Question about Victory Commercial Freezer VSF-3
Hubbell plug installing plug for freezer can i install to 20 amp service or would it take more
  • Victory Master
  • 1,230 Answers
Look on the electrical data plate. It should give you the info you need to know. I went to "victory-refrig.com". It looks as if you have a 3 door unit. The condensing unit is rated at 208-230 volts and is single phase. If your data plate confirms this, you need to use a plug that will accomodate 4 wires (4 prongs). Ground, neutral, and 2 power wires. It also shows that the unit is rated for 12.9 amps so a 20 amp plug is o,k. to use as long as you have the correct voltage. Do not attempt to use 115-120 volts on this as it is not designed for it and will most likely damage the unit. The web site has manuals, diagrams, and such. It looks user frendly, just got to look for what you want.
Hope this helps.
Good Luck
Posted on Mar 07, 2009
Gasket installation
I tried to re-initialize the freezer by unplugging it for a few seconds, then re-plugging it and turning the freezer back on, but, unfortunately, to no avail. NOT A SOLUTION EITHER, BUT AT'S A TRY.
Nov 22, 2013 | GE Refrigerator Freezer Gasket -...
I need 20 m 3 freezer installation manual
you search on net by written manual installation.
Mar 22, 2013 | Haier Freezers
It won't start no click sound if I turn the temperature control to maximum
If your hearing a clicking sound and it won't start your looking at either the relay switch for your compressor or the compressor itself. I recommand replacing the relay switch first to see if that solves your problem. Just look for the model number of your freezer, visit your local part store (reliable, amre) and ask them for the relay switch for the compressor. It should be under 20 bucks or so.
To install the part you first need to located the compressor. There should be an opening to the freezer somewhere in the bottom. Once you find the opening (after removing the cover) you should see a large cylinder metal container, this is your compressor. If the freezer unplugged located a small box attached to the compressor that looks similar to the relay you purchased from the part store. Remove the wiring for the old relay and then proceed to remove the relay (it should just be plugged in). Once it is removed place in the new relay. Plug back the fridge and see if your freezer works. If the problem persists it will be your compressor. You should have a professional have this replaced as it requires weilding and removal of the freon gas. The repair for a compressor job is $500 up.
I hope this helps and good luck. Please give positive feedback if this helps :)
James Memije
Head Technician
Accufix Appliance Service Centre
www.accufixappliance.com
Nov 20, 2010 | Danby 5.5 cu. ft. / 156 liter Chest...
What Gauge wire should be used for 20 Amp Circuit Breaker.? I have a 110 V Deep 2 Freezers has to be connected to one the outlet.
A branch circuit protected by a 20 amp breaker requires 12 gauge wire. The freezer should by the only load connected on that circuit.
Feb 22, 2010 | Freezers
Plugged a new tumble dryer into an extension lead in garage with my lec fridge freezer and blew the fuse,brought new tumble dryer inside house and is working fine,lec fridge freezer in garage now showing a...
you have more than likely ruined the control board on the refrige,a dryer and refrigerator should each be on their own dedicated circuit,they use an enormous amount of current to start, and even if one is running and the other starts thats enough to trip even a 30 amp receptacle, and furthermore extension cord use on these types of appliances even a large gauge cord i.e. 12 ga. that will carry 20 amps is not even a good idea because of voltage drop,as this causes motors to draw excessive current and over heat the motors and reduce appliance efficiency too
Nov 09, 2009 | Freezers
I need to know which circuit to install for my freezer The description I have is imperial commercial manaual defrost freezer 20.7 Cu Ft.
put it on a dedicated circuit(meaning only item on this breaker) with a minimum of 20 amps @ 120 volts
Sep 23, 2009 | Freezers
Need to know breaker and wire size to run from panel
Compressor 12/3 with 20 amp dual pole breaker. 220 VAC
Freezer 12/3 with 20 amp single pole breaker 120 VAC
May 24, 2009 | Nor-Lake Freezer Walk In Freezer 6ft x...
Victory Commercial Freezer VSF-3 Logo
166 people viewed this question
Top Victory Freezers Experts
Dennis Boxerman
christian nielsen
David Emmel
David Emmel
Are you a Victory Freezer Expert? Answer questions, earn points and help others
