Question about Samsung SH-S182D DVD RW Dual Layer Burner
Will this dvd writer work in windows vista. samsung sh-s182
Will it work? how hard to install and use
    Scholar:
  • 40 Answers
I'm not an expert on Vista, but generally it should work, as Vista comes with drivers for generic CD/DVD drives.
*(though installing the Samsung drivers may be a good idea if they have Vista approved ones on their site)
Installing DVD drives is one of the easiest things to do in terms of computer building, but I would be very careful if you've never opened the case before now.
All you need to do is turn the PC off, unplug it, then open the case. Find the molex power connectors (they're rectangular and have four pins, should be all over the place if your power supply is anything like mine) and the IDE data cable, which is flat and should be in your mobo, probably attached to a harddrive already. The IDE cable is pretty wide and has a plastic end usually in the middle and the end of the cable, either will work to plug the drive into.
It's self explanitory from there on out. The four pin power socket on the drive goes with the molex connector, and the long, flat data socket goes with the IDE cable connector.
*(the IDE cable has a small spur on one side, and the drive should have a void on one side, top or bottom of the socket, these match up so you don't put the connector in upside down. If it wont fit the first time, try switching top and bottom on the connector.)
The drive should insert from the front most likely, and the case may be cluttered or tight, so you would want to push the drive in half way or so and then connect it before pushing it in all the way. Then screw the drive in place.
Hope this helps, please rate if it did. Thanks.
Posted on Dec 15, 2008
What cable do I need to hook up a Samsung dvd writer sh-s182 to my Akai dps16 with scsi?
I suppose you would need a SCSI cable with the correct number of pins that match your scsi ports. Some have 50 pins some have 80 pins and some have less than 50 pins. Count your pins and go from there. Have you ever done this procedure before? Did it work?
Mar 18, 2014 | Samsung SH-S182 DVD±RW Dual Layer Burner
Installed Samsung SH-182 SH-S182 DVD Burner But my computer windows XP is not reconizing the newly installed unit
Which OS Service Pak is XP using? Have you tried to update the drivers? ' System ' Hardware ' Device Mgr
Can you test the burner on a 2nd PC? My older PC's dont see the DVD-RW but the burning software does.
Feb 21, 2011 | Samsung SH-S182 DVD±RW Dual Layer Burner
I require the driver for Samsung SH-S182 DVD±RW for my Home -System since my device manager is reporting the same was missing or corrupted.
You can find you driver here :
http://www.opendrivers.com/driver/240991/samsung-sh-s182m-dvd-writer-firmware-sb06-windows-98se-me-2000-xp-free-download.html
Oct 29, 2010 | Samsung SH-S182 DVD±RW Dual Layer Burner
Need a manual for SAmsung DVD Writer SH-S182
heres the weblink for the manual.. http://www.samsungodd.com/WebManual/dvd-writer/SH-S182D/en/index.htm..
if u want the manual in PDF format then go to the following link http://www.samsungodd.com/Eng/ and enter the model no. and download in PDF format..
the weblink for the same works great.. let me know if this is what u were looking for regards, guru
Feb 13, 2010 | Computers & Internet
DOES SH-S182 DVD WRITER SUPPORT DVD-R FORMAT DISC?
Yes
Thanks, Frank
@Tech
3868607368
http://www.attechcomputers.co.cc
Jun 21, 2009 | Samsung SH-S182 DVD±RW Dual Layer Burner
Dvd drive not reconized by windows
Hi ranman3995,
Your not alone with the Vista problems. I'm going to send you to a Microsoft site that will walk you through changing your registry that should fix the problem. HERE.
Good Luck,
Mark
Jan 14, 2009 | Samsung SH-S182D DVD RW Dual Layer Burner
DRIVERS NEEDED
All optical drives use ATAPI drivers, these drivers are native to Windows. Physically install the DVD player and it will be recognised, depending on what type of CD and DVD burning software you have your drive may not be recognised by them.
OEM burning software will only work with the optical drive it was supplied with, retail burning software should work with any drive.
Aug 31, 2008 | Samsung SH-S182 DVD±RW Dual Layer Burner
SH-S182 installation
before anything else.. your computer must not be plugged in
have some screw drivers ready
open the case
remove the connections of your old cd/dvd-rom
remove the screws
remove the drive from the bay
replace it with your new dvd writer
replace the connections and the screws
put everything else back
then turn on your system :D
Nov 02, 2007 | Samsung SH-S182 DVD±RW Dual Layer Burner
Samsung DVD writer SH-S182 problem
try a different power connector from psu,do not share same as HD!!should work!!
Oct 07, 2007 | Samsung SH-S182D DVD RW Dual Layer Burner
Samsung SH-S182D DVD RW Dual Layer Burner Logo
60 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
