select envelope options to change envelope size, font and print options.
Click on Next Select recipients.
Click on browse under select an existing list.
Select the Excel file with your address information.
From the Select Table check the First row of data contains column headers.
Click on the OK buton.
Arrange your envelope then Preview it and your good to go.
If you have an older version of word selects Tools and click on Mail Merge.
Select Get Data.
Pull down Excel for document type.
Select entire Spread Sheet.
Layout your document and complete the merge.
On old versions of word it may not recognize the Excel file. If this happens open the Excel file and save it as a Database File (.dbf) and it should work.
I hope this helps since I did not have enough information from your question.
Jul 15, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Will not print Word or Excel Documents
pls reinstall printer and reinstall microsoft office also
Mar 01, 2009 | Epson Stylus CX6000 All-In-One InkJet...
63 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
