Question about Nikon Coolpix 5700 Digital Camera
Green waves When I look through the viewfinder or LCD panel I see green waves. When I take a picture it's unclear and greenish color.
Http://www.fixya.com/support/t128774-green_screen has the solution. It is probably a CCD burn out, but link exists for free repair (above)
Posted on Jun 09, 2007
Tip
My TV picture has a greenish tint.
The first thing to check is the cables connected at the back of the TV.
Check cable connection, and try using a different cable, video signal is often coded in separate colors signal, and a bad cable can cause a green picture when red or magenta (depending on type of signal) are out.
A faulty receiver or DVD player can also send a bad output. Try connecting different devices to TV.
If the cables and receiver are OK there are also internal faults that can cause the same effect.
The fault depends mainly on the model and type of the TV set.
On all TVs a faulty input/output can cause greenish picture.
On all digital TVs the signal is also elaborated on different color channels . Video circuits are often located on digital board.
A fault on digital video processing can cause a green picture.
If you have a rear projection CRT based technology, one of the three CRT may be faulty, or the power board supplying the CRT (red in your case) may have blown.
In that case you will get a greenish picture.
If instead you have a CRT TV, a greenish picture means that the red gun inside the cathode ray tube is not working. The CRT itself must be replaced.
Generally, when the problem is not the video cable , or the connected device, the TV must be inspected and repaired by a technician.
If you have a new digital TV, as an LCD, Plasma, or any non CRT based technology, the problem is usually caused by cables, input output, or connected devices.
Check the cables thoroughly, if that is not the problem, call manufacturer to find the nearest repair service location.
on Oct 23, 2009 | Vizio L32 32 in. LCD HDTV
32 inch Sharp Aquos is less than a year old... I changed that channel and the picture was green or gray... i changed it again and got a normal picture once but now all channels are looking blank with a...
Contact Sharp to locate the nearest authorized Sharp servicer. Sharp Aquos servicers have to give Aquos TV top priority. Sharp provides very good and fast serice on these sets.
Apr 26, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
My 37'' Vizio LCD TV has a green haze and lines on the TV
It is a very simple fix. Replace the LVDS cable will fix it. This cable connect the mainboard to the panel.
Nov 15, 2008 | Vizio L6 20.1 in. HD-Ready LCD Television
Blue colors appear greenish in middle third of screen...there is a circle of yellowish green in the center of the screen
You have a bad optical block, the block has a 2 year warrnty but you will have to pay labor to have a tech change it
Aug 08, 2008 | Sony KDF-E50A10 50 in. LCD HDTV
Red tint is gone
It sounds like the red cable on your component input is bad, one way to check this is press menu and see if the menu bars and letters are the right color. if they are then you may have a cable issue, if they are bad you may have a bad DG board in the unit. This will probably require a service technician. Hope this helps
Apr 03, 2008 | Panasonic TC-32LX20 32 in. HD-Ready LCD...
Pink picture
the electronic viewfinder on almost all digital cameras if even they got one is a tiny resolution screen or a mirror reflecting the bigger or smaller lcd screen. switch to your Lcd screen and see if colors are ok or still pink, also look at pictures you have taken. if ok the problem soly lies on the viewfinder which I have many cameras like it and come to think of it they looked aliittle pink too. the view finder helps you only in sunny conditions that you cant see your regular Lcd screen. and should be able to give you a good idea of what you are shooting. pink in real digital colors means you lost some green . look through your menu and see if there is an adjustment for it if not and you cant live with it return for exchange. I looked up the specs and would love this camera. good luck
Aug 31, 2007 | Fuji FinePix S7000 Digital Camera
Greenish tint
First of all component inputs are analog as the only digital inputs are the DVI or HDMI inputs on a TV. You might have color adjutments in the menus somewhere that allow you to compensate for color weakness on one or more colors. If not you most likely have a bad digital board.
Apr 07, 2007 | ViewSonic N2750w 27 in. HD-Ready LCD...
Nikon Coolpix 5700 Digital Camera Logo
48 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Computer Links
Are you a Nikon Camera Expert? Answer questions, earn points and help others
