Question about Epson Stylus CX6400 All-In-One InkJet Printer
I have a cx6400 epson printer, when I turned it on the gold belt inside made a noise as it turned. I got an error message to call a service rep. Is this something I can replace myself, or do I need to take it in.
  • yacht_oasis Jan 31, 2009
    Hi, My Epson CX6400 makes a dreadful noise whilst trying to stack the ink cartridges on startup. It began making this noise (and telling me to call a repair man) at the end of each print run, now it won't start up at all. When I try to change an ink cartridge, the cartridge holder moves past it's normal docking point and when I turn the printer on, the cartridge holder whizzes all the way over and slams into the side of the printer. I think the timing or sensors must be faulty but my supplier says to ditch the printer. Can you help, please?
  • parsons159 Feb 26, 2009
    the gold belt just keeps running and the inc cartridge dosent move
    everything has been cleaned. then it says printer error see documentation bla bla bla. the inc cartridge is not locked but it trys to move just dosent. it feeds paperfine it has ink. what can i do
  • 3 Answers
Solved my own problem by cleaning up the Linear Scale using vodka. This is the thin strip behind the ink carrier, above the gold toothed belt. Persevere, as the ink dries quite hard, but treat it gently. My condemned printer now works a treat.
Posted on Feb 08, 2009
  • 68 Answers
If you mean the rubber belt with teeth on it, first check it's still attached at both ends. If it can't move your head along its slider, it will be because the head is in the locked position.
There will be a little plastic release bar in front of the print head which is locked on the right hand side of your printer. Gentle push the release bar and you should be able to pull the print head away from its locked position.
When you turn on the printer, the head will move and reset itself, hopefully without locking this time.
If it continues to lock then the whole assembly on the right hand side of your printer has lifted slightly.
With the printer turned off and the head slid to the left (see above) put your hand onto the locking/cleaning assembly and press down and it should pop back into its seat.
Turn on the printer and it should reset.
If its the gold/copper looking sensor marker strip behind the print head you are talking about, this is held in position by sprung hooks at each end and the strip is simply hooked over protruding hooks. Attach one end then stretch slightly (compressing the spring) to attach the other. The head uses this to position itself when printing and it is a precise and essential piece of equipment. So be careful with it.
I hope any of this helped.
The INK Store
Posted on Jan 17, 2009
When I turn on my Epson stylus CX6400, it has the message "error-Printer error-See your documentation and call service if necessary." The only thing the documentation manual says about this error is to...
Do you have any other indicators such as flashing lights or similar?
My guess is that it MIGHT be a "service required" error meaning the waste pads are full in which case this guide may help..
There's a reset sequence you can follow near the end of the article which I'd try... If that solves it then you'll need to deal with the waste pads.. If not, you'll know it's something else and can report back..
Feb 23, 2010 | Epson Stylus CX6400 All-In-One InkJet...
I have a error on my epson cx6400 and don't
the best way to solve the problem is to replace the printheads or
Turn the printer on and pull the plug when it starts its initialization process. Can you move the carriage by hand at this point? If not, sounds like you may have a carriage motor\belt issue.
or clear the error message.
Nov 18, 2009 | Epson Stylus CX6400 All-In-One InkJet...
When turning the power on to my Epson CX6400, the following error message comes up: "Error: Printer Error -> SEE YOUR DOCUMENTATION AND CALL SERVICE IF NECESSARY." The little "!" exclamation point...
Sounds like the ink counters need resetting (it happens with other printers as well)
Go here for more info as the prog supports your printer
Jul 17, 2009 | Epson Stylus CX6400 All-In-One InkJet...
Printer reads-"Printer error-see your documentation"... no clue as to what to do.
pull the plug and unplug it again..or load and unload your cartridge..,or change the cartridge you using...maybe the printer don't recognize the printhead..
May 12, 2009 | Epson Stylus CX6400 All-In-One InkJet...
Initial Charge message not seen
Sounds as though the printer is defective.
Call or email Epson Tech Support.
Feb 14, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Not workin'
I assume you've checked and done all the basic things like a power down and power up reset and checked to make sure all the ink cartdridges are properly installed and seated.
The user manual discusses your error message and suggests you do the following: Open the scanner unit to make sure any tape securing the ink cartridge holder has been removed; close the scanner unit/ press the ON button to turn off the CX6400, then turn it back on . If the error message still appears, contact your epson dealer or Epson tech support. If so,then you may want to get direct support and information from Epson at this website :
Technical Support line_dkblue.gif spacer.gif United States Phone Number:
Hours: Mon.- Fri. spacer.gif 6AM-6PM (PT) Canada Phone Number:
(905)709-3839 Hours: Mon.- Fri. spacer.gif 6AM-6PM (PT)
Sep 23, 2008 | Epson Stylus CX6400 All-In-One InkJet...
Epson Stylus CX6400 All-In-One InkJet Printer Logo
194 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
