Question about Sharp AL-1641CS Laser Digital Copier
Changed the drum, now power will not come on. help!
Drum light cme on. replaced it, now power will not come on.
  • Roger Binsfeld May 11, 2010
    is the drum light still on? when you change the drum you still have to restet the drum counter. code 24-07
    Novelist:
  • 148 Answers
You have to go to the display and let the copier know you changed the drum ther is a code number you enter not sure for this model
If power does not come on you have not seated the drum or any comonents (there are safety switches in doors and corona ara and fuser area re open and close again
you should get a display
Posted on Dec 30, 2008
  • Steve Archer Dec 30, 2008
Will not cme on
Hi
Firstly - Is the cabling, mains and data cable, securely attached at both ends and the power turned on at the mains?
Secondly - If so when you press the monitor power button, does a light come on? (often orange coloured) If yes does this change colour when the computer starts its boot sequence? (often to green or blue)?
If no light can be obtained it is likely that the monitor is faulty.
If a light comes up on power up, but doesn't change colour during the computer boot sequence then it is more likely to be the graphics card that is faulty, or sometimes the computer PSU.
The easiest way to find out whether the computer or monitor is at fault is to replace the existing monitor with a monitor that is known to be in full working order, for example from another computer. (Or connecting your monitor to a computer that is known to be working)
Having isolated the faulty component it can be replaced and you should be up and running again.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Dec 18, 2014 | GNR TS902D Monitor
Check engine light flashing on motorway journey
I have had the same problem with a Kia Sedona which also gave the same symptoms as it goes into limp mode. I found it was a problem with the fuel filter, this started happening after I ran it low on fuel. Changing the filter and not running it low has cured my problem and might just cure yours.
Jun 04, 2017 | Kia Cars & Trucks
After replacing new drum need to reset counter
With the unit powered on open the front cover link you would to change the drum now press the 'Go' button until all four lights turn on. Now close the front cover, the Drum counter is reset.
I hope this helps, if so please rate my solution.
BuddyMc
Sep 05, 2011 | Brother DCP-8025D All-In-One Laser Printer
Winterized it last fall cme home and put on spin to flush out antifreeze now nothing no power nothing
Hi
It seems that the power board has failed and should be replaced however, .please post back with its complete model no. for further assistance.
Daniel
Mar 21, 2011 | Kenmore Elite 45986 Front Load Washer
Engine light on
If it is a maintenance light, it may just be time for some basic service, like an oil change. If it is a check engine light, you really need to have it scanned, which alot of parts stores will scan it and give you the codes for free. get it scanned and cme back with the codes and someone here will be better prepared to hep you
Nov 05, 2010 | 2003 Nissan Xterra
I have a Scotsman CME 1056R. Diagnostic water light is on
cut power to unit pick up water pump unil u see bottom of pump..try to spin manuely..chances are your pump is locked ..if spins freely ohm out motor windings..make sure ur getting power to pump
Sep 06, 2009 | Scotsman Cooled Modular Contour Cuber Air...
Replaced drum, light won't go out - machine won't run
Hello dear; After you replace drum you need to reset too, the procedure as below;
1, press" clear" "exposure" "clear" "exposure" keys.
2, enter 24 then press start
3, enter 07 then pree start again.
4, turn power off and back on .
Feb 09, 2009 | Sharp AL 1631 Copier
Light copies
If you have changed all you mentioned with the correct parts, I can only advice you to change the control board.
Try to warm your papers
The same power you are using now, is it the same you have been using before facing this light copy problem?
May 08, 2008 | Canon NP 6050 Copier
Sharp AL-1641CS Laser Digital Copier Logo
27 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
