Need the original password and user for modem
  • Wimpie Hall
    Wimpie Hall May 11, 2010
    Hi weeejeee
    Need more info
    Which modem : make and model number
    Please remember to give as much info as possible the better the info the quicker we can help you resolve your problem.
    Regards
    Go-Tech
  • 43 Answers
There are password crackers out there that may help you with this,one particular site is "mininova."Go there and look under software.
Posted on Dec 15, 2008
I have my android cell phone an I want to connect to interent,, but it keeps asking for the password of modem... I put in whats on the side of the box... I need modem password.. how do I get that? help
If it's a CradlePoint router or modem/router, the owner may have enabled access control under
Tools -> User Login -> User Login Settings -> Require User Login, and
Tools -> User Login -> Internet Access Password.
Which causes a java popup to appear prompting for a password (which is not necessarily the same as the modem/router's administration password; typically it's NOT the same).
I imagine other routers could have similar settings... a good reason to include details such as the brand and model of the modem/router.
Mar 08, 2015 | Computers & Internet
Invalid user name or password
Have you made an attempt to enter the controller using the 192.168.0.1 in the command line of your internet explorer? The numeric sequence may need to changed using 192.168.1.0 or other codes as I cannot advise which address is available to you. Once you are in the setup using adm and No password, everything else is up to you.
Mar 12, 2014 | Computers & Internet
How do I install a driver for the SB5100 when I don't know the password
This is the original Install disk:
SB5100 Series SURFboard Cable Modem Installation CD ROM Motorola Inc Free...
Just install the original drivers and you should be fine.
If still asks for password,
it is the Administrator user and password for that computer.
Hope it helps!
Feb 05, 2018 | Arris SB5100 SURFboard DOCSIS 2.0 Cable...
I wnt reset my afaq shamel wireless password
Access to the modem page
Put this number / http://192.168.1.1 on your browser
When you put it tell you to put your user name and password looks like this:
Username: Afaq_shamel
Password: stccpe_2007
After put password and password claimed Tnafthalk forgiven the modem and the original image as shown in the picture
Back Matdguet claimed Untouchable Press Options as in the picture
Put options as in the picture and remember that you must be 8 digits should not be less
to get photos (step by step) click here
May 19, 2011 | Computers & Internet
Need modem reset - unable to access using original user ID and password.
Press RESET button for 10 seconds it is in back side of router then all settings defaults.Then you can configure it with below method. Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Then configure wan settings and lan settings enable wireless if you want to use wifi . Let me know if you need further assistance. Thanks for using FixYa.
Oct 10, 2010 | Arris SURFboard SBG900 (49402201900) Modem
A user name and password
You need to hard reset the modem first. By doing that, look at the back of the modem then look for red button. Get a pen or something pointed that will fit on the red button. Press the reset button of 30 seconds then you will see that the power light will change to orange light. If every light is already disable. You can access the firmware of your modem. username: admin
password: password
the you can configure your modem now.
May 23, 2010 | Westell Wirespeed LiteLine 6100...
I have lost my router User Id and Password. So is there any way to fix it or i need to get a new router...
In the back of the unit there is a reset button, you need to hold it in for 30 seconds, this will set everything back to the default setting.
Your default settings are
user--admin
password- motorola
You will have to run through the settings to set up the router again.
Feb 06, 2010 | Arris SURFboard SBG900 802.11g/b...
Siemens SL2-141
Go thro' the manual of the router there should be a resetting method for the router, ( a small hole thro which you should use some object to press a push button) in order to reset the router to factory setting, when this is done the user name and password is reset to the original factory settings with the default username and password then you can log in and re-configure your router for your ISP services.
Dec 31, 2007 | Computers & Internet
Speedtouch username and password
i need user name and passowrd for modem speed touch
Nov 12, 2007 | Computers & Internet
Speedstream 4200 setup
I have just set up 4200 with dsl - you may find that you need to reset modem before you can configure. I was told that you need either a grey or yellow cable from your laptop to the modem. I use 10.0.0.138 to access modem. The 4200 I have was from a bigpond a/c - originally configured accordingly.
Regards,
Richard
Nov 12, 2007 | Siemens SpeedStream Modem (4100) (SS4100)
Computers & Internet Logo
David Payne
David Payne
