Question about Whirlpool GHW9100L Front Load Washer
Duet Washing Machine spin cycle is spinning slow
Our duet washing machine spins very slow?
  • 4 more comments
  • Anonymous Mar 12, 2014
    will agitate during wash cycle, but trys to spin then slows down
  • Anonymous Mar 15, 2014
    my direct drive washing machine noisey on spin cycle?
  • Anonymous Mar 25, 2014
    DOES NOT SPIN
  • Anonymous Mar 26, 2014
    it spins slow but will not spin up to fast speed. Change out the position sensor and it still will not go to a fast spin in any wash cycle
  • Anonymous Mar 27, 2014
    after the wash cycle, the machine spins for an hour if I let it.....
  • Anonymous Mar 30, 2014
    F06 code is displayed when washing in the White Cycle and will not continue. We can move to the spin & drain cycle and the machine works fine
  • 67 Answers
Make sure u are not under loading the washer with just one or two items and that the load is fairly balanced or else the machine will not go into high speed spin as to not go completely off balance and walk across your floor if that doesnt fix it you might need a new ccu or motor control board probably the second one and make sure u are using HE detergent and not too much because suds will lock the pump up which will not spin with water in the unit
Posted on Mar 20, 2007
  • Terry Halpin Jun 21, 2013
    I meant it only spins very slow. Won't even do a complete revolution
Water won't drain, spin cycle won't engage
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Nov 20, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Stops in middle of cycle and won't drain or spin
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
If you are having problems with your front load washing machine then checkoutthis tip...
heatman101
Nov 06, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Cycle will not complete
heatman101
Sep 18, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool sport, won't drain water on spin cycle
heatman101
Sep 17, 2010 | Whirlpool Duet GHW9150P Front Load Washer
During the spin cycle, machine makes a loud clinking sound and cannot spin
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Sep 08, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Washing machine will not spin. have cleaned out
I have problem with my washing machine.could you help me please.
Apr 04, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Front Loader won't get up to spin speed
Careful of overloading the front-loading washers. Too much of this will result in the bearings in the drum to go bad. When this happens, the rpms on the drum slow down due to belt slack. You can only see this with the back off of the unit and in the middle of the cycle. They do not sell replacement bearings...you'll have to buy the whole drum (bearings pressed inside) and for 1/2 the cost of a new washer. I hate front-loaders. I'll never buy one again.
May 20, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Washing machine spins slow
If it has a speed selection switch than this switch is likely to be bad, other than that are you sure that It once has high spin in the cycle you are using??
Jan 14, 2008 | Washing Machines
Whirlpool GHW9100L Front Load Washer Logo
331 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
