Question about Vacuums
My Babylock Ellageo is locked up...the safety switch won't release. I changed the bent needle and I need to unactivate the safety switch.
3 Suggested Answers
  • 661 Answers
SOURCE: Babylock Ellure only winds bobbin
Hi Sewitupnow,
This problem happens when there is a minor mistake in our methodology of winding the bobbin,
However I would like to give you a very good resource so that you can go through it and make sure you follow each step cautiously , many have had the same problem like you have and they were benefited because of this method to wind the bobbin systematically.
Please use this link to get the complete instructions and i am sure it will help you out ..http://www.ehow.co.uk/how_8662804_wind-bobbin-baby-lock.html
Posted on Jul 05, 2011
jas247
  • 844 Answers
Welcome to FixYa!
Try replacing the needle with a new one. The machine is able to detect a slight bent of the needle which our human eye cannot.
Thank you for using FixYa. Hava a great day.
Jas247
I have Kirby sentria that shuts off while using the rug attachment and won't start until I change to the hose attachment. I have had it in Kirby repair store 5 times, cord replaced. Took it back t
power switch faulty, slow speed terminal inside switch is burnt,hence
intermittent fault, hose uses second speed different lever inside switch
Oct 12, 2012 | Kirby Vacuums
Why is my sewing machine skipping stitches
If the needle is slightly bent it won't pick up the lower thread all the time. Try using a new needle.
Sep 26, 2012 | Singer 7256 Fashion Mate Sewing Machine
Popped the lid open to change vacuum cleaner bag...now lid won't close. It's stuck at 90 degree angle. Is a button to release it?
Hi bndennis,
Please check the spring on your lid, it may be keeping the door open. Miele vacuum cleaners mainly use a spring concept for keeping lids open - merely pushing it down will lock it at the bottom.
Kind Regards :-)
JEDEMEYER1
* If this solution helped you, please rate it
Jul 23, 2011 | Miele S4210 Antares Bagged Canister Vacuum
Just purchased a used Babylock Companion 200 sewing machine; looking for a user's manual.
I just purchased one from from shop in McDonough, GA called Scarlet Thread. The are Baby Lock dealers and were able to get one for me. It took about 3 weeks but was only $6.99.
By the way, you bought an excellent machine that's super durable!
May 07, 2011 | Vacuums
I need a manuel for my sewing machine . it's the sophia model
Sophia Model sewing machines are made by the company Babylock. If you got to there website (www.babylock.com) you can look in the yellow tabs across the top of the page where you will find the downloads tab. Hold your mouse of this tab then scroll down to the manuals section. There you will find the manual for a Sophia Model Babylock sewing machine. Hope this helps.
May 06, 2011 | Vacuums
I have an Elna 745 serger/overlock machine. Whenever I'm doing a double cover stitch hem, when I'm at the end, the thread release lever does not release the thread. To release it, I have to cut the...
There are two methods to release the cover stitch with sufficient slack in the thread. Since you are using the thread release lever, did you set the Brown tension dial to zero? Before changing the tension, you have to first lower the needles to their lowest position in the fabric with the hand wheel and then turn the hand wheel backwards to bring the needles to the highest point in the cycle.
The other method may work better for you. Bring the needles to the highest point in the cycle and lift the presser foot. Then slide a thin object (a sewing ruler, for example) between the presser foot and the feed dogs and pull the needle thread towards you. Cut the needle threads Then pull the fabric away from you before cutting the looper threads.
Both of these options are described on page 98 of the manual, which is available from Elna. The current link to the manual is http://www.elnausa.com/data/files/2_users/55/Inst_Book_745_%28E-F-G-I%29.pdf . Pictures for the second method are available here: https://www.seamwork.com/issues/2015/06/coverstitch-machines . (Ending the double cover stitch hem is the same as that for the single cover stitch.)
I hope this helps.
Nov 27, 2017 | Vacuums
Vacuums Logo
130 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
