Question about Electronics - Others
USB Flash Drive - Files disappeared
Saved a file onto the USB and left it in the slot and when tried to open the removable drive, it doesn't show any folder or files. it says 0 objects and 0 bytes. but when i choose the properties to see how full it is, it's almost full. and when i tried to open a new folder in the usb drive, it wouldn't let me. what can i do to retreive the files. thanks!!
  • Anonymous Mar 15, 2009
    I used my flash drive to copy files from my computer and safety removed it from my computer.After two days when i try to open it again, no folders files and found. Its empty. i looked at the properties, the space are not used.
Basti
  • 1447 Answers
SOURCE: usb flash drive corrupted
HI-
Have you tried reformatting it? please be advised that you will lose your file if you reformat it. but that could help resolve your issue.
Hope this helps.
Posted on Oct 18, 2008
SOURCE: transcend 1 GB removeable Pen drive is not detected
Its most likely that the device is dead and the data is not recoverable, no software will work as it does not show as a drive. You could send it to a data recovery expert like LC Technology, they helped me on a similar issue.
Posted on Nov 25, 2008
shbuckler
  • 126 Answers
SOURCE: USB Flas Drive - Files disappeared
In the explorer make sure you can view hidden files. (Tools>folder options)
Check the file sizes of each file by mousing over. Add them all up manually. Is this the size of the disk ?
If the total size is not the full storage size copy over to the PC> format the drive and drop them back on.
Posted on Dec 24, 2008
SOURCE: USB Flash Drive
- Click Start / Run / diskmgmt.msc {OK}
- Right-click the memory card, then create a partition & format it.
Posted on Feb 19, 2009
SOURCE: The USB flash drive doesnot shows the file system
There will be 3 reasons of this problems.
If you not not connects this drive properly to system it will show drive property 00 bytes. If you has set up password for this drive then this problem will appeared OR drive is damaged & stopped working. If you trying to connect memory card then change your card reader.
If this flash drive in warranty period then go to authorized service center & give it for replacement.
Thanks.
Happy to help you.
Posted on Apr 30, 2010
Windows run doesn't keep my work history
you have to physically save any work
save the history to a usb drive in case you have computer failure
Plug the flash drive into your computer's rectangular-shaped USB drive.
Wait for Windows to recognize the system.
Windows operating systems use "plug and play" technology, which means that computer peripherals like USB flash drives can be recognized instantly by the system without further need for device configuration.
Open the drive on your computer.
Open the "My Computer" directory if using Windows XP or the "Computer" directory if using
Windows 7 or Vista. Locate the flash drive letter and icon under the section named "Devices with Removable Storage." Double-click the flash drive icon to open it.
Transfer files to the flash drive.
Click the "Restore" button in the top-right corner of the "Computer" or "My Computer" directory to shrink the window so that you can view your computer's desktop background.
Open the folders or locations of the files which you want to save to the flash drive.
Click and drag with your mouse each of the files and folders you want to save to the flash drive over to the empty space in the "My Computer" or "Computer" window.
Release the mouse button to let the files "drop."
Close the windows and directory locations when finished.
Save files directly onto the flash drive. From an open file (i.e. text, spreadsheet, image files. etc.), click the "File" menu and "Save as" option.
Select the "My Computer" or "Computer" directory in the drop-down menu at the top of the "Save As" box. Double-click the flash drive letter under the "Devices with Removable Storage" section.
Click the "Save" button to save the file onto the flash drive.
Close the windows and files when finished
hope this helps
Oct 17, 2012 | Microsoft Windows XP Professional Full...
Having saved files onto my iomega harddrive - how do i re instate files onto laptop
if the hard drive you saved the files to is separate to your laptop you can use a usb portable drive to copy these files to then plug the usb drive into your laptop to finish installing them by selecting the file right click to open
hope this helps
Sep 03, 2010 | Iomega eGo160GB External USB 2.0 Portable...
How do you save files on a sandisk cruzer flash drive?
