Question about HP Photosmart C6180 All-In-One InkJet Printer
I Have an HP c6180
I get an 'Ink system failed' error code. ' 0xc18a0006' I tried the online reboot solution. No help
  • 4,041 Answers
Hi I found this I know your error not in here but it may work for It worth a try nothing to lose and it may work. I know your error code is not in this but it some times it clean the error with this type of error number you can gave it a go try not harm it Error code: 0xc18a0201, 0xc18a0206, 0xc18a0306, 0xc18a030a, 0xd0620130, 0x887dd03a, 0xd05d010d, 0xf0af8004, 0xc19ac3ff, 0xc18a050...
Reset the product:
1. Without turning off the product, disconnect the USB cable from the rear of the product.
2. Remove the cartridges from the product.
3. Wait for the 'Insert Cartridges ' message to display on the control panel.
4. Disconnect the power cord from the back of the product.
5. Wait 60 seconds.
6. Reconnect the power cord. If the product does not automatically turn on, press the Power button ( ).
7. Reinsert the cartridges, and then close any open doors on the product.
8. If you receive a prompt to print a calibration page, do so.
9. Reconnect the USB cable to the rear of the product, and then try printing again.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 08, 2010
.photosmart c6180 ink system has failed unable to copy recieve fax or printerror 0xc18a001
As always I start with the dreaded question. Did you use a refilled cartridge in your printer? If so, remove it and install a new HP cartridge. Recycled cartridges are famous for this type of failure. By the way the error code is a Windows error code. If you haven't found a solution to the " ink system failure " yet, it is quite easy to reset (using the buttons) on HP C7180. You can find the reset instructions on my website: http://www.inkbank.com.au/webcontent21.htm
Try this:
May 04, 2015 | HP Photosmart C6180 All-In-One InkJet...
Error 0xc18a0006 Ink system has failed. Unable to copy, recieve faxes, or
You cannot repair this error as no parts are available from hp .
Srri but thats HP for you.
Jun 19, 2011 | HP Photosmart C6180 All-In-One InkJet...
HP photosmart c6180 all in one printer error message of 0xc19a0035, ink system has failed. unable to copy, receive faxes, or print. what can i do to fix it?
The "Ink System Failure" error is caused by air in the ink fed tubes. We have a step by step guide to perform a ink purge on the printer posted on our web site at: http://www.ccl-la.com/blog/index.php/category/printer-repair/hp-printer-repair/ Following this procedure should get your printer back running in about 10 minutes.
I hope this helps, if so please rate our solution.
CCL_Tech
Corporate Computer
www.ccl-la.com
Aug 03, 2010 | HP Photosmart C6180 All-In-One InkJet...
Oxc18a0101 error message ink system failure
*** Fix your HP Photosmart D7360 (Reset Code/Master Reset) ***
1- Turn off power and unplug from power source.
2- Open right side of printer (looking at the front).
3- Disconnect,by pulling gently, both white flat ribbon cables off the main circuit board.
4- Plug in power source and turn printer on. Wait till you get a error message and push "Ok".
5- Unplug power source.
6- Reconnect the flat ribbon cables by aligning and carefully pushing into the conectors on the main circuit board.
7- Plug in power source and turn printer on (Printer preparing occurred).
8- voila, the nasty error message 0xc18a0001 "Ink System has Failed" is now gone. http://www.fixya.com/support/t451942-help THIS WORKED!!! Don't throw it out try this first for: Ink system failed Error16x16_smiley-surprised.gifxc18a0101 on photosmart D7160. This is to reset the error code only,you will need to explain in more detail why you got the code and what you've done to correct it.
Jan 24, 2010 | HP Photosmart C6180 All-In-One InkJet...
I am having a problem with by printer C6180..error it is giving is ink system has failed...error 0xc19a0035
call HP support. They will give you a series of codes to enter into the keypad. They are the only ones that can solve this problem.
Dec 08, 2009 | HP Photosmart C6180 All-In-One InkJet...
Ink System Failure HP C5180
IssueAn 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel. The printer cannot copy, receive faxes, or print. Solution
Press the On button to turn the printer off.
Unplug the power cord from the back of the printer.
Remove all the ink cartridges.
Wait two minutes.
Plug the power cord into the back of the printer.
Press the On button to turn the printer on.
Install the ink cartridges when prompted.
If the error code does not display, the issue is resolved.
If the 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel, service the printer.
Jan 23, 2009 | HP Photosmart C6180 All-In-One InkJet...
Error Code 0xc19ac3ff
This problem seems to have occurred a few times... The only thing i would adise you to do is call HP and see whats the deal. Number is 800-HP-INVENT
Nov 23, 2008 | HP Photosmart C6180 All-In-One InkJet...
Oxc18a0101 error message - C6180 All-In-One
Try the following reset:
Hold the OK and the Help button at the same time. While holding them down, plugthe power in. Continue to hold both buttons until the unit shut off.
After shutting down, release both buttons and power on the printer.
Alternatively follow instructions on this document from HP.
Oct 14, 2008 | HP Photosmart C6180 All-In-One InkJet...
Ink System Failure
below is to document that i want you to follow exactly inorder to resolve your issue..
CLICK HERE ==>> DOCUMENT
Please let me know the result after following the document.
thank you so much.
adonscott
Aug 07, 2008 | HP Photosmart C6180 All-In-One InkJet...
Solution
Wait two minutes.
Jul 18, 2008 | HP Photosmart C6100 All-In-One Printer
HP Photosmart C6180 All-In-One InkJet Printer Logo
453 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
