Question about Vivitar ViviCam 4100 Digital Camera
Camera will not stay on
I've just bought a new camera and put the batteries in ? when i tried turning it on, it only came on for a few moments and then switched off ? i've tried many new batteries but it won't power up now? (vivicam4100)
Are you using rechargable batteries if not use them the normal batteries do not last long and to be honest are no good with digital cameras. if you are using rechargable batteries let them charge for at least 5 hours before you use them
Posted on Aug 27, 2007
DS charging..light stays orange...
It could mean that the Motherboard (Main Circuit) could be damaged or could be a fuse problem as you may have said. Although it actually might be the battery, there's one way to find out, if your friend has a DS Lite, ask them if you could borrow your battery for 2 seconds and put their battery in yours to see if it is the battery, if the same thing happens, its the Motherboard (Main Circuit)
Jul 06, 2013 | Nintendo DS Lite Console
CX7300 Digital camera won't turn on. New batteries get hot after being put in the camera after a few minutes.
No. This camera requires service/repairs, the repairs will be more than this model camera is worth !!!!
Nov 12, 2012 | Kodak EasyShare CX7300 Digital Camera
I've bought a new samsung pl121 camera & taken a
Your camera is obviously defective. It may have been a return and resold to you. In any case, you should return it immediately....this problem will only get worse.
Aug 20, 2011 | Samsung Cameras
When I press the power button for my Olympus FE-190 to turn the camera on nothing happens. I haven't used it for a while so I initially thought that the battery might not have any charge. When I put the...
Most likely the battery has been depleted. When you are not using you camera you should always recharge the batteries every now and then. This ensures that they will last longer. Try buying a new battery for your camera.
Feb 28, 2010 | Olympus FE-190 Digital Camera
Battery warming up the camara
Was your camera working before you put the new battery? if yes, then its possible some dirt or grit has got stuck between the lens and the body and therefore you motor might be warming up.
Since you 've bought a new battery, I dont think It may not be the battery, the way you are explaining. It could be the lens motor itself, since its warming up.
Try to do the following: ( I 've got this checklist from the forum itself)
Remove the batteries from the camera, wait a few minutes. Put a fully charged batteries back in and turn the camera on. if it doesnot work then,
2: Remove the batteries again, as also remove the memory card. Then install the newly charged batteries, when you turn it on it should come back to life.
3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during start up. This extra power can be useful to overcome any grit or sand particles that may be jamming the lens.
4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum
6: Repeatedly tap the padded/rubber usb cover with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand.
Try the above and let me if its any help.
Best of luck
Mar 07, 2009 | Casio Exilim EX-Z40 Digital Camera
No power Fuji F10
The symptom of light staying on briefly then going off suggest the battery is dead. If you bought a new battery did you put it in correctly? turn it around and try again.
Sep 02, 2008 | Fuji FinePix F10 Digital Camera
Kodak Easyshare CX7530 won't stay powered on
SOLUTION: Fot the past two years, fully charged NiMH and new alkaline (generic and fresh Name Brand batteries) in my CX7530 always gave a red light and immediate power off -- symptoms of low batteries. Today I tried it again with the same problem. This time, I folded up a small piece of stiff paper to depress the small Lithium battery module detect switch in the battery compartment, and put my NiMH batteries back in -- it WORKED for the first time in two years! After removing the paper and reinserting the batteries, it still works. I suspect this somehow recalibrates the low battery detect circuit. I hope it helps you as well.
Oct 18, 2007 | Kodak EasyShare CX7530 Digital Camera
Vivitar ViviCam 4100 Digital Camera Logo
Top Vivitar Cameras Experts
SHARCNET-USA
SHARCNET-USA
James Woodgreaves
James Woodgreaves
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
