Question about Desa International RFN30T Open Flame Mid-Size Heater
I have an older fireplace insert type heater which was set up for propane and would like to convert it to Natural gas. Can you tell me where to pick up the correct orifice?
  • Desa Interna... Master
  • 3,335 Answers
Try national energy they will need make and model number
Posted on Feb 25, 2010
Hayward H series propane pool heater, how do I convert to gas?.
I used to be able to get it through my supplier but the link is now dead and shows product not available. I am sure you can get this through Hayward direct. The last kit I bought was around $200 (my cost, not retail). As for a used kit, I seriously doubt that is an option.
Aug 09, 2014 | Hayward H Series Pool & Spa Heater 200k...
Hayward H200P1 Pool Heater- need to convert propane to natural gas
all the parts needed will be in the kit. usually, its the control valve and the jets that get replaced. my manual shows its the same part all units. HAXCNK0002
Need blower for model #crhfd400rt-m-m gas fireplace
PDF]BLOWER ACCESSORY - Home Depot
www.homedepot.com/.../0e104dad-8f0d-4383-aa50-11...
The Home Depotinstructions may result in a possible electric shock, fire hazard and will void ... Thisblower contains assembly instructions for the following models and item ....CRHFD400RT-M-M (Item # 0328248), BD23 series, Q stove, PCSD25RT .... andrequire no further lubrication. ... Type of gas used (Propane/LP or Natural gas/NG).
Lowe's STYLE SELECTIONS Blower Fan for Gas Fireplace ...
answers.lowes.com/answers/0534/product/3162223/questions.htm?...
... real customers have contributed for the Blower Fan for Gas Fireplace Inserts. ... Cedar Ridge 32,000 BTU Vent-Free fireplace (Model# CRHFD400RT-M-M)?
Cedar Ridge Hearth Crhqd250t - Sepeda Ontel Klasik Vector
efratoium.xyz/cedar-ridge-hearth-crhqd250t/
Feb 26, 2013 | Heating & Cooling
How do I convert my fireplace from natural gas to propane
Buy a kit from nat gas to propane in saying that some fireplaces come with both kits .
change injector in pilot and the injector in main burner and the spring in the reg on the fire place , This info should come with the converstion kit
Apr 17, 2012 | Heating & Cooling
I need to get a manual for a Charmglow electric fireplace Model # CGN250TED-C 25,000 BTU Pure Comfort solutions and I cant find a website, i need to know where to change it from natural gas to propane. ...
I am almost totally confused. You started out saying you have a Charmglow Electric Fireplace. Then you said you want to change it from natural gas to propane.
Could you please be a little more specific in what you have? So I can help you. As Charmglow only makes Electric Fireplaces. No gas ones.
Thanks, I look forward to hearing from you.
Aug 10, 2011 | Williams 2509612 Ceramic Mid-Size Heater
I have 3 natural gas fire places. i would like to know if i can change it to propane. i'm thinking i would just have to change the logs and hook a tank up outside. can some tell me if this would work.
Typically gas log sets are factory made for either natural gas or propane. If you want to use them on propane you need to find out if a LP conversion kit is available for your brand/model #. Ask the place where you bought them or ask the company that installed them (if you didn't put them in yourself). If they can be changed over to propane, then you will need to buy the propane tanks, regulator and gasline or just have your local propane company put in a pair of 100# cylinders for each fireplace (or 420# cylinder to service all 3 fireplaces) with an auto-switchover regulator. They can also do the conversion, if the conversion kits are available. Let me now if you have any other questions. Douglas
Oct 21, 2010 | Reddy Heater RLP100 Portable Forced Air...
I have a ProCom FBN400TYLA vent free natural gas fireplace and want to convert to propane because the gas company wants too much money to hook up a line. Is this even possible?
Found the manual on line and copied directly from it:
WARNING
Models FBN400 are equipped for Natural
gas. Field conversion is not
permitted.
Models FBL400 are equipped for Propane
gas. Field conversion is not permitted
This should answer your question.
See if you can run the gas line or find someone to do it cheaper for you.
Nov 15, 2009 | Procom QL300TYLA Heater
Black soot on glass and black smoke comes out
Remove the burner and clean all holes ,typically at the end of the burner is a cheep sheet metal valve.This valve adjusts the air to gas mixture by rotating it to increase or decrease the combustible air intake.Air must be sucked into the burner as natural gas is injected into it, this makes for a clean flame,The flame should be blue with small yellow tips.If the flame is long and yellow and sooty increase the air intake on the burner valve.
Jan 26, 2009 | Napoleon 36" Zero Clearance Top/Rear Vent...
Black sot from vent free gas fireplace
Thanks for your question,
your problem is either impingement on your log set, or a product of incomplete combustion, if you notice soot on your logs, then you will need to take them out, clean them, and reinstall them as to not have the flame touching them, you will need to clean the burners as well, make sure nothing is laying across the burners, as this too will cause sooting, as far as incomplete combustion, was this model a natural gas converted to propane or the other way around ? if so who ever converted it, did they adjust the gas valve according to specs? improper adjustment will cause sooting or hooking up a natural gas unit to propane will do this too, I will recommend using (Rutland White Off) to remove any soot from your glass, it works fantastic for this ! any ace hardware will carry it, please do not use windex or any other cleaner on the glass as it will more than likely leave a rainbow affect on your glass once the glass heats up, hope this was helpful to ya, please rate this solution, thanks agai
mr.grzz
Jan 25, 2009 | Leisure HOMEPRIDE Electric Fireplace...
Physical difference between natural & propane orfice
Merry Lynn, there will be no physical differences between Natural Gas heaters and Propane Gas heaters. Check the model number of the unit, it may have a N or P or LP printed at the end of it to distinguish which gas it uses. The plate that is attached to the heater should indicate the type of gas it uses.
DO NOT try to convert this heater to another gas.
Oct 16, 2007 | Reddy Heater RLP100 Portable Forced Air...
Desa International RFN30T Open Flame Mid-Size Heater Logo
67 people viewed this question
Top Desa International Heating & Cooling Experts
Paul Carew
Ronny Bennett Sr.
Ronny Bennett Sr.
vance jones
Are you a Desa International Heating and Cooling Expert? Answer questions, earn points and help others
