Question about Kenmore Elite HE4 Electric Dryer
Dryer will not start
I cut the power on, everything lights up, I push the start button but it doesnt start instead I hear a beep beep noise........????
  • Anonymous Mar 19, 2014
    dryer turns on push start button and it just beeps
    Problem Solver:
  • 10 Answers
There is a start relay on the computer control board. You probably hear a very dull click. That click is the relay on the computer board trying to engage, but it won't and therefore your dryer won't spin and your board sends a beep and perhaps an "E11" error code to the LED display (Not sure on Kenmores.).
In plain english, you have a bad control board now and will have to replace it. Cost about $130.
Posted on Dec 19, 2008
Inglis IFR 8200 electric dryer - power light comes on but no power to motor or heater. TCO hasn't tripped Any ideas?
Check the door switch! This is the likely culprit if the motor will not start. You can push the button in by hand with the door open and while holding the button in, push the start button. If still no go, check the switch itself does it click when pushed in and released slowly. If you can't hear or feel it clicking, replace the door switch. You can verify the switch function with a multimeter by reading across the switch without power applied and check for continuity as it changes state.
Jan 30, 2017 | Dryers
I am having problem getting my dryer to start. I turn it on and everything lights but but when I press start button it just beeps at me.
These symptoms characterize a problem with a blown thermal fuse located on the blower housing. It is wired in series with the motor and cuts power to the motor when it blows and the motor cannot run. Dryer function works when the motor is not running. Click on the link below for the detailed procedure in troubleshooting this kind of dryer problem.
Troubleshooting Whirlpool and Kenmore Dryers Not Starting
Mar 30, 2011 | Dryers
Start button does not work on our Asko t720 dryer
if you get a light on the main power switch, then it might be overheat cut-off switch wich has been activated. This is located outside on the back of the machine. a rubber button aprox in the middle, you must push this, and hear a 'click'. it might be a solution.
Jul 07, 2009 | Asko Dryers
Getting power but wont boot up or anything
pull out everything in the computer except what's required to any pci cards or video cards (if you have onboard video). you can also try pulling out the ram (while unpowered AND unplugged) and then booting to hear beeps...if you pull the ram out and the computer doesnt make a sound, its probably a bad motherboard and needs to be replaced. if you hear beeps, try replacing the ram or disconnecting other harddrives, optical drives, modems and what not.
Apr 26, 2009 | E-Machines T2792 PC Desktop
Dryer won't start. Pressing "Start" button just emits 4 beeps.
does the drum turn? if it doesnt you can assist it and see it that is problem, have to remove top and push it. that would be capacitor on motor or jumper the door closed switch and try to spin.
Apr 21, 2009 | Dryers
Won't start
is the light going off when the door is closed, and on when opened??? sounds as if you having ansd issue withthe door switch, notthinkin the door is closed, try manually pushing the buton in, you should hear it "click", if it doesnt, i would unplug hte unit, nad witha screrwdriver you can pry the switch out from the side of switch. Dont ask me why buit for somereason afetr removing from the unit, it then will"click". somply prerss back inot place.Never actually had to replace teh switch, perhaps it gets stuck!
Jan 11, 2009 | Whirlpool Duet 7.0 Cu. Ft. Capacity Plus...
Kenmore Elite HE3 Dryer (3 yrs. old)
when u push the buttons do all lights light up if so ,, machine is in lock mode ,, press and hold the little icon that read lock for about 3 seconds unitll lights are off then run ,, let see
Nov 19, 2008 | Kenmore Elite HE4 Electric Dryer
Dryer just says beep beep beep everytime I push start
sounds like you may have a bad door switch(mach thinks door is open when it is not).open door and look on front panel that door pushes should find a small button covered in a grey rubber boot.push on it and listen for a click,if u dont hear a click the switch is bad.if u do hear a click it could still be bad or you can have a open thermal fuse
Sep 29, 2008 | Whirlpool GEW9250 Electric Dryer
Kenmore Elite HE4 Electric Dryer Logo
344 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
