Question about Pentax IQZoom 928 35mm Point and Shoot Camera
Film wont rewind
I changed the battery at the end of a roll and the camera wont rewind now. It is supposed to be automatic and I can't find a manual rewind
  • nadyne07 Dec 22, 2008
    Turns out that the camera is just worn out. I took it to a camera shop and they told me to throw it away. Thank you
    Scholar:
  • 185 Answers
Nadyne,
manual rewind is next to lcd panel right side. hold the button down for 3sec. the re-wind symbol will be displayed on the lcd panel.while holding down the re-wind button depress the shutter button. film will re-wind.
Posted on Dec 15, 2008
My 35mm film won't load. It keeps rewinding
Solution: Repair or replace auto-rewind system.
Cause: The built in auto-rewind system that supposed to work when film is finished but because it is faulty it receives wrong signal when film is lloaded. So the camera thinks the film is at the end of the roll.
Possible cost: $65-$75
Oct 26, 2012 | Photography
I have a half way through film in my Nikon F80 and I have changed the batteries. At first it wouldn't go on, there would be the error sign blinking after turning it on. I turned it on and off several times...
You can force your camera to rewind, but you will have a partially shot roll of film. If you continue to shoot your counter will be off but when the film cannot advance any more the camera will rewind.
Jul 27, 2010 | Nikon F80 35mm Film Camera
How do u get the camera 2 rewind
Usually the automatic rewind starts when the film roll has come to the end. You can rewind also before that by a rewinding button you'll find usually somewhere in the camera body.
To rewind manually, press the film release button (consult the manual if you don't find it) and use the rewinding lever to rewind the film. See this for inspiration: http://www.ehow.com/how_2028878_film-mm-manual-slr-camera.html
Jun 19, 2010 | Nikon Photography
Why is the film automatically rewinding around 15 shots instead of the end of the 24 shot roll? The batteries are fresh.
the roll sensor is not reading the silver code on the film roll.
Open the camera when you have no film in it.
Clean the film roll slot where the "fingers" are.
These fingers touch the case of the film roll to determine the film type, which includes the number of exposures. You nmay have to "adjust" the fingers so that they make good contact with the film roll case.
Look at different rolls of film, notice the silver blocks are different. If the roll has a "dent" on it, it can't be sensed correctly.
Hope this helps!
Sep 15, 2009 | Canon Sure Shot Classic 120 35mm Point and...
Can't rewind film
It should automatically rewind when the roll is at the end. For mid-roll rewind press both the rewind buttons simultaneously for about 1 sec and the film will rewind.
May 21, 2009 | Nikon F80 35mm SLR Camera
New roll of film rewinds instead of advancing
Your camera has a faulty winding mechanism. It suppose to rewind in the end of the film when there are tension present but somehow the detecting system in your winding mechanism is detecting when the back door is closed. Remedy is replacing the clutch system within winding mechanism. Average repair runs about $90. -James. For further assistance by email, go to www.camerarepairjapan.com
Mar 21, 2009 | Nikon N55 35mm SLR Camera
Film rolls back automaticaly
The camera shouldn't be doing this, assuming you're using 36 exposure (or 24 exposure) film. You may want to set a custom function to prevent automatic rewind -- you would have to rewind the film yourself by pressing the rewind button.
To do this:
1. Under the palm grip, press the 'CF' (custom function) button.
2. Use the main dial to select 'F1' in the LCD. It should show a '0' below the 'F1'.
3. Press the 'CF' button to change the '0' to a '1'.
4. Press the shutter button half way to save the change and exit the custom function setting mode.
If you want to stop the rewind with the film leader still exposed (film doesn't rewind entirely into the cannister), use the same steps but set custom function 'F2' to a value of '1'.
Mar 17, 2009 | Canon EOS-1N RS 35mm SLR Camera
Film loading
Rewinding button or option may be in action
Oct 27, 2007 | Canon EOS Rebel G 35mm SLR Camera
Camera Rewinds New Roll of Film
Check the camera and the manual to see if there is a control to override the auto rewind; it may be set to rewind. Other than that, check Mikon's website for support info.
Jun 16, 2007 | Nikon N55 35mm SLR Camera
N75 will not load film
Quick solution: force a manual rewind.
1. Remove film
2. Close camera back.
3. With the power turned on, press the two rewind buttons together. They are marked in red.
4. The camera will make a rewind sound and will stop after about 2 seconds.
5. DO NOT fire the shutter yet.
6. Put the mode on Manual and select a fast shutter speed like 1/90 sec. Any aperture will do.
7. Load the film correctly as given in the user's manual.
8. As you close the camera back, the film will prewind to the end of roll. At the end of the roll pre-wind the LCD will show you the total number of frames available.
9. Select any shooting mode.
10. Go on and take pictures.
Hope this helps
Dec 14, 2006 | Nikon N75 35mm SLR Camera
Pentax IQZoom 928 35mm Point and Shoot Camera Logo
615 people viewed this question
Top Pentax Cameras Experts
Geoff Hone
Jerry Greenberg
Jerry Greenberg
Mohamed Ismail
Mohamed Ismail
Are you a Pentax Camera Expert? Answer questions, earn points and help others
