Question about Dishwashers
My kitchen sink is draining into my dishwasher
    Problem Solver:
  • 8 Answers
Take the hose and loop it up opposite of a "p" trap on the sink this way thw water doesn't flow back to the washer
Posted on Dec 15, 2008
Dishwasher Whirlpool quiet partner 2 will not drain
Check your drainage hose going to the kitchen sink. It should be routed up to an air gap on kitchen sink, or ran to the highest point as possible under the kitchen sink counter and then slope down into the disposer or branch wye tailpiece on your drainage piping depending on what your drainage configuration is. Not going up to the highest point, or an air gap, before draining into your drainage piping allows the water inside the dishwasher hose to drain back into the unit.
Feb 21, 2012 | Whirlpool GU2400XTP Built-in Dishwasher
Newer Maytag dishwasher smells really bad inside
This problem can normally be fixed very simply and you can do it yourself.
1. There is a flexible drain line that goes from dishwasher to the sink drain line or garbage disposer.
2 You will find this flexible drain underneath the kitchen sink.
3. Make sure that the flexible dishwasher drain line goes up above the sinks lower portion of the sink basin and then comes back down into the sinks drain line or grabage disposer. The dishwasher flexible drain line must go above the bottom of sink basin like an upside down u shape, it will act as a upside down p-trap that you see under the sink in the sink drainline.
4. Once you have the flexible dishwasher drain line in this configuration (upside down U shape or p-trap) it will prevent air from leaking out of the dishwasher as the smell you are smelling is coming from the drian line.
5. You should also look inside the bottom of dishwasherr to make sure the drain screen is not clogged up.
Sep 08, 2011 | Dishwashers
I have a Kenmore quiet guard 3 model: 665.74364k2 and serie F55202295. It is not draining properly. It works fine and cleans the dishes but when it goes to drain it leaks in my basement ceiling and vents.
if you have an air gap vent in the kitchen sink plumbing then make sure it is clear. Also looks like the kitchen drain end is blocked. Pour some caustic soda into the sink drain, wait 10 minutes and run water into the sink.
If you are using insinkerator (garbage disposer) in sink, make sure it is run before you start the dishwasher.
Jan 10, 2011 | Kenmore 24 in. 15932 Built-in Dishwasher
WHEN RUNNING A CYCLE ON TOP DRAW THE BOTTOM DRAW WILL FILL UP WITH WATER NOT DRAIN
The drain hose going to the kitchen sink is blocked. If you have an insinkerator in your kitchen sink then run it first. Otherwise take the dishwasher hose out from the sink outlet and run straight into sink to see if any difference.
Aug 17, 2010 | Fisher and Paykel 23 in. DD603H SS...
Kitchen Aid Dishwasher does not drain completely
loop the drain hose up under the sink higher than your sink drain.
Jun 21, 2010 | GE GSD1000 Dishwasher
After washing dishes in the kitchen sink, water fills up and stands in the dishwasher and drains only after running the dishwasher
Hi, There is a drain hose under the sink that goes to the dishwasher. Make sure that hose is raised up higher then the drain pipe for you sink. It is just draining into the dishwasher because the drain hose is to low.
I hope this helps you. Please let me know if I can assist you further.
Vic
Jul 10, 2009 | Maytag Dishwasher
Dishwasher water keeps backing up into kitchen sink then taking a long time to drain from sink
Yes, your sink drain needs cleaning -- it's clogged. Pour some bleach into the sink drains and let it sit for a couple of hours. Flush out with boiling hot water.
If this improves the situation but not completely solving the drain problem, try it again.
If that doesn't solve the problem, remove the P-traps on the sink drains under the sink and clean them out.
If that doesn't work, let me know -- we'll try something else.
May 05, 2009 | Dishwashers
Dishwasher drains at the top of the sink? Is this
you mean its draining into the kitchen sink waste pipe. if so this is perfectly correct.
Mar 27, 2009 | GE Nautilus 24" Built-in Dishwasher
Water gets into disher when not inuse
dishwasher drain enters sewer system tapped into waste pipe below kitchen sink
water flowing from kitchen sink passes the opening of the dishwasher pipe
If the dishwasher hose does not loop up higher than the kitchen sink before going down to the bottom of the dishwasher water may flow downhill through the dishwasher drain into the dishwasher
ensure the dishwasher drain hose is screwed to the underside of the kitchen counter, to provide a stop to water flow.
The installation instructions suggest this
but often the dishwasher is at the end of its 'stretch'
and the installer assumes looping is just to use up excess hose, and doesnt.
an extension drain hose is available at most appliance stores
Oct 27, 2008 | Kenmore 22422 Top Load Washer
Kenmore ultra wash dishwasher model665
You have a restricted drain in your sink, not the dishwasher. Water is unable to go down drain fast enough and is backing up.
Nov 13, 2007 | Dishwashers
Dishwashers Logo
56 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
