Question about US Night Vision D-141M Weapon Sight
D-141 Mweapon problems
I have one of Night Vision D-141 riflescope and I leaved it switched on for a long time. When I tried to use it again it didn´t work. It seems to work for just a second every three seconds but the image seems to vanish... What do you think about it? I much appreciate any comment on this regard, Thank you in advance
    Problem Solver:
  • 10 Answers
Sounds like terrmal run away of the power fet.
leaving it on that long caused it to be damaged.
many compact devices have simular toruble.when
you turn it back on it quickly over heats and shuts down. After a few seconds it cools enough to resume operation till it reachs cutoff temp causing the on off cycles.
Posted on Feb 26, 2009
  • jesse reiter
    jesse reiter Mar 12, 2009
    a component tech should be able to replace or repair that part a reasonable price sometimes its just a lose soldered connection
    can have a simular effect.
    This is jessefuture please remember to rate solutions I am basically bed bond and trying to acquire a job at fixa and a rating of even helpful means a lot Thank you.
Atn night storm 3 not working
On any tv's pc, any thing that you don't want fried. The powder surge is what kills them powder going on and off buy powder surgers on every thing and you will never have that problem.
May 08, 2014 | ATN Night Vision Night Storm-3 Gen.3...
Works sometimes
It could be a lot of things; such as, faulty wire connection, cold solder joint, HV voltage arcing, corroded battery terminals. intermittent short in the switches. If it stop work, try gently shaking it several times, push the on/off button several times. make sure the battery makes a good connection in the battery compartment. Wrap it up and put it in your freezer for a few hours. There are electronic components that might get hot/warm and by cooling them down they will start working again. I don't know who manufactured Night Owl NOTG1 Goggles or who manufacture the components. Rissia manufactures make a lot of night vision devises and components. Also, there are a lot of countries in world that manufacture NV devises, and their parts. GB...stewbison
Aug 30, 2011 | Night Owl Optics NOTG1 Goggles
My HDR-SR12 handycam automatically switches to night vision when it is turned on & stays in night vision. Doesn't switch back. I bought it used, & have been filming with it fine since I got it...
This is a failure of the cameras internal "night vision"switch which is part of the lens assembly. the camera will need to be disassembled to repair. This can be done fairly inexpensively. However, it's not really a user serviceable problem and will need to be repaired by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com.
Aug 11, 2011 | Sony HDR-SR12 HDD Camcorder
The line from the gas source seems to be plugged on the weber. the gas does not seem to coming through. The weber worked fine last night.
there is sometimes an automatic shutoff if too much flow is detected. Occasionally when the lines are purged and you open the valve on the tank it will activate this.
  1. turn the tank off
  2. turn the burners on
  3. wait 10 seconds and turn the burners off
  4. open tank valve slowly- listen for a slight ping or click, if this happens that is the shut off activating, try again opening the valve more slowly.
Hope this helps, also make sure tank is full and you didn't leave it on all night. If this helps please rate it
Jul 05, 2011 | Weber Grilling
I have an ATN Aries MK330 night vision riflescope. I can hardly see the reticle glow. Welcome any helpful advise on how to make it brighter
Humm! The image intensifier tube just about to go south in one leaping moment. This scope has Russian manufacture parts, image tube, ccfl, inverter, voltage multiplier, wire almos everything is Russian except maybe the the blacken aluminun tube and covers. Now, the Russian make some very good optics. I needs some parts, what do you for it. stewbison
Jan 07, 2011 | ATN Aries 330 Warrior
I am Looking for the manual for the D-141M Night Vision Rifle Scope.
Hello, go to Night Optics web site and contact them through their web page. stewbison
Dec 24, 2010 | Kalinka Dipol D-141 Russian Night Vision...
I have an NEPVS-14 that was left on while facing
this is not much to go on???? i gess you have found out its not working by now,,,try changing the batterys? these scopes only have a life span of about1500 hours after that there dead they are "bright light protected" so leaving it switch on in daylight should have just knocked the batterys out,,,
Nov 15, 2009 | Quest ITT Night PVS-14 Gen 3 Night Vision...
US Night Vision D-141M Weapon Sight Logo
188 people viewed this question
Top US Night Vision Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Mark Campeau
Level 1 Expert
Are you an US Night Vision Optic Expert? Answer questions, earn points and help others
