2004 Ford Freestar Logo
Posted on Dec 15, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Air in power steering lines
Replaced power steering pump on my 2004 ford freestar van, re hooked
everything back up, but can't get air out of lines, and the steering is very
hard. Also i was told not to use power steering fluid in reservoir, but to use transmission fluid, is this corredt
  • csw13 Jan 09, 2009
    I too have the same problem and just had power steering pump replaced which did not fix the problem. They are now telling me its a problem in the steering column itself. What could this be and is it a result from a previous recall # 11253 issued in 2003?
  • Anonymous Mar 27, 2014
    i was told it was coming from power steering pump which has been replaced but still have wining noise.
Anonymous
Level 3:
  • Master 659 Answers
  • Posted on Dec 16, 2008
Anonymous
Master
Level 3:
Answers
659
Questions
Helped
338708
Points
2279
Trans fluid and p/s fluid same thing thats fine. Did you fill fluid first before starting vehicle? These pumps burn up easily if run dry.
2answers
2answers
How do I fix my shifter on my 2004 Ford Freestar Van?
The cable HOUSING has become loose from the anchor point. Get under with a hammer and a pliers and put back in place. Then persuade it to stay in place.
Why wont my ford 2004 freestar reverse
Failed Transaxle
That vehicle has one of the most
common trans to fail
Most likely need to rebuild it
If you fail to change power steering & trans fluids, every
3 years, those items will fail,guaranteed, on all vehicles
2004 ford freestar van idles rough
For rough idle and error code issues on your ford freestar.Click the link below:----
http://howtobyme.blogspot.in/2012/01/2004-ford-freestar-van-idles-rough.html
--------This will help.Thanks.
2004 ford freestar 4.2L engine...high pitched
this sounds odd but mine did this when i replaced the wipers. it seems the design of the wiper frame was making a whistle at higher speeds. the freestar wipers are exposed on the window cowl and not hidden so they endure the winds at high speed. it is worth a shot.
How do you get the sepentine belt back on a 2004
it is located under the power steering pump pulley towards the rear of the engine u have to rotate the the tensioner counterclockwise then push the spring clip towards the tensioner.
The little black catch at back on the 2004 freestar van body will not release when opening the sliding door
POWER SLIDING REAR DOOR WON'T OPEN ON A 2004 FORD FREESTAR WHEN THE BUTTON IS PUSH EITHER ON REMOTE OR CONSOLE. ONE DOOR DOES WORK.
2answers
Orange fluid leak (most likely power steering fluid)
Check your hoses around your power steering resevoir, you might have a pin hole leake in one of the hoses. Make sure to keep an eye on the fluid level. As long as you keep fluid in it you won't burn out the pump.
Top Ford Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
xxxxxx xxx
Are you a Ford Expert? Answer questions, earn points and help others
