Question about Canon Pixma MP450 All-In-One InkJet Printer
Paper isnt loading correctly
Printer keeps trying to load paper but it seems to only be pulling on the right side..then it pops up an errror that says theres no paper in the printer...what can i do?
  • 1 more comment
  • Anonymous Nov 04, 2007
    I have the same problem,
    what do you mean exactly by "grease" the mechanism ?
    put oil into it somewhere ?
    tx in advance
  • Anonymous Dec 03, 2007
    My Canon Mp450 is pulling on paper on the right (as you look at it) then makes some strange noises before finally reporting that no paper has been loaded, it occasionally also says that there is a paper jam but I can't find it. I should add that my husband had a habit of leaving his coins on top of the printer and one of them fell in. Any idea what else I can do before i have to give up and spend a lot of money on a new one for the sake of a problem caused by a 5p?
  • Morgan Kinney
    Morgan Kinney Apr 17, 2008
    Have the same problem, except that my computer always says it's a paper jam rather than no paper.  I've tried the first solution below to no avail, and I don't know what "grease" in quotation marks means below.  If anyone has any other suggestions, I'd be most appreciative.  This is a perfectly good printer/copier, but it's making me want to go "Office Space" on it's a*s.  Thanks!
Hi, thankyou for the clue as to how to get an MP450 working. Trying that tonight...oh, what sort of grease, how do you apply it...maybe to save a mess...thankyou.
Posted on May 12, 2008
  • 749 Answers
My printer does that too, after many copies have been printed out. There is this mechanism that pushes the paper forward and another to slide one paper in... well it won't get in. I tried to add "grease" at the right side, "facing the printer", of that mechanism that made contact to the rollers which slides a paper in..  well my printer now works fine
Posted on Oct 31, 2007
I also have the same problem. I cleaned the roller heads (using the function supplied in the printer driver maintenance tab) at least 3 times. This didn't seem to work too well but I also selected the "quiet" mode for printing which I think slows the paper feed and this seemed to help. The problem is still there but at least the paper feeds through now (it was getting stuck before). I did a couple of test prints and I'm not seeing any skewed printing so far so we'll see. I'll check back here to see if you found any other solutions.
Posted on Nov 17, 2007
Epson stylus sx405 will not load paper
Inspect the rollers that take the paper in. If none of them appear out of place or damaged, it may be that they need cleaning. I've had some success cleaning printer rollers with methylated spirits, but any dust cleaner should work.
Oct 01, 2012 | Computers & Internet
Paper keeps shifting during loading and eventually gets jammed every time
Seems like the rollers are either dirty, or worn out. Probably the latter.
“Paper jams” on page 68
“Paper or specialty media misfeeds” on page 68
“Printer does not feed paper, envelopes, or specialty media” on page 69
“Banner paper jams” on page 69
Paper jams
Is the jam in the paper
support?
1 Press to turn off the printer.
2 Firmly grasp the paper, and gently pull it out.
3 Press to turn the printer back on.
Is the jam in the printer? To automatically eject the paper:
2 Press again to turn the printer back on.
The paper automatically ejects from the printer.
To manually remove the paper:
If paper or specialty media misfeeds or skews, or if multiple sheets feed or stick together, try the following solutions.
Check paper
condition
Use only new, unwrinkled paper.
Check paper loading Load a smaller amount of paper into the printer.
Load paper with the print side facing you. (If you are not sure which side is the printable
side, see the instructions that came with the paper.)
See “Loading various paper types” on page 21 for information about:
Maximum loading amounts per paper type
Specific loading instructions for supported paper and specialty media
Troubleshooting
68
Remove each page as
it is printed
Remove each page as it exits, and let it dry completely before stacking.
Adjust the paper
guides
Adjust the paper guides:
When using media less than 8.5 inches wide
To rest against the edges of the paper or media, making sure it does not buckle
Jul 22, 2010 | Lexmark X2500 All-In-One Printer
Error 2 paper out but not
Does that printer feed from two ends -- a tray and a feeder at the back? If so, make sure your program is set up to draw the paper from the correct tray, or else put your paper in on the other side.
May 12, 2010 | Canon PIXMA MP160 All-In-One InkJet...
Photo printing errors
This is not the fault of printer. Choose those type of photo paper, whose thickness is equal to executive bond paper. This type of printer do not catch the thick photo quality paper
Apr 09, 2010 | HP PSC 1610 All-In-One InkJet Printer
My canon PIXMA MP190 All in one Injet Printer won't feed the paper through. It pulls to the right side and then bunches up. I've cleaned everything and even tried pushing cardstock through. It seems like...
Use a flashlight and small mirror to look down where the paper goes in the back, usually something has fallen in where it shouldn't be. A lady last week turned her printer upside down and shook until a bic pen fell out.I find pins, paper clips, toys, or gum inside. That one roller us usually enough.
Oct 23, 2009 | Canon PIXMA MP190 All-In-One InkJet...
Keeps popping up "paper source setting not set properly"
I'm guessing (wildly) that the printer is an R2400 (although there's no guarantee of that it seems :) )...
Anyway, the problem is most likely to be in the printer driver settings used on your computer.
You need to go to:
- Start
- Printers & Faxes
- Locate your printer
- Right click on the printer and choose "printer preferences"
From here you need to ensure that all your settings for paper size, etc... are correct.
You also need to ensure that whatever you're actually printing has the correct page setup using the same paper size.
Hopefully that will correct your problem.
Feb 14, 2009 | Epson Stylus Photo R2400 InkJet Printer
Printer will only pull the paper in from one side.
Hi !!
Usually this problem happens if there is something wrong with paper feed rollers which is inside the printer .
But to fix teh problem you can try this ---
take out ink cartridges, all the cables, power adapter (black rectangular box at the back) and papers from the paper feeder . Then take the printer in your hands, keep it like upside down and shake it for a while .Then keep it back in its position
Afetr 10-15 mins , install cartridges, cables, power adapter and just 1 sheet of paper on the printer . try to print somethg if still it dows same thg then it means that This is a time to buy a new printer on this christmas !!
Regards
Priya
Nov 25, 2008 | Lexmark X5150 All-In-One InkJet Printer
PRINTER MP210
Problem seems to be in the design. The paper loading roller pulls on the corner of the sheet,cocking it to one side. If the paper was pulled in from the center of the sheet,it would be pulled in straight and evenly.
Apr 10, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
One side of paper is feeding in....
The paper loading tray have stuck something check the tray cut pieces of papers or other things /clean also the feeding rollers /w/ cotton tips one drop of rubbing alcohol.
Jan 10, 2008 | Epson Stylus RX530 All-In-One InkJet...
Canon Pixma MP450 All-In-One InkJet Printer Logo
134 people viewed this question
old marine
old marine
