Question about SimpleTech SimpleDrive Portable USB 2.0 60GB 5400rpm 480Mbps USB 2.0 USB 2.0 External (STIUSB2560FT) Hard Drive
Does not recognize the drive any longer
I inadvertingly disonnected the portable drive without using the usb disconnect procedure......... Now the computer does not recognize the drive any longer.. What can or should be done to correct the problem? Coolhand
  • 1 more comment
  • akchris Dec 19, 2008
    I have a simple tech desktop hard drive. All of a sudden my computer say it is a unknown device when I try to get in to it. I have tried every usb port on m computer and it says the same thing every time.
  • weikang399 Dec 23, 2008
    I have the same problem. I tried to follow Kallk's help, but HOW to plug into TWO USB port? I have only ONE cable.
  • mzparris Dec 26, 2008
    I have the same problem but it works in a USB 1.0, and not 2.0. Also I don't have a secondary usb prot. What can I do?
    Mine is a 250gb simple drive.
Following is the answer from Simpletech:
The most likely cause would be not enough power provided by a single USB port on your computer. Unplug the portable drive from the cable and unplug the cable from the computer. Now, plug the cable into 2 USB ports directly on your computer. (If you have a desktop, you should plug the USB cable directly into the USB ports on the back of the computer. If this is a laptop, you should plug directly into a USB ports on the computer. Do not plug into a USB hub or docking station). Then plug the drive into the cable. In a few seconds you should see the drive listed in the "My Computer" window as a SimpleDrivePS.
Posted on Jul 24, 2008
HOW DO YOU USE KATLK'S SOLUTION? HOW DO YOU PLUG ONE USB CABLE INTO TWO USB PORTS?
Posted on Jul 17, 2009
Get this bit of software USBviewer.exe from Microsoft or just Google for it. This will give you the status of every USB item connected to your computer.If you can identify your USB stick on the list then it is recoverable. Then try this:
open a Command Prompt and type: format x: /fs:fat32
NOTE you will lose all your data by doing this.
If you cannot find your USB stick and it is only shown as an Unknown Device the it is naffed, the device descriptors have been lost -  just throe it away!
Posted on Apr 11, 2009
I have had my drive for almost 2 years. It has always worked perfectly. All of the sudden last night my computer just didn't recognize it. I have always had the drive plugged into a USB hub because of all my accessories. I followed the answer that katlk posted and it was dead on! It now works perfectly again & that is why I just rated his answer FixYa! My life is on that drive...Thank you so much!!!
Posted on Sep 23, 2008
    Problem Solver:
  • 12 Answers
Try to plug it into more than 1 computer other than your PC. If it works, then the problem is the interface between the hard drive and your computer and if it really doesn't work, you're solution is have it recover by data recovery experts. Here are a few things you need to keep in mind, on taking your first steps in such a situation: Do not open the hard disk and try to repair it on your own. If you're data is really, very valuable, don't use automatic data recovery tools. Before you bring it, wrap your hard drive in anti-static envelope if possible, bubble wrap it, and seal package securely. You also had an option to recover it on your own by using known data recovery software but it's risky compared if you bring it to a data recovery experts. If the problem is within the mechanical parts of a hard drive, there's a possibility that you will not attain a 98% chance of recovery if you do it on your own.
Posted on Apr 04, 2007
SOURCE:
Computer doesnt recognize drive
Try a different usb port on the computer. Maybe the usb port you are using is bad.
Try the portable drive on another computer and see if it is recognized. If not, the portable drive might be defective.
May 29, 2012 | Prestige Portable 320gb Usb 20 IOMEGA ...
Sony walkman nwz-b135 when i connect it to my laptop it will add music etc, but will not charge thanx
I'm sorry to know that the Walkman player is not getting charged. I'll be glad to assist you with this. Please perform the following steps:
If the New Hardware Wizard appears and is prompting for a location of the driver, point to the following directory: C:/WINDOWS/INF .
To function properly, your Walkman player must be recognized by your computer as a Media Transfer Protocol (MTP) device. If the portable player was connected to the computer before the Windows Media Player version 10 or later was installed, it will be recognized as a Mass Storage Class (MSC) device and not function properly. In that case, a different procedure is available to correct this issue.
For some models, when you use the portable player for the first time, if you have not used it for a long time, or the battery is depleted, it may take up to 5 minutes for it to be recognized or start charging. On models with a display, the display will remain blank. If it the portable player is not recognized or does not begin to charge after waiting 5 minutes, reset the player by pressing the reset button.
If this is not the first time using your player and it was working properly at one time with no major changes performed (such as restoring the operating system or replacing a hard drive), follow the procedure below:
Connect the portable player to the computer using the supplied USB cable.
Disconnect the USB cable from the portable player and then reconnect.
Check the connection status again.
Disconnect the USB cable from the computer and then reconnect.
Check for available space on the player using Windows Media Player or My Computer .
Restart the computer.
Check that the USB cable is firmly connected to both the computer and the player.
If the player is connected to a USB hub, disconnect it and connect it directly to the computer with a dedicated USB cable.
If the player is still not recognized by the computer, disconnect all devices connected to the computer with a USB connection and restart the computer.
After the computer restarts, connect only the Walkman player and test the connection again.
If the player is still not recognized by the computer, try a different USB port.
Under the Common settings menu of the player, format the player using the built-in Format utility.
