Question about Casio G-Shock GW500A-1V Wrist Watch
Buttons stopped working
After new batteries fitted the buttons stopped working.
  • 2,334 Answers
Probably you changed battery youself. If that's right, then open watch again, take battery out and check it with tester if it is fully charged. If yes- put battery back in place and secure the contact. Now carefully check for AC sign on movement. When found- take fine tweezers and connectAC with battery+ for 3 seconds.
Watch should work now, but resetting is needed. Use your watch manual to reset all watch functions.
NOTE: Some movements require connect AC and+ twice. This should be written inside caseback or on battery cover.
Good luck.
Arthur
Posted on Dec 17, 2008
    Problem Solver:
Contact inside back of watch circuit wasn't making contact with circuit board. After pushing this together to touch contact the bottons worked again...
Posted on Dec 19, 2008
3 Suggested Answers
  • 17 Answers
SOURCE: Buttons topped working
did the inside of the watch get shifted when the battery was put in or cover repleced. So the out side button doesn't touch the inside sensors.
Posted on Dec 16, 2008
escapement
  • 2334 Answers
SOURCE: start buttons don't work after battery change Adidas Sports Timer
You will have to open your watch, because the contacts or contact springs are not stiff enough, so, you need to make them stiffer.
Do as follows:
1) Open your watch caseback
2) Extract the movement (carefully and using tweezers), do not touch dial with fingers,
3)Take small brush and lighter fluid (ZIPPO) and clean all pushbuttons in case from inside and out pushing them rapidly, then use dust blower to dry the fluid out,
4)On the movement you will see contacts corresponding to each pushbutton on the case. Use needle or sharp metal pin to clean (scrape) off any visible residue from these contacts till they are shiny.
5)Pull all contacts on movement sligtly outwards using tweezers but be careful not to brake. This will make them stiffer.
6)Reassemble the watch and the problem should be sorted.
Do not forget to rate, please.
Posted on Aug 14, 2009
Had a new battery fitted but now cannot set time. B and D buttons do not operate. How do I fix it
It may be that the watch needs to be cleared after fitting the battery.Open the back of the watch and you should see a very small hole marked AC, using metal tweezers or similar, connect the AC to the metal side of the watch, this may clear the system and you should be able to set the time.
Regards,
JB.
Mar 14, 2016 | Casio AW81 7 Data Bank World Time Watch
My armitron all sport watch works, it's only 1 month old, buttons stopped working. any ideas
try to put a new battery..whether it's only 1 mo old ypu can't tell the watch you bougth has a new battery inside.
Feb 02, 2013 | Armitron Watches
I just bought this watch Nautica A31504 and it does not seem that any of the chrono buttons work. Is it the watch that is defective, or am I doing something wrong. In the manual, it says that I can...
The watch has been displayed for long time. You have to replace new battery for the watch and then those functions will work again. Good luck! :)
Feb 10, 2011 | Nautica A31504 Watch
I just replaced the battery on a fossil watch and it won't work. How to you reset it? or what else needs to be done? Please help me. thanks.
mcdevito75 here, Your Fossil watch should work with the battery change, of course it will need to be re-set. You"ll have to double check the battery install, make sure the battery contacts are clean, use a piece of paper towel and carefully clean the battery contacts. Hopefully your new battery is not dead. Another thing to check for, is that the buttons contacts are lined up with the quartz movement. While you double check your battery install, carefully press 1 button at a time, and make sure each button is making contact with the quartz mechanism, many times during a battery change to quartz movement may move just slightly but enough to keep the buttons from contacting the movement, this will keep the watch from working. Hopefully 1 or all of these is the answer for your Fossil watch.
Aug 22, 2010 | Watches
Watch has new battery but suddenly stopped.
Might need cleaning, oiling or other servicing ...
What do you think?
Thanks for your interest in FixYa.com
Feb 19, 2010 | Tag Heuer F1 Indy 500 CAC111B.BA0850
Had a new battery fitted to my tag 6000 and now 2 of the dials dont reset to zero
To reset the chronograph dials back to zero do the following:
1) Pull the crown out to the position where the date can be adjusted and push the buttons.
2) Pull the crown out to the position where the time can be adjusted and push the buttons.
Jan 06, 2009 | Tag Heuer 6000 WH1312.BA0677 Wrist Watch
Dec 15, 2008 | Casio G-Shock GW500A-1V Wrist Watch
Crane and Viceroy ladies RC watch
Hi, Klik and Crane & Viceroy are excellent and robust watches, but due to the radio control batteries need to be changed more often than ordinary watches. Instructions for resetting the time on a Klik or Crane & Viceroy watch. With the watch face upwards and the buttons on the right assume the buttons to be; top button - "A", middle button "B" For setting the watch to GMT all hands need to point to 12 oclock exactly. To achieve this press Button A until the hands start spinning. Stop the spinning when the time reaches a couple of minutes before 12 oclock by repressing A. Inch the time forward by repressing Button A until all hands are at 12 oclock.(EXACTLY). Press Button B within 10 seconds and the time will advance 1 hour and stop. The radio signal will be picked up automatically and time will set itself in a few minutes. Notes: If you have radio dead spots avoid these when resetting the watch and do it away from magnetic or large metal objects. i.e. trays etc. If you are refitting a new battery and have a battery that isn't quite dead, do the advancement of time with the old battery and fit the new one near to 12 oclock to get the best life out of the new battery. If for any reason you want the watch to be in radio mode but read a time other than GMT ( no adjustment is needed for BST ), then instead of stopping the watch at 12 oclock stop it at the time in relation to 12 oclock. i.e. if you wanted the watch to read 30 minutes fast then stop the watch at 12.30. if you want any other info my email is; Charles@adept.fsbusiness.co.uk
Jul 15, 2008 | Watches
Klik r c watch.
problem solved.
regards.
Matt.
Apr 17, 2008 | Watches
CASIO PAG-40 Keeps good time but buttons stopped working
open the backside.
probably the light switch contact at the six side of the watch (attached to the steel mainframe) may have contact with the electronic cirquit
Jan 13, 2008 | Casio PRG-40T-7 Pathfinder
Casio G-Shock GW500A-1V Wrist Watch Logo
355 people viewed this question
Top Casio Watches Experts
Kazim ERGUNEY
Kazim ERGUNEY
Ansel Alberto
Ansel Alberto
Are you a Casio Watch Expert? Answer questions, earn points and help others
