Question about Inter-Tel Axxess Corded Phone
Selecting a custom recording.
I am trying to select a custom recording and apply it to the night ring mode. What I am doing is dialing in, selecting "9" then "4" as instructed in my manual. Then I enter the application extension number, then I am selecting 2 for a night recording. I have a custom recording already saved, so I am selecting that # to apply that as my night recording. Then I press pound to accept that recording. I then swith my phone into night ring mode, and I call in to check to see if the message is saved, and it is my "default" message, which is also a custom recording. So pretty much it is not saving when I try to change the night ring message, and I have been unable to figure out what I am doing wrong that it wouldn't save. I tried multiple times, and even had someone in my office look at it but it is still just not accepting the changes.
    Problem Solver:
  • 9 Answers
I was told that the day and night settings in the local applications must be the same. It is in your night call routing table that you need to place the extension in order for the system to know which recording to play when. Then, your system will play the application when it is set in night mode. Hint: When you place the extension in the call routing tables make sure the extension is placed ABOVE the +ALL CALLS line, if applicable, and your ring-in-destination is set to your appropriate application recording. I hope this helps.
Posted on Jan 15, 2009
My phone is not ringing, what should I do. I have a KX-TGA41OC
    A)The ringer volume is turned off. Adjust the ringer volume (page 16).
    B)Night mode is turned on. Turn it off (page 25) A)Adjusting the handset ringer volume
    While the handset is ringing for an incoming call:
    Press {??} repeatedly to select the desired volume.
    Programming the volume beforehand:
    1 {MENU} #160(include the # key)
    2 {??} Select the desired volume.
    3 {SAVE} {OFF}
    B)Turning night mode on/off
    1{MENU} 238
    2 {??} Select the desired setting {SAVE} If you select "Off", press {OFF} to exit
    3 Enter the desired hour and minute you wish to start this feature.
    4 {AM/PM} Select "AM" or "PM" {OK}
    5 Enter the desired hour and minute you wish to end this feature.
    6 {AM/PM} Select "AM" or "PM".
    7 {SAVE} {OFF} When the night mode is set, the night mode indicator is displayed
Dec 18, 2014 | Lands Phones
My samsung ES90 didnot flash night and day
With the round dial on the back of the camera, you can select different things. One is the flash. Press on the left side t chose the flash mode with flash on. If you used that button once, for selecting class of, I'm not sure the default value will come back after you switched of and on the camera.
It also could be you did select a certain shooting mode. Some modes, don't use flash, unless you selected it.
Dec 16, 2013 | Cameras
Panasonic KX T7433 - I need to change the night mode message howevern when I select intercom 165 or intercom greeting and change the message I am unable to select the new message as the new night mode...
It's only that simple if you have a guide to what Custom Service or greeting plays now. When the system moves from Day to Night mode, the installer assigns a menu that plays. You can change it if you know which one. If you don't get the right one, there would be 98 other custom service and 31 other Company messages that you could record to and they'll never play.
Aug 23, 2011 | Panasonic KX-T7433B Corded Phone
Lamp lights without command no longer open in the minidv box black screen does not play, not record one more thing to do?
Solution 1 • Unlock focus area selector. • Auto-area AF selected for Custom Setting 2 (AFarea mode): choose another mode. • Press shutter-release button halfway to turn monitor o?¬? or activate exposure meter • Memory card is full, locked, or not inserted. • Flash is charging. • Camera is not in focus. • CPU lens with aperture ring attached without locking aperture at highest f/-number. • Non-CPU lens is attached: rotate camera mode dial to M. • Mode dial rotated to S after shutter speed of bulb selected in mode M: choose new shutter speed • P, S, A, and M modes: lower ?¬? ash. • Digital Vari-Program modes: turn ?¬? ash o?¬? Turn long exposure noise reduction o?¬? Turn long exposure noise reduction o?¬? Press multi selector up or down or rotate sub-command dial to choose photo information displayed Select All for Playback folder. Note that Current will automatically be selected when next photo is taken • Select On for Rotate tall. • Photo was taken with O?¬? selected for Auto image rotation. • Camera orientation was changed while shutter-release button was pressed in continuous shooting mode. • Camera was pointed up or down when photo was taken Use Nikon-approved card. • Card may be damaged. Contact retailer or Nikonauthorized service representative. • Delete unwanted ?¬ les or insert new memory car
Jan 26, 2011 | Samsung SC-D103 Mini DV Digital Camcorder
Language option
Selecting the desired language:
