Question about Cobra PR-245/2 (7 Channels) 2-Way Radio
Model #LI 7700 serial# R811004738 walkie talkies do not charge
Purchased 10/14/2008 and cannot charge. The charger has a faint light and after a few seconds goes dark. The charge model #GA-CF7 s/n821026414. Can I get a new charger. we use these for our hunting lodge.
    New Friend:
  • 109 Answers
Hello ddzepp;
I apologies but this site does not represent any manufacturer or company. This site is made up of many technicians like my self that volunteer to help others with technical issues concerning thier equipment. As for your problem you would need to contact the company that makes your product and ask them to resolve your issue with this charger.
Patrick Patterson - N5SLI
Posted on Dec 16, 2008
Charging/Charged Indicators
I don't know what model of radio, but here is what I would try: pull the batteries and charge them on the charger by themselves if your charger allows this. The lights, well, some manufacturers just miss the boat. Especially on low end or "beginner" radios. I have one brand I can insert with NO BATTERY and the light comes on. Talk about useless. Charge times vary by size of battery and charger output, minimum is 3 hours, 12 hours much more likely but I see a lot at 5-7 hours. Hope this helps, model and brand helps always.
Dec 12, 2015 | Walkie Talkies Radio Communications
I have k7gfv700 Motorola walkie talkies w/ charger. The charge seems to work, but the lighs one the charge are red and the talkie do not charge. Do I need new batteries and where can I purchase the
You might try http://wirelesspro.com, we have found them to carry most TalkAbout accessories and batteries. Before ordering battery packs, you might try switching your existing good battery to the other radio and see if it solves the problem. This would assure you that it is indeed a battery problem.
Sep 28, 2014 | Motorola Walkie Talkies 2-Way Radio
Battery charging
Only the Li-Ion batteries designed to work with the radio can be charged inside the radio. If you have Li-Ion rechargeable batteries such as those you can buy along side the
Alkalines in a store, the answer is no. This type would need to be charged in the style of charger made for recharging this brand/type of battery
Jan 25, 2014 | Motorola Walkie Talkies 2-Way Radio
My Cobra MircroTalk walkie-talkies aren't charging. The charge light doesn't turn on and I've made sure u turned Tue units themselves off. The model number is: GA-CQ
If your problem started after replacing the batteries (mine did), see this: http://www.walkie-talkie-radio.co.uk/replacing-cobra-walkie-talkie-rechargeable-batteries.html If that is your problem, you can also fix it by wrapping foil around the bottom of the battery that makes that touches the bottom side charging contact.
Oct 19, 2013 | Radio Communications
When I place the walkie talkie in the charger base, the light indicator does not come on. I've put new batteries in the walkie talkies. Also, on another walkie talkie, it constantly shuts off when I...
Generally when a radio shuts off when you press the PTT button it is a sign of a bad or poorly charged battery. It takes more energy to transmit than to receive. The fact you have a charge which the light does not come on indicates you have a bad charger or bad connection between the radio and/or battery and the charger. Clean your battery contacts (on both radio and charger) with a pencil eraser and see if it clears up the problem. If not, you have either a battery or charger problem.
Best regards.
May 25, 2011 | Motorola Walkie Talkie 2-Way Radio
The battery is fully charged on the walkie talkies and all are on the same channel, however out of 12 walkie talkies only 2 will work. When ever you push the push to talk button the walkie talkie shuts...
Your batteries are either no good, or not charged. When you press the PTT button it takes more energy than being in standby mode. If you have a battery problem it will fail quickly when the PTT is pressed.
Rechargeable batteries last approx. 18-24 months. Check your battery for a 3-digit date code. It is usually a 3 digit number followed by a couple of letters. The numbers tell the date of manufacture. The first number is the year, followed by the week of the year. 025 would be 2010 the 25th week. (or if very old it could be 2000 the 25th week.)
If you feel age is not a problem, you might check your charger(s) to see they are fully powered, and clear of debris on the contacts (and the radio contacts as well). Clean with a pencil eraser if needed.
A few tips: Be certain when placing your radios on the charge they are turned off. Check your wall outlet to be certain it doesn't get shut off with a light switch. Expect to replace your batteries every 2-3 years.
Best regards.
Nov 09, 2010 | Motorola Walkie Talkie 2-Way Radio
I have a gmr885 walkie talkie set...we used them last weekend as we moved from ct to maine..they were charged well before we left ct and when we got to maine put them in the charger, no lights showed lite...
You might try cleaning the battery contacts and the charger contacts with a pencil eraser. It could be you are not getting good connection. Also check your batteries to see they are installed correctly and are touching the internal battery contacts to the radio. Try switching the battery pack to the opposite radio, as a test to see if one will turn on. It would be highly unusual for both radios and/or chargers to fail at the same time. So the problem is probably something simple.
Jul 24, 2009 | Radio Communications
Charging
put batterys in a normal charger. if still nothing,. problem lies with radios.
May 09, 2009 | Cobra Microtalk 100 FRS Walkie Talkie...
Problems charging Cobra Walkie-talkie MT800 battery
Downloading the manual will now make the batteries charge?
apimom
Sep 21, 2008 | Cobra PR-245/2 (7 Channels) 2-Way Radio
Cobra PR-245/2 (7 Channels) 2-Way Radio Logo
630 people viewed this question
Top Cobra Radio Communications Experts
AnyMHz.com
AnyMHz.com
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
