Question about Toshiba Tecra 510CDT (P000224080) Motherboard
My tecra 510cdt needs a bios update it.wen i turn on the computer it sais put in bios disket and press any key.....how do i put it in it has no disket drive?? i downloded the bios on a disket but how do i get it on ? PLEAS HELP!! thanks JANNET
  • s_eades_spik Dec 28, 2008
    I have a similar problem. I tried to access my bios but got into the update screen instead. Where did you get the update diskette from? I can't find it anywhere.
You have to buy a toshiba FDD attachment case which plugs into the computer.I have the opposite problem.. I have a built in floppy drive but I must buy a cd-rom .
Posted on Feb 01, 2010
How to access the bios of a toshiba tecra 8000
Turn the computer off completely, and then turn it back on.
Press and hold the "Esc" key on the keyboard immediately after turning the computer on. After a moment, the computer will prompt you to press the "F1" key to enter the motherboard BIOS configuration utility.
Press the "F1" key when you see the prompt. The BIOS configuration utility will load.
Jul 21, 2011 | Toshiba Tecra 8000 Notebook
What function key accessed the bios on 500cdt
If you have a Toshiba Tecra 500CDT:
Steps
1. Power up computer from off condition with ESC key depressed. Unit will display "Check system. Then press (F1) key"
2. Release the ESC key, press the F1 key. This will put the unit into the BIOS setup screen.
Oct 19, 2009 | Computers & Internet
Toshiba tecra 8000 EC/KBC update
go to system setting by pressing F2 when you see the toshiba or bios logo
disable the system setting auto update.
Mar 16, 2009 | Toshiba Tecra 8000 Notebook
Updating memory and cpu.
GO TO ADDRESS BAR TYPE:
MOTHERBOARD UPDATE DOWNLOAD DRIVERS,
MOTHERBOARD UPDATES,
CPU UPDATES,
CPUID OR CPIUD
CANDYMANGANDY
Jan 27, 2009 | Toshiba Tecra 510CDT (P000224080)...
Toshiba Tecra 510CDT Laptop
hi,
this is mainly dependant, on what input/outputs the laptop has at the rear. If it has a printer port, or USBs. you need to be able to physically connect, laptop to printer, as i,d imagine it has no bluetooth or infra-red et,c.
Thankyou for using fixya.
Mike at compurepair.
Jan 20, 2009 | Toshiba Tecra 510CDT (P000224080)...
No windows system
in bios put the boot sequence so that cd is first when computer as to boot from cd click enter after installing xp - use drivers downloaded here (if u dont have the cd) - http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=1073769787&rpn=PA1232U&modelFilter=510CDT&selCategory=3&selFamily=1073768664&selModel=1073769787|PA1232U
Dec 26, 2008 | Toshiba Refurbished TECRA 510CDT...
Memory Up-Grade
hi there, the memory slot is under the main case. lift the computer up from the front and you will see a panel on the left with two small screws. undo these two screws and you will see the memory card. they have also two small screws that must be removed to be able too remove the card.
sam
Oct 31, 2008 | Toshiba Tecra 510CDT (P000224080)...
Start Up Problem
Usually means that Operating Sytem needs to be reloaded or the hard drive is dead. Try to re-install Operating System first.
Hope this helps!
Mar 24, 2008 | Toshiba Tecra 510CDT (P000224080)...
BIOS intermittently loses CDROM
Hi, first check that your RAM chips are seated firmly, then check the CPU fan for dust, then if you still have the problem try disconnecting the on/off switch wires that run from the case to the board, bridge the two pin out to mstart the computer and see if problem still exists. The final test I can offer is the power supply, If you can use a multimeter and test the voltage. Yellow =12v red=5v black=ground. If you get a variance of more than 2v replace the unit. Another way is to try a diferent power supply. Regards mistyman
Sep 08, 2007 | Computers & Internet
Toshiba Tecra 510CDT (P000224080) Motherboard Logo
202 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
