Question about Saeco Magic Comfort 103467 Espresso Machine
Esppresso machine I get a ventilate message and nothing inthe manula/user guide indicates what to do... i need my coffee.
  • Anonymous Apr 26, 2008
    same problem and running the water through it is not working :(
This means there is air in the steam/hot water line. Turn on the hot water button and run it through until it stops saying ventilate. If this doesn't work, there could be more serious problems at work (clogged hose? bad flowmeter?).
Posted on May 26, 2007
Saeco magic comfort display ventilate, what does that indicate
It means that no water is moving through the machine.. To reset, you need to hit the hot water button (that's the button with water drops). Let it run until the message goes away.
If nothing comes out then you need service. We can service this type of machine in New York.
http://www.cerinicoffee.com/espresso-parts/espresso-machine-service-center-new-york.html
Aug 11, 2013 | Coffee Makers & Espresso Machines
We are getting a "ventilate"
Hi.
When you get ventilate the machine functions are locked. Try following the indications here:The following procedure works when you get the ventilate error: The Ventilate sign can...
Regards.
Ginko
Mar 03, 2011 | Gaggia Titanium Espresso Machine
Hello I have a problem with y machine. I have got a message "Ventilate", and i have pushed the button 26, but nothing happens. What to do?
You need to push the hot water button on the machine panel to allow water to run out of the steam wand. After a few seconds the machines ventilate message should clear.
Jun 04, 2010 | Gaggia Titanium Espresso Machine
Machine wont make coffeee, m,essage says ventilate...
You need to push the hot water button on the machines panel to allow water to run out of the steam wand. After a few seconds the machines ventilate message should clear.
May 20, 2010 | Saeco Stratos Coffee Maker, Espresso...
I have saeco incanto deluxe coffee machine,ventilate msg appears
Check the end of the steam nozzle, make sure it is not blocked. If not then with the knob open for hot water cycle push in on the knob if that works then the tap rod assemble or the steam valve needs to be replaced.
Feb 20, 2010 | Saeco INCANTO DELUXE Espresso Machine
How to ventilate a saeco cafe royalecoffee machine
Hi
There is a water button you need to push. It has a water drop on it. This will clear the ventilate message.
Jan 22, 2010 | Saeco Royal Professional Espresso Machine
Why am I getting a "need to prime" message. I have low water flow when I open the hot water/steam valve to prime the machine as per the user guide.
HI
The problem you have is, there is a restriction in the intake of your flow meter. It usually is a piece of coffee that fell into you water receptacle when you had the water tank off. Then you filled the bean hopper and the chip of coffee fell in the receptacle, and then you replaced your water tank and that let the chip flow to your flow meter and now you have a slight flow of water and you always get the ventilate message.
You need to remove the flow meter (in the back bottom of the machine, attached to the tube that goes to the receptacle) and clean the intake side, and then remember "When you are working on either the beans or water, make sure that the other one is covered".
Jul 28, 2009 | Starbucks Saeco Italia Digital Barista...
V entilate?
the machine come with a little pump put water in the pump and insert the pump inthe water hole and press the water in the machine try to ventilate fill the water tank cheers
Jan 16, 2008 | Saeco Classico Espresso Machine
Saeco Magic Comfort 103467 Espresso Machine Logo
214 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
eyecam
Marvin
Marvin
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