1. Set the mode dial to P and press the power to switch to turn on the camera to the ON position.
2. Press MENU button.
3. Press arrows dial buttons to select the MODE MENU.
4. Press arrow dial buttons to SET UP tab.
5. Press arrow dial buttons to select Language.
6. After selecting the language press OK dial button on the middle of the group buttons.
That is all. So you can change the language by this way.
Apr 15, 2010 | Olympus Camedia C-755 Ultra Zoom Digital...
How to increase brightness in Canon Powersot A620 ?
Are you asking about brightness as viewed on the LCD, or are you asking about increasing brightness on the actual image taken? If it's the image, there are two special modes that you can select on your mode dial. They are "Night Scene", "Night Snaphot", and "Indoor". A description of both, along with your camera's other special settings, may be found here:
"Night Scene" can be selected directly from the dial. It's the one showing a person standing under a star. Note that Night Scene should be used with a tripod to reduce the potential for blurriness.
"Night Snapshot" works almost as well, but does not require a tripod. It can be accessed by selecting SCN on the dial, and then pressing right or left with the selection buttons until it shows in the menu. The camera will remember this setting the next time you select SCN. I usually keep my camera always set to this setting so that I merely have to select SCN to use it.
"Indoor" works very well in those large rooms that may produce dark backgrounds when taking photos. It also does not require a tripod. It's accessed the same way as "Night Snapshot" (Select SCN, then right/left until selected). This is another good setting that I like to keep sometimes set in SCN.
Try all three settings, (and don't forget all the others too). Think you'll be impressed.
Feb 23, 2008 | Canon PowerShot A620 Digital Camera
Make your own ringtone
hold down the right smartkey on the right side of the phone) and start recording, when you let go of the key, you'll have options, one of which will be "apply as ringtone".
You might try going into your sounds menu and see if the voice record you had is still in there, then selecting 'apply as ringtone' from the options.
Oct 04, 2007 | Motorola Mobility MOTOKRZR K1 Cellular...
Fugi finepix s7000 auto shut off
keep camera on shooting mode.Turn dial to SET UP mode.Select POWER SAVE mode by lower navigation key.Press right navigation key to select one of the 2MIN -5MIN-OFF modes.By selecting OFF mode the camera will never be off until u turn it off.After selecting desired mode.Turn dial from set up mode to desired shooting mode.
Aug 30, 2007 | Cameras
IstD problem selecting recorded pixels and RAW/Tiff/jpg
I'm not sure what could cause this, in fact I don't even own the D but..... Approcahing this from a Network Analyst's poiunt of view, it's either hardware or software. The fact that all other modes are OK would indicate that the hardware may be ok. Assuming that it's a software glitch have you tried installing the latest firmware ? It may be worth a try if your problem is a result of some corruption your exisiting fw. It'll cost you nothing to try it anyway.
Sep 08, 2005 | Pentax *ist D Digital Camera
Record a movie in QuickTime Movie mode
After selecting Quicktime Movie mode from the mode dial, you can begin recording by pressing the shutter button. Press the shutter button again to stop recording the movie.
Sep 04, 2005 | Olympus Camedia C-60 Zoom Digital Camera
Inter-Tel Axxess Corded Phone Logo
337 people viewed this question
Top Inter-Tel Lands Phones Experts
David Burbee
David Burbee
Are you an Inter-Tel Lands Phone Expert? Answer questions, earn points and help others
