Question about Kenmore 33169 Gas Single Oven
Melted aluminum foil
I need help While making a pizza I put aluminum foil on a bottom of my LG oven. In some parts it melted and now we need advice how to remove it.
Please help i have to bake for Christmas
Ewa
  • Anonymous Jan 20, 2009
    Aluminum foil bonded to oven floor. Trying many things. Did you get yours off? email: trader2079@yahoo.com
  • sheilailles Feb 08, 2009
    I did the same thing in a new LG oven making Pizza, how do I get it off?
  • 3,230 Answers
Steel wool is the best bet, but it would be easier to replace the floor panel. I had a customer do the same thing. depending on how bad it is replacement mat be a easier option, about $35 for the new panel, and about a month to get the part. two screws on the floor of the oven next to the back wall. The manual does say not to use foil on the oven floor.
Good Luck!!
Thanks
Posted on Aug 23, 2009
MELTED ALUMINUM FOIL ON BOTTOM OF OVEN FLOOR: Have a Kenmore ceramic smooth top range. We placed a piece of aluminum foil on the very bottom of the oven as we like to bake our pizza on the rack but...
I would try a copper scouring pad.
Aluminium is very soft - Mohs hardness of 2.75
Copper has a Mohs hardness of 3, just slightly harder.
https://en.wikipedia.org/wiki/Hardnesses_of_the_elements_(data_page)
Ceramic tile has a hardness of 7
Mohs Hardness Scale
This means the copper scouring pad should be able to remove the melted foil without scratching the ceramic - but test first to be sure.
Mar 10, 2017 | Ovens
My new oven has melted the tin foil onto the bottom of the oven that I put to catch cake drips. I don't know how to get it off as it has adhered. The smell right from the start of the oven and during my...
With the older models of self-cleaning ovens one could put aluminum foil on the bottom tray of the oven, but with the newer models there is a warning (hidden in the last line) of your booklet for models of stoves where aluminum foil should 'not' be used! Even though print in small and many consumers are complaining regarding their stoves and melted aluminum stuck to the bottom tray of their oven (nothing will get it off) all manufacturer do 'not' cover this problem under warranty and thus, it will cost you $44 to buy a new tray. You unscrew the two screws to the bottom of the damaged tray of your oven and then install the new one and put back the screws. Letters of complaint should be written to the manufacturers to have them put this warning in clear bold print right on the front cover of the instruction brochure.
Jan 20, 2011 | Frigidaire 30" Self-Cleaning Freestanding...
We too ended up with melted reynolds wrap standard aluminum foil lined and then melted to the bottom of our oven. The smell was terrible. The thing was, we didn't know it was the aluminum foil until we had...
It is very difficult to melt Teflon; 326.8 degrees Celsius or 623.24 degrees Fahrenheit, hotter than most ovens! Rapeseed cooking oil will have long before caught fire.
Teflon is not used on oven floors, walls or racks.
The melting temperature of aluminium foil is 660 degrees Celsius (1,220 degrees Fahrenheit) at standard pressure, so it won't melt with temperatures encountered in a standard household oven!
Toxic fumes from the Teflon chemical released from pots and pans at high temperatures may kill pet birds and cause people to develop flu-like symptoms (called "Teflon Flu" or, as scientists describe it, "Polymer fume fever").
Oct 15, 2017 | Ovens
I don't have a Kenmore I have a Fridgidare and I have burned on foil on the bottom and cannot remove it. It is a self cleaning overn and I am afraid to turn it on??? I have tried scrapping, soaking, but...
With the older models of self-cleaning ovens one could put aluminum foil on the bottom tray of the oven, but with the newer models there is a warning (hidden in the last line) of your booklet for models of stoves where aluminum foil should 'not' be used! Even though print in small and many consumers are complaining regarding their stoves and melted aluminum stuck to the bottom tray of their oven (nothing will get it off) all manufacturer do 'not' cover this problem under warranty and thus, it will cost you money to buy a new tray. You unscrew the two screws to the bottom of the damaged tray of your oven and then install the new one and put back the screws. Letters of complaint should be written to the manufacturers to have them put this warning in clear bold print right on the front cover of the instruction brochure.
Apr 26, 2010 | Kenmore 33169 Gas Single Oven
How do i get an aluminum foil pan stuck from the
You may be able to get it opff with the oven hot. Whatever is holding it was liquid when hot before, so should at least loosen enough for you to remove it.
