Question about Brother Disney PE-400D Computerized Sewing Machine
Brother PE-400D sewing- Bobbin casing not turning.
HI, I have a PEBrother400D. I have used it very little up until the last 60 days. I was embroidering and the top sewing thread kept winding around the bobbin. Finally the machine quit working. I noticed the bobbin casing was not turning. I put a new bobbin casing in it. It still is not working. Everything down below is turning except the bobbin casing when I turn on the machine. Does anyone out there know what is causing this? I hate to send it out for repair if It is not broke or some small part I could order. Thanks Thank you, Patty
SOURCE: Bobbin won't wind
I have checked the gears underneath and see no missing teeth for the bobbin part. The bobbin "seat" does raise, but does not engage. Thanks
Posted on Dec 23, 2007
SOURCE: brother PE150
You need to adjust your top tension and maybe your bottom tension ( the little screw on the bobbin cover) Also check your needle and make sure it's straight.
Posted on Feb 08, 2008
akylas
  • 26 Answers
SOURCE: Brother PE-150V bobbin thread
For embroidery, and zig-zag, and because the needle makes side movements, it needs more needle thread.
So try to keep you needle thread not very tight,
and tight up your bobbin case tension more, so that the two threads meet under the meterial.
Posted on Jun 10, 2008
SOURCE: Elna Primula 410 Bobbin Winding Question
Wind the Bobbin
For the usual jobs, it is the best to use a medium sized thread.
2. Disengage the flywheel by unscrewing the coupling knob as far as it will go.
3. Place the bobbin on the bobbin winder, and push the bobbin winder to the right.
4. Pull out one of the spool pins and place the spool of thread on it.
5. Pass the thread through the bobbin winder tension discs, as indicated.
6. Wind the end of the thread around the bobbin by hand, in the direction indicated.
7. Wind the bobbin, at a medium speed by pressing lightly with a finger on the spool so as to stretch the thread better and thus fill the bobbin to a maximum. The full bobbin stops automatically.
8. Re-engage the flywheel by tightening the coupling knob.
9. Cut the thread and remove the bobbin from the bobbin winder by pushing the latter to the left.
Posted on Aug 23, 2008
  • 16 Answers
SOURCE: Unable to wind bobbin on Brother Css-8150 stopped suddenly
Checking to see if in fact that the bobbin shaft is turning. Run it without any bobbin on the bobbin shaft. Make sure that it is push over in the correct position and run it. I checked on mine and it does make the whirring sound and the the shaft does spin. Also check underneath the shaft to see if there is any thread wrapped around it. ( I had problems with that in the past). I hope this helps,
Posted on Sep 27, 2008
I purchased a singer quantum xl-5000 for small embroidery projects about two weeks ago and trying it out. When I am embroidering the top thread looks good but my bottom has a little loop while the bobbin...
Loosen your tension on your tension adjustment. It will show you where in the manual. Just feel it out a little at a time until it feels better and the problem goes away. Stop before the needle breaks and all but some machine you have to work the kinks out.
Oct 03, 2017 | Sewing Machines
How do you start embroidering a design where the thread breaks on a Bernina Artista 180 sewing/embroidery machine?
Most machines have a stitch counter, stitch forward and step back features. Check your manual and embroidery machine's screens for this.
IN case you have misplaced your manual I found this one for you. It's big so allow time to download.
http://www.itsastitchonline.com/mastery_on_the_web/Mastery_170_180_1-10-02.pdf
Sep 10, 2012 | Bernina Artista 180
My elna sewing machine bobbin won't spin on top to wind thread around. The fly wheel spins though...I've been putting thread on the bobbins by hand.
If the fly wheel is going around then the clutch isn't disengaged to wind the bobbin, you need to pull out the flywheel on your model to disengage the clutch for bobbin winding.
Take thread from thread spool across to bobbin winder thread guide, then back to bobbin and thread the tail through the hole on top of the bobbin. Place bobbin onto spindle on top of machine and then push it against the stop to engage the bobbin winding motor. HOld the thread tail up and start winding slowly until the bobbin core has been covered including the starting point. Stop and trim off the thread tail with scissors. COntinue winding bobbin and give the thread a nudge if needed to wind evening top middle and bottom of the bobbin. A good smooth wind is important. Also don't wind at full speed and keep an eye on the thread reel that the thread is coming off, you don't want it bouncing around as this will **** the thread and stretch then relax it affecting your bobbin wind.
