Question about Powerware 9120 UPS System
LCD shows Low O/P V
I turn on the UPS without anything connected to it. It stays a few seconds on "On Line" then it changes to Low O/P V
What can be the problem?
  • 2 more comments
  • Pmartins Dec 17, 2008
    My unit say the same. what we can do to solve this situation
  • bargeoffroy Feb 01, 2009
    My unit have the same problem too :(
    "Low O/P V" on screen
    I have tested the outputs voltage and i got the good value
    Someone have a solution ?
    I didn't notice any blow condensator on main board
  • bargeoffroy Feb 20, 2009
    cgeorgoulis & Pmartins> No solution ?
  • Guille Schim Dec 18, 2013
    They say that changing some optocoupler right down the PCB solves this. Any comments?
  • 3 Answers
Fault: Low Ouput Voltage
Cause: Surge Taken by load / Short Circuit on load / Fault in inverter
Remedy: Remove load and restart UPS / Try a different load / Repair or swap out
If you need spares or price for repair contact Eaton Power Quality Ltd - the new name for Powerware - 01753 608700
Posted on Jun 17, 2009
    New Friend:
Hi to All
I had the same issue where the UPS started (loaded or not) and immediately sounded an alarm with Low O/P V and it tripped the breaker at the mains. Tried starting the UPS with no power to the device as well (cold start) with no success.
I removed all batteries to reset the UPS and powered up again, same thing happened.
I then moved the UPS without any batteries to another power point in my home (different breaker on the mains) and device booted with "DC bus Fault"
Powered everything down, loaded all the batteries and it booted up 100%!!! So it turned out to be the breaker for that location... Worth a try and will save you allota tom!
Posted on Apr 08, 2014
Sony bravia works on ups/battery not mains :(
Sure sounds like the power supply board received an insult that allowed a different voltage to work for a while . UPS will regulate top 120 volt whereas mains may be higher or lower . You may be able to change bad capacitors or just buy the power board between 80 to 200 dollars .
If it was connected to UPS during surge it should have been protected...make sure you are connected to 'battery' side as a lot of UPS have a 'surge only' side that will not stop a rapid on/off power insult .
Hugh
Mar 02, 2017 | Sony Bravia KDL-26L5000 26 in. LCD HDTV
The battrey leds stay flashing i changed battries also the led still flashing
Automatic: The UPS performs a self-test automatically when turned on, and every
two weeks thereafter (by default). During the self-test, the UPS briefly operates the
connected equipment on battery.
Manual: Press and hold the button for a few seconds to initiate the self-test
REPLACE BATTERY LED ILLUMINATES
Replace Battery LED flashes and
short beep is emitted every two
seconds to indicate the battery is
disconnected.
Check that the battery connectors are fully engaged.
Weak battery. Allow the battery to recharge for 24 hours. Then, perform a self-test. If the
problem persists after recharging, replace the battery.
Failure of a battery self-test. The UPS emits short beeps for one minute and the Replace Battery LED
illuminates. The UPS repeats the alarm every five hours. Perform the self-test
procedure after the battery has charged for 24 hours to confirm the Replace
Battery condition. The alarm stops and the LED clears if the battery passes the
self-test.
Sep 09, 2011 | APC Smart-UPS RT 5000VA (SURTD5000XLI) UPS...
Hi, I've APC UPS ES 500 connected to my desktop computer. Have 1 year old battery but when checked without load displaying 12 V. Issues are: a. ups doesn't supply...
A battery showing 12V without a load attached means nothing. You probably have one or more weak cells and they simply cannot supply enough power. I would try a new battery before I try anything else.
Jul 21, 2011 | Office Equipment & Supplies
My Samsung 42" LCD used to turn on quickly, now it takes a LONG time for the screen to show anything. It looks like it turns on, turns off, turns on, etc. 7-8 times before finally staying on--almost like...
Ageing capacitors usually causes this sort of problem. They change value going low capacity etc. A replacement flourecent display board may likely fix it as the display is taking too long to come on.
Oct 16, 2010 | Samsung LN-T4081F Television
Tripp Lite OMNI 1000 LCD will not stay on
Turn UPS on: Press and hold the ON/OFF button for one second.
Run a Self-Test: Press and hold the MUTE/TEST button for two seconds (until alarm beeps several times).
The test will last 10 seconds. All LCD Display icons will be illuminated and the alarm will sound.
If the fault icon remains lit, the battery-supplied outlets are overloaded. Unplug powered devices until you remove the overload.
If the "Replace" icon remains lit and alarm continues to sound, the UPS batteries need to be recharged or replaced. Allow UPS to charge for 24 hours and repeat self-test.
Feb 19, 2010 | Tripp Lite OMNIVS1000 UPS System
Mge pulsar 3000 does not power up
MGE Pulsar 3000 is an online UPS. try to check the battery first if its ok. coz for an online UPS it will need to have a good working UPS battery to trigger the switching relays to on the online UPS unlike backups UPS that can be turn on without any batteries
Aug 13, 2009 | MGE UPS Pulsar Evolution 3000 UPS System
Nexxtech UPS Battery shows full charge but won't stay on
had same problem! i discovered that the unit was defective,sorry if this is the case. good luck!
Feb 02, 2009 | Computers & Internet
TV turn on for few seconds then turn off.
This TV has a network of diodes connected to a PROTECT-1 line monitored by the control IC. If any circuit pulls this line low, the control IC turns the system OFF. The diodes act to isolate all the circuits from each other, its called a diode-OR circuit.
You can troubleshoot by opening a diode which disconnects a circuit from pulling the line low. I had a hunch the EL backlight board was bad, so after opening that protect line the power stayed ON.
I found a bad .068uF 250V cap on the transformer primary, it measured .002uF. I've replaced the cap and the other two on the other transformers just for good measure.
It probably took more time than the TV is worth, but my friend's Mom will be happy, and thats worth it.
I hope this helps, look around for the service manual, it can be found online.
Dec 02, 2007 | Emerson EWL20S5 20 in. EDTV-Ready LCD...
Low battery alert on my apc - ups es350
Have your supply voltage and frequency checked under load.
/bz
Oct 30, 2007 | APC Back-UPS ES 350 - UPS ( external ) -...
Powerware 9120 UPS System Logo
1,856 people viewed this question
Top Powerware Computers & Internet Experts
Vassilis Chamaidis
Level 1 Expert
Marvin
Marvin
Jax Planet
Jax Planet
Are you a Powerware Computer and Internet Expert? Answer questions, earn points and help others
