Question about Sony Playstation 3 (PS3) Console
Ps3 my controllers wont react to my playstation 3 and when i turn it on the screen is just blank. alson i cant put it onto standby by holding the button. please if you could give me a solution i would be grateful. cheers.
  • 30 Answers
OKAY COULD YOU GET TO THE MAIN MENU??? BE DETAIL!!!
Posted on Dec 18, 2008
Tip
Hi this is exactly my problem but the thing is when i just press the power...
Are you plagued by the problem of your Playstation 3 not booting up properly?
Got a screen with just a background and no icons?
Seeing a wavy line and nothing else?
This is the tip for you!
This is a problem with the Playstation 3 software becoming corrupt. It is very easy to fix if you follow my simple steps.
Please note, this method will erase your hard drive so any save games you had will be lost. All your online trophies will be preserved.
Step 1.
Turn your Playstation 3 off into standby mode (red light on)
Step 2.
Press and hold the power button. The Playstation 3 will beep when you first press it, then beep again 5 seconds later and then beep once more and turn off back into standby mode (red light on). You must now release the power button.
Step 3.
Press and hold the power again. The Playstation 3 will beep when you first press it, beep again 5 seconds later then there will be 2 quick beeps together. When you hear these 2 quick beeps release the power button.
Step 4.
Your Playstation 3 will now start up with a screen asking you to connect a controller via USB. Connect your controller and then press the PS button.
Step 5.
A menu will now be displayed on screen. Select option 5 "Restore PS3 System". This will then ask you to confirm that you wish to go ahead with the system restore. Accept whatever the Playstation 3 says.
The Playstation 3 will now go through the system restore process and re-install the system software back to out of the box status. You will have to set your user name, date and time and network settings again.
Once you have completed the above, the Playstation 3 will restart and spring back to life again!
I hope this helps all of those out there who are suffering this problem.
on Jul 23, 2011 | Sony Playstation 3 (PS3) Console
I have just turned my playstation 3 on with not a blank screen just the background of the ps3 (a wavy line) and my users wont come up
hello try and reset it, press hold the standby button you will hear 1 beep the 2 short beeps after the short beeps release the button it should reset all the best
regards
shaun
Sep 09, 2010 | Sony Playstation 3 (PS3) Console
Screen goes blank and standby light keeps flashing red
How to fix ps3 yellow light of death 3. tips first
1)Turn off your playstation 3. If you think your ps3 has been caught by the heat, then wait at least 20 minutes and put it back on again
2) Check if there's any loose cable.
3) Try to put out your playstation's hard-drive, and put it back in. You might want to repeat this 2-3 times for better results.
If this did not work, then there are 2 options left for you on how to fix your ps3 safe and fast!
Send your playstation 3 back to Sony
You might think that this is an great option, but take a look at some statistics. Most users had to wait at least 4-6 weeks before they had their Console back. And also, if your warranty is expired, you have to pay a big fat $150,- to get the job done! Does this still sound as a good option?
Jul 27, 2010 | Sony PlayStation 3 40GB System
Blank screen, not reading dsc
try rebuilding the database and the file system in recovery consol
to get to the recovery consol press and hold the power button when ps3 is in standby mode(red light) till you hear a double beep. sometimes the ps3 does a beep then another beep and goes back into standby thsi is fine just release the power and quikly press and hold it again till you get double beep.
like on my 80g system it goes like this
ps3 standby...press hold power.......beep .........beep........stanby again....release and hold power again.......beep .........double beep...release power now you should be in recovery menu.
Oct 26, 2009 | Sony Playstation 3 (PS3) Console
Ps3 turns on with green light an doesn't show users screen blank
Your tv screen has problems with the video mode
that has setted up on your ps3, hold the power button till hear two beeps, this will reset the video mode of the ps3, and leavse you at a screen to set up the video mode of the ps3.
Succes.
Sep 03, 2009 | Sony Playstation 3 (PS3) Console
My playstation turns on and everything, but once i plug it in to any kind of television there is no picture or sound
Heres one solution that I found. If your ps3 turns on but does not boot up just stays a black screen most likely the hard drive got corrupted. So unfortunately you will lose all your saves. But to save the system when you power on the ps3 hold the button down its should beep once keep holding it and it should turn red in standby mode. Keep holding the power button down though. It should turn green again keep holding it should beep then double beep this time instead of going into standby. Let go now and some options will come onto the screen. You will need to plug in your ps3 controller and 6 options should come up. Reformat PS3 worked for me but I lost all my saves. Good luck!
Apr 06, 2009 | Sony Playstation 3 (PS3) Console
Not loading up to main screen
ok go to youtube and type" PS3 REPAIR/FIX" basicly what you do is put the ps3 on standby (the red light on) and then turn the main power off (the back switch) then hold the I/O button in the front (the on switch you use to put on standby) just hold it until it will go to standby then hold the I/O button again (the standby button) and then keep holding it until you hear one beep, then wait for two quick beeps. Then there should be a menu and select "Restore Defualt Settings". If it dosent work CONTACT SONY!
Mar 08, 2009 | Sony Playstation 3 (PS3) Console
PS3 won't show the system screen unless a game is running... HELP
put in cables ps3 came with with system on standby hold power button on system down for 10sec
Jan 06, 2009 | Sony Playstation 3 (PS3) Console
Mode not supported with playstation 3 DVI input
@ddkim From standby, press and hold the power button until you hear a second beep. this reset the display settings, and may work - Cheers JB
Dec 20, 2007 | Samsung DLP HL-P5663W 56" TV
Sony Playstation 3 (PS3) Console Logo
27 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