Verify the current Operating System. If it is an upgraded operating system, contact the computer manufacturer for updated drivers for their upgraded operating system.
If you are running the Windows XP operating system, be sure you are running Service Pack 2 (SP2) or later.
If you did not have the latest service pack, test the connection status again after it has been installed.
If you are still unable to transfer music to your player and have not yet uninstalled and reinstalled the driver follow the procedure to confirm that the player is recognized by the computer as an MTP device.
Thanks for contacting FixYa.
Aug 08, 2011 | Sony Walkman NWZ-B135 MP3 Player
My laptop doesn't recognize Lacie Rikiki Go 1TB. I have USB 2.0; and I couldn't find the drive in the Computer folder. Please help.
Hello roblau99:
First lets try this. Shutdown your laptop and reboot. Once your up and running, plug in your portable hard drive. You might try a different USB port. If windows doesn't let you know its there then you need to look for it by going into your administration tools menu. Of course this depends on what version of windows your are running, if it is windows.
Maybe you can answer this? Have you been disconnecting that hard drive without telling windows you are going to disconnect it first? If the answer is yes you may have corrupted that drive which is why windows is not recognizing it.
Good Luck and just let me know if you need more help.
Sincerely, Peter N.
Mar 22, 2011 | LaCie Rikiki Go 1TB USB 2.0 Portable -...
My Passport Drive is no longer recognized by windows
Check to see if the drive is available in disk management, if so and it's got a blue bar at the bottom, try changing the drive letter. If not, try the following:
Normally with the passport drives, you receive a shorter USB cable (this is because the drive relies on power from the PC, which your normal length USB cannot offer sufficiently. If you are using a short cable, try connecting the drive to the back of your desktop PC, this generates more power than the ports on the front (the ports on the front are actually hubs). If none of these options work try it on another PC, using the steps above.
If you still have an issue, the drive has most likely failed and you will need to get data recovery done to retrieve your data. If you do so, contact samsung for warranty information, so that your warranty doesn't become void.
Jan 24, 2010 | Samsung Portable 120GB USB 2.0 External...
My battery wont recharge when i plug it into the computer
IMPORTANT: To function properly, your Walkman® player must be recognized by your computer as a Media Transfer Protocol (MTP) device. If the portable player was connected to the computer before the Windows Media® Player version 10 or later was installed, it will be recognized as a Mass Storage Class (MSC) device and not function properly. In that case, a different procedure is available to correct this issue.
NOTE: If this is not the first time using your player and it was working properly at one time with no major changes performed (such as restoring the operating system or replacing a hard drive), follow the procedure below: Check for available space on the player using Windows Media Player or My Computer . Restart the computer. Check the connection status again and try to sync the player. Check that the USB cable is firmly connected to both the computer and the player. Check the connection status again and try to sync the player. If the player is connected to a USB hub, disconnect it and connect it directly to the computer with a dedicated USB cable. Check the connection status again and try to sync the player. If the player is still not recognized by the computer, disconnect all devices connected to the computer with a USB connection and restart the computer. After the computer restarts, connect only the Walkman portable player and test the connection again. If the player is still not recognized by the computer, try a different USB port. Check the connection status again and try to sync the player. Under the Common settings menu of the player, format the player using the built-in Format utility. Check the connection status again and try to sync the player. Verify the current Operating System. If it is an upgraded operating system, contact the computer manufacturer for updated drivers for their upgraded operating system. If you are running the Windows XP operating system, be sure you are running Service Pack 2 (SP2) or later. If you did not have the latest service pack, test the connection status again after it has been installed. If you are still unable to transfer music to your player and have not yet uninstalled and reinstalled the driver follow the procedure to confirm that the player is recognized by the computer as an MTP device.
Sep 22, 2009 | Sony Walkman Video NWZA818 MP3 Player
Disappearing files from Hard Drives
find if you portable deviceshas any SAFETY REMOVE function, if you using hot plyg and unplyg function without firs safety remove it causes this action, same is in flash drives. because writting process is not finished when unplug and last transaction had not been writen and file allocation table has wrong data in it.
Aug 18, 2009 | Belkin Wireless USB Hub
After a time, Computer not recognizing portable harddrive
Reformatting will be our last option and there are a number of steps that you can try to fix this.
  • Try plugging it in on a different USB port
  • Check the USB cable, try replacing it and see if it works
  • USB ports on your computer makes use of power, so if you have multiple USB devices plugged in, the portable hard drive might not be receiving enough power. Try plugging it in without your other USB devices, except the mouse of course
Please leave me a comment for this.
Jun 03, 2009 | SimpleTech Signature Mini 320GB External...
Simpletech usb drive model 96300-40001-001 Mac OS9 compatibility
If its 9.2 it may be because your mac is usb 1 and your external HDD is usb 2. It will recognize it but sometimes it takes longer to see the drive.
Feb 12, 2009 | SimpleTech SimpleDrive Portable USB 2.0...
SimpleTech 100GB SimpleDrive portable USB
Sounds like the file system on the disk is now corrupt. You may need to use a recovery programme to get your files back but nothing is for free.
Jun 17, 2017 | SimpleTech 100GB SimpleDrive portable USB...
Computers & Internet Logo
3,348 people viewed this question
Top SimpleTech Computers & Internet Experts
Marvin
Marvin
Joaquim Martins
Are you a SimpleTech Computer and Internet Expert? Answer questions, earn points and help others