Insert the cruzer into the usb port. You should see a message pop up and say new hardware found and then flash off. It may also say usb memory or storage device or even recognize it as the cruzor. This recognition process is fairly quick say 5-10 seconds. After that the computer knows what the cruzer is and its ready for use.
The cruzer is now seen as another drive or storage drive on your computer. Your hard drive is usually C , the CD/DVD would be D drive and the cruzer would be seen as E. If you are in a program and want to save to the cruzer you open the file/save and you should see E drive or Cruzer if not click on my computer and look for it there. Once you find it just click on it and then hit save/ok. Thats all there is to using one. Once you know how to find it as a save option or a loading option then you just treat it like a hard drive.
Once you get it sorted out you will use it a lot. They are very handy.
Jun 01, 2010 | SanDisk Cruzer Titanium 2GB USB 2.0 Flash...
How do i download data onto my scandisk
chaqhat4
You would access it from My Computer like your normal harddrive. Note if the removable drive is showing up in My Computer then this is a sign that another device is already been assigned to the drive your USB drive wants by default. The links below will help you assign a drive letter to the USB drive.
How to change your drive letter in Windows Vista and Windows 7
How to change your drive letter in Windows XP
Let me know if you have any more problems or questions
Issken
http://www.fixya.com/users/issken
May 11, 2010 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Cannot copy files says"Cannot create directory or file" even though more than 25GB of empty space left
I had this problem while trying to copy all the files in My Documents onto a USB 2gb flash drive. I reformatted the flash drive to fat32 and the problem disappeared. Hope that helps someone else!
May 10, 2009 | Computers & Internet
SanDisk 2.0GB disk full - but it's not full!
1. Right click My Computer and select Manage.
2. Open the Device Manager and find your USB drive under the Disk Drives heading.
3. Right click the drive and select Properties.
4. Choose Policies tab and select the "Optimize for performance" option.
Click OK.
6. Open My Computer.
7. Select Format on the flash drive.
Hurrah there is NTFS option available now
8. Choose NTFS in the File System dropdown box.
9. Device Formatting is completed.
Important: To remove a device safely without data loss use a "safely remove hardware" procedure or Eject function from Windows Explorer.
Apr 04, 2009 | Electronics - Others
Transfer from usb to micro sd
This mp3 player does not appear to have SD card support. In general terms, however, if you plugged a USB flash drive into one USB port of your computer, and then plugged an SD card into the SD card slot on your computer, you can then double-click "My Computer," and then double-click on "Removable Drive F" or whatever your computer is calling the USB flash drive. Then, open a second instance of "My Computer," double-click on the SD Card logo, and then drag files from the USB flash window, or to the SD card window as appropriate.
Another way to do this without opening a second instance of "My Computer," would be to open up the icon for the USB flash drive, right-click on the first file that you want to transfer, and then select "Explore." The window will then change - you will see the file or files you want to transfer on the right, and all available drives (including the SD card icon) on the left. Drag and drop from there.
-Tha Mp3 Doctor
Dec 28, 2008 | RCA OPAL M4001 MP3 Player
Dec 15, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
USB Flash Drive
By chance was the flashdrive formatted in NTFS? If so, try FAT32.
Also, if you are right clicking a file and using "send to", don't do that. Try "copy" instead, then go to My Computer, right click your flashdrive and select "paste." Then safely remove and see if the files are there.
Aug 04, 2008 | iLO (2 GB) MP3 Player
Lexar flash drive
First, download and try to extract all the files from your drive with this tool:
http://www.lexar.com/drivers/files/ImageRescue_2.0-u(b16).zip
Second, at the moment that you are sure that you have all your files backed up, if windows recognizes the drive, try to right click on it and format
Apr 14, 2008 | Lexar 64MB FLASH MEMORY DRIVE USB 2.0 -...
Electronics - Others Logo
374 people viewed this question
Top Electronics - Others Experts
Marvin
Marvin
Are you an Electronics - Other Expert? Answer questions, earn points and help others