Nov 04, 2009 | Kenmore 47783 Electric Single Oven
How do I remove aluminum foil from the bottom of my oven? I have a brand new Kenmore wall oven that I have only used once. I had put a piece of foil on the bottom in case there were any drips. it baked on...
To all those who think this problem description couldn't be true, you're wrong. You're right that the aluminum did not get hot enough to melt though.....What happens is that the non-stick teflon coating they put on the aluminum get's too hot and bonds with the oven bottom.... like a crazy epoxy!
Furthermore, this isn't a problem in older, conventional-type ovens... this is moreso a problem with ovens that have a hidden bottom element.... The bottom element is actually directly below the oven bottom, and lining the oven bottom with foil is basically like putting it directly on the element. And that part gets extremely HOT!!!
Thankfully I've got the solution to this! But it takes some extreme patience, a lot of respect for what you're working with and some good ventilation.
I went back to my high school chemistry class to get the answer. It's Lye, aka Caustic Soda aka, Sodium Hydroxide.
I used Drano Kitchen Crystals off the shelf of the grocery store..it's about 70% lye with some added salts to aid the chemical reaction.
You'll need some plasticene, the drano, water, GLOVES!!, a lot of paper towels and wood skewers and GOOD VENTILATION.
Start the ventilation and open a window or door.
Put on your gloves.
Use the plasticene to create a dam about .25"-.5" high around the area in the oven you're looking to remove the aluminum from... the area's you're working in should be about 2.5" in diameter.
Pour in some of the drano into the dam and add enough water to touch all the sides of the dam......if the chemical reaction hasn't started (should be almost instant) keep adding the drano bit by bit until it does... the dam contents will start to boil and ammonia fumes and a little hydrogen gas will form....... hence the need for some good ventilation!!
Once the reaction is done, poke around with the wood skewer to see if the oven bottom is clear... if you're satisfied with the results, add some some vinegar in to help neutralize the solution a bit.... then use the wood skewer to remove the plasticene dam to a dish to be rinsed off ASAP.
Use paper towels to wipe up the mess on the bottom of the oven.... See your results! the area of the oven botton you treated should be free of aluminum and just be discoloured instead..... not from the drano, but from where the teflon bonded.
Repeat the process until the oven bottom is clean.
To get a 'feel' for the chemical reaction and what to expect, experiment first!... take a square of aluminum foil, go to the backyard with the foil shaped in a littlebowl and place it on a dish or pan, add some drano crystals to it then add a little water... step back from the dish and try not to breath the fumes!.. the dish will be hot!!
It took me about 6 hr to clean the bottom of my oven when this happened to me.
Hopefully this helps some other poor unfortunate souls who finds themselves in this situation!
Oct 15, 2009 | Kenmore Ovens
I have a Kenmore self cleaning oven with foil liner burned on!
Hi Leia, Unfortunately, the aluminum actually melted and adhered. The only perfect fix is to buy a new bottom piece for the oven, it costs about $30.00 and it is very easy to remove the old and install the new. Just a few screws.
You can get the part directly from sears by going to sears.com
May 06, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Melted aluminum foil on bottom of oven
Apr 11, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Melted Tin Foil in bottom of oven
Use "The Works Toilet Bowl Cleaner" to dissolve the foil. *Caution* when the cleaner is applied to the foil a chemical reaction occurs releasing some harmful fumes so please use outside or in a well ventilated area. I just did this to a Frigidaire oven I bought from Lowes at a discounted price. The previous owners bought it, did not read the owners manual or just disregarded the warnings on using foil in the oven and thought they would line the bottom pan with foil to help make it easier to clean (Good idea, but don't try it on the hidden element ovens). With the heating element being hidden under the drip pan the heat is hot enough to melt the foil and fuse it to the pan. Now most of the pans on these ovens are removable by just a couple of screws and I strongly recommend removing the pan when doing this. Squirt some Works toilet bowl cleaner on it in a well ventilated area and watch it go to work. It took about 15 minutes for it to dissolve all the foil on my oven, then I rinsed it clean and reinstalled it in the oven. The pan does have a slight discoloration on it, not from the cleaner but from the foil being melted onto the pan, if you choose you can buff this out. Most of the modern ovens have the ceramic coated drip pans in them so the Works toilet bowl cleaner will not harm them, unless you have scratched the finish off. Works Toilet bowl cleaner contains a fair amount of hydrochloric acid which is what makes this work so well.
Oct 23, 2007 | Kenmore 33169 Gas Single Oven
Kenmore 33169 Gas Single Oven Logo
1,069 people viewed this question
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
