Question about GE GSH25JFR Side by Side Refrigerator
Water dispenser problem?
Last week the water was coming from my dispenser slower and slower every day. Today it stopped completely. I by-passed water filter, I replaced it with bypass plug, as always during the replacement process some water ammount came out of the filter installation socket. I assume if there is water presence in the system up to filter, then I have problem somewhere after filter, most probably dispenser? Ice maker and ice dispenser working as designed. What is solution of my problem?
  • 1 more comment
  • Vladimir Akopyan Mar 19, 2007
    I just checked everything you suggested and I found frozen pipe in door. Thanks for your help. You are the best. Thanks again and again!!!
  • Anonymous Jun 19, 2008
    GE Profile Artica...slow water, now almost no water and ice maker has stopped making ice.
  • Anonymous Apr 11, 2009
    After replacing filter, the water flow completely stopped. I have also had many of the same fan variation speed problems reported by many others. This refrigerator has had problems since the day I bought it. I will never buy another GE refrigerator, or microwave for that matter. The microwave completely failed after about 2 years of use. Not good.
    President:
  • 878 Answers
Grandfunk, by your post, it sounds like the line is frozen over. You will have to do some tests. First rule out the dispenser itself. While someone is calling for water see if you have 120V to the water valve. If you do, we ruled out the dispenser. Behind the toe panel there should be a water line with a john guest fitting going up the door. Disconnect it there and call for water. Catch it with a cup. If the water is flowing there, you might be frozen up in the door. I have found a couple of these models with that problem. If it's not flowing there, behind the lower drawers in the refrigerator section is the water coil tubing. Take a hair dryer and go over it lightly. It could be frozen over there. Check these things first and post back. Catriver.
Posted on Mar 19, 2007
SOURCE:
Hello, I have a frigidaire side by side fridge and freezer ( LGUS2642LF2). Water stopped coming out of the dispenser and the ice cubes are coming out but is taking a very long time. I first replaced the...
Good Morning Friend,
I understand that you are having trouble with receiving water out of the dispenser area of your Frigidaire refrigerator, model# LGUS2642LF2.I also see that you have changed the water filter as well as checked and replaced the inlet valve with no positive results, other than it sounds like it wants to dispense water and makes a humming sound. I suggest resetting your refrigerator, by either unplugging it or shutting the power off at your homes circuit breaker, for 3-5 minutes. Once power has been restored, try getting water out of the dispenser. If you are still having trouble, I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your appliance and determine what the cause of your refrigerator not dispensing water. Hope this is helpful.
-Best Regards-
WP
May 17, 2014 | Frigidaire Refrigerators
Or Whirlpool refrigerator model GS5SHAXSB00 has stopped dispensing water. What can we do?
Most times the dual water control valve is defective and you can run the simple test found HERE. Click Here for the part that fits your GS5SHAXSB00=> W10408179 Water Inlet Valve
All it takes is for either the ice maker side or the dispenser side of the water control valve to become defective and the complete water control valve will need to be replaced. I will be here should you have any questions, Thanks Sea Breeze
Here is a link to your
GS5SHAXSB00 Repair Parts List
Oct 03, 2012 | Whirlpool Refrigerators
Kenmore Coldspot refrigerator Model #57282791 no water from dispenser
When was the last time you changed the fridge water filter. Sounds like its blocked if no water is coming out of the hose at the bottom front. Also depending on the fridge design two other culprits are possible.the electric switch that is pressed that cativates the water valve to open and let water pass and the second the water valve itself. I would lean toward the water valve at the back of the fridge, as you said it was getting worse over time u til it just stopped.
Oct 02, 2017 | Kenmore Refrigerators
How to resolve our "lack of water" issue..within the last few weeks, the water dispenser's water flow lessen with each day-now it does not just doesn't work
there may be a problem with the water lines or bottles in the fridge compartment is frozen raise the temp in the fridges to about 38 for a couple of days and this should unthaw the lines
Apr 13, 2010 | LG LFX25971ST Bottom Freezer French Door...
Ice & Water Dispenser Suddenly Dysfunctional; LED lights, too!
Cory, you sound like you have a bad water valve as well as a bad control board for your dispensor. If you've had any storms in your area in the past 4 - 6 weeks, it's very possible that the storm took both parts out.
We have parts for GE as well as mots other major brands, so please give us a call with your complete model number and we will get your parts out to you right away!
We hope this solves your problem and we look forward to being able to assist you with future issues.
Have a great evening.
Nov 05, 2009 | GE GSS22JF Side by Side Refrigerator
Water dispenser worked perfectly for 9 months. Today, no water comes out at all.
hi michael! you may have to get out your owner manual and read about how to change the water filter. get back if u need assistance
May 09, 2009 | Refrigerators
Grinds beans, won't dispense water sometimes
I just had this problem. I took apart the brew chamber and cleaned under the screens and everything else I could get to along the path of the water. These areas were completely filled with gum residue and solids. I'm guessing that when they dry out, the water can pass through for a little bit. After a cup or two, they go back to blocking off the water flow.
Mar 09, 2009 | Saeco Vienna Espresso Machine
No water from water dispenser
wat temp are you runninr in the refrigerator side? it should be at 38 degrees because now days the are using an averaging sensor inside and also if tis any colder yoou will possibly freeze you produce
Dec 25, 2008 | Refrigerators
Dishwasher not filling with water
My GE Nautilus, Serial # GSD363F00W, Model # LA774908 is about 3 or 4 years old. I use it at least once a day. It has been working fine. Today I turned it on, red light came on, and I heard activity of some sort inside machine but no water came. Turned washer off, looked inside, no water. Turned machine back on, again heard some sort of activity but again no water came. Tried twisting the dial through the washing cycles, detergent cup dispensed detergent and dry heat come on, but no water.
Jul 21, 2008 | GE Nautilus 24" Built-in Dishwasher
Water Dispenser and Ice Maker
Have you checked the pressure limiting valve which protects the filter from over pressure? It could be blocked/faulty. Have you checked the inlet on the valve assembly? It may be clogged up. Try bypassing the filter all together to determine if the filter is faulty.
Oct 29, 2007 | Admiral 26 cu. ft. Side-By-Side...
GE GSH25JFR Side by Side Refrigerator Logo
314 people viewed this question
Top Refrigerators Experts
Sal De
Brad Goodale
R.A. Ellis
R.A. Ellis