Obviously if you know this and the bobbin winding mechanisim is just not working, then it will need a service/replacement by an Elna repair person.
Aug 01, 2011 | Elna 2007 Mechanical Sewing Machine
Just got the sewing machine last night - read the manual, etc - the tension of the bobbin is way off. tried every solution mentioned, but its still not working
are you adjusting the little screw on the tension spring on the bobbin case by minute amounts each time? Only turn it a quarter turn each time you change it.
If you do the dangle test, (suspend the bobbin by the thread tail) the bobbin case and bobbin should stay still in the air, but a gentle tug on the case should release thread. Adjust the little screw with the mini screwdriver in your kit until you get it to this point. turn it left to loosen and right to tighten.
Also check that the bobbin is in the bobbin case the right way, page 12 of your manual should show this. Yout want the bobbin to turn anticlockwise when you pull the thread tail. Then load it into the shuttle using the latch on the bobbin case to secure it.
It is possible that the tension spring itself is faulty in which case you can buy a new bobbin case for the machine from the local machine shop, or http://www.sewingpartsonline.com/brother-lx-3125-parts.aspx
Jun 02, 2011 | Brother LX3125 Sewing Machine
I have a Brother Disney SE-2700 and the bottom threads knott up causing me to not be able to sew.Please help.
It sounds like it has not been correctly threaded or the tension is too tight. Check the tension discs for bits of thread that may have broken off and be causing a blockage.
Re-thread the top threads making sure the pressure foot is up before passing the thread through the tension discs!
Then check the bobbin is running correctly by pulling on the tail of the thread. The bobbin should rotate clockwise. Put the bobbin case in and make sure it is seated correctly.
If all this fails try replacing the needle. A blunt needle can cause all sorts of weird problems
Mar 24, 2011 | Brother Disney PE-400D Computerized Sewing...
I have a Brother SE400 on which I was embroidering last night. The top thread was being sucked into the bobbin case and wrapped around the race. Which cause my needle to jam and then bend. After freeing...
Are you certain that you removed all of the thread from around the bobbin? Is the bobbin locked into place. The latch could be worn letting the bobbin case wonder out of place.
Jun 06, 2017 | Brother Sewing Machines
Bobbin is clumping up
You haven't given a lot of details so I'll just assume this is a bobbin issue initially.
Take out the bobbin and rewind a fresh bobbin of thread paying attention to the following.
You want to keep a bit of tension on the thread spool as the thread winds off it - good way is by placing the round handle of a pair of sewing scissors onto the top of the spool. If you let it just bounce around it will affect the bobbin winding neatly and the thread won't then run off the bobbin smoothly as you sew.
Also visually watch the bobbin as it fills, and give the thread a nudge with your finger tip to ensure it fills top and bottom, not just in the middle.
Think of how you wind up the garden hose reel, if you let it all go in the middle, it jams up before the whole hose is wound onto the reel. But if you wind it carefully and move the hose around winding it evenly across the whole reel, it stays neat and doesn't all jam up. Same principle for bobbins; don't just run the thread through the little tension disc and press the pedal hard until it stops.
Also quality of the thread is important; cotton wrapped polyester is nice to sew with and has a bit of spring, strength and good sheen; not sure where you are. But the brands I look for are Sylko Supreme, Guttermann and Mettler threads; there are other good brands too. Don't use those cheap bags of 5 white or black thread in the bargain bin. Some threads you can actually see particles of dye coming off the thread around the spool holder as you sew. Darker colours do this more.
And keep your threads stored neatly in air tight containers away from light, insects or damp; textiles fade and break down under UV rays eventually.
Now rethread your machine and ensure that the bobbin has gone into the bobbin holder winding in the correct direction for your machine, and that the thread has clicked into the tension spring.
Hope this helps, a good source of general sewing machine info is www.sewing.about.com.
Mar 06, 2011 | Brother SE-270D Computerized Sewing...
When I push the button to sew, I get a message stating that the safety has been acitivated. There is no thread tangled and the needle is not bent.
try turning the handle toward you if it won't move then it is more than likely the bobbin case is in wrong take the bobbin case out and try turning the hand wheel toward you if it works simply replace the bobbin case back into the hook area correctly and that should fix the problem
Aug 27, 2010 | Brother Disney PE-400D Computerized Sewing...
Brother Disney PE-400D Computerized Sewing Machine Logo
61 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
