Question about Refrigerators
Belling Bi60 Integrated fridge freezer (fridge) not working
My Belling BI60 Integrated fridge freezer is showing H on the temperature panel in the fridge. The freezer is working perfectly but fridge is not on or cold at all.....help pleazzzzze.
  • pkeegan Jan 05, 2009
    i was having the same problem but i turned off the fridge from socket and left for 24 hours now showing +5 but i want to bring back to +2 or +3
I also have probs with Belling Bi 60 less than 3 yrs old...already had
enginneer out & paid......now fridge aint cooling showing H
its frost free and this may be too sensitive ??
tried unplugging no Go
wont buy Belling again
Posted on May 19, 2010
I AM LOOKING TO PRICE A BELLING BUILT IN FRIDGE FREEZER
Michael, Check the attached links,
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Cooling
Belling Integrated 70 30 Fridge Freezer
Buy Belling BIFF233 Integrated 70 30 Frost Free Fridge Freezer from...
http://www.powercity.ie/?par=45-25-BFF233
Mar 12, 2016 | Belling Refrigerators
Hi, i need to set temperature for my 6th sense american fridge/freezer.. panel shows -24 deg for freezer and 5 deg for fridge..can you help me pls ?
There are buttons for fridge temperature and freezer temperature on the control panel. Just press the relevant button repeatedly until the temperature you want is displayed. http://docs.whirlpool.eu/_doc/501931501055GB.pdf
Jul 15, 2014 | Refrigerators
Fridge too warm
It is likely to be either the circulation fan in the freezer or the defrost element. The cold air is blown from the freezer into the fridge if the fan doesn't work then no cold in fridge( actually I think there are 2 fans in these, 1 horizontal 1 vertical) otherwise it could be a defrost problem, if the element doesn't work the rear fills up with ice and the air cant flow. Both are behind the rear panel of the freezer
Jul 08, 2013 | GE Energy Star PDS22SIS Stainless Steel...
Srl629ev refrigerator
It is likely to be either the circulation fan in the freezer or the defrost element. The cold air is blown from the freezer into the fridge if the fan doesn't work then no cold in fridge.Otherwise it could be a defrost problem, if the element doesn't work the rear fills up with ice and the air cant flow. Both are behind the rear panel of the freezer
Jul 08, 2013 | Refrigerators
I have a CDA integrated fridge/freezer, the fridge is working but
OK then have a look at the back wall of freezer is frost building up on rear panel?
Jan 25, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Belling B160 Fridge is warm Freezer is cold
In fridge freezer where the fridge is under the freezer, the cold air falls down a channel from the freezer. I had a similar problem and it was a failed defrost thermostat. The evaporator in the back of the freezer was a solid lump of ice and wasn't allowing any cold air to drop into the fridge. The defrost thermostat was changed and then 30 minutes with a heat gun melted the ice. It was worked fine ever since. On a side by side fridge, there is a bypass from the freezer to the fridge. Either way, you need an engineer. You are not the only one to see this problem with that model. I see two in Google.
http://www.ukwhitegoods.co.uk/forumsphpbb3/belling-b160-fridge-freezer-t48629.html
Sep 19, 2017 | Refrigerators
Belling fridge/freezer controls
most likely that is an on off switch for the temperature alarm. the 1 or l is the on psosition and the O is the off postition..
Nov 16, 2007 | Freezers
Belling intergrated Fridge Freezer
On integrated appliances the power supply is invaribly behind the unit. However there is normally an isolator to the side of the unit or in a side cupboard. Hope this helps.
Aug 06, 2007 | Belling BE811 Bottom Freezer Refrigerator
Refrigerators Logo
356 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
