C4200 PRINTER. - STICKY BACK LABEL JAMMED IN PRINTER. BACKING HAD COME AWAY FROM LABEL WHEN GOING THROUGH THE PRINTER. BECAUSE IT HAD STUCK TO PARTS INSIDE, THE PART VISABLE WHEN I REMOVED THE BACK CAME AWAY WHEN I PULLED IT LEAVING SOME OF THE LABEL STILL ATTACHED INSIDE AND TO SMALL TO GET HOLD OF. THIS PRINTER IS IN DAILY USE AND WOULD BE NEEDED VERY QUICKLY. THANK YOU
    Scholar:
  • 143 Answers
Dear sir.
i think it's a hardware lavle problem if u have a knowloge of hardware
1) you need to open yr printer cover
2) you need to clean one part called ROAD which that lable is stick..
3) you have to propre clea with thiner or clean petrol
4) then re attached it
if yr experinece is less then batter to call a profishnal
if u need more help please speak feel free thanks...
Posted on Dec 15, 2008
What is the backing?
The Backing is the see through paper on which the labels are stuck to. It can have a light yellow or white color. While the printer prints, the labels move through the label sensor, usually green in color. The gaps between the labels triggers the sensor to indicate where the printer should start to print.
Hope this Helps. (",)
Aug 05, 2014 | Datamax DMX-M-4206 Thermal Barcode Label...
Stuck in eject
Wow. A cheap MD deck from 1998. Brings back memories.
The last time mine did that the sticky label came off and jammed up the mechanism.
Take the cover off and see what you can do by hand. Be REAL careful not to touch anything that looks electrical!
Jun 13, 2012 | Sony MDS-JE320 Minidisc Player/Recorder
Dymo Twin Turbo has sticky label jammed in feeder out of sight. How do I get it out?
See here for detailed instructions on how to remove a label that has jammed inside a dymo labelwriter:
How to remove jammed label from Dymo Labelwriter
Sep 30, 2011 | Dymo LabelWriter Thermal Printer
STUCK LABEL IN THE P-TOUCH QL-500 LABEL MAKER, This is now the third printer I have purchased and replaced because of stuck labels on the rubber roller, this is a great printer until this happens. Any...
I downloaded service manual
You need to remove the top cover
Remove the curved cover 1st , has 2 plastic pins to press inwards
Lift the curved cover upwards
Remove the darkcover beneath the labels
At the back 5x self tapping screws
At the from 2x machine screws, left hand one is under a label
Prise off the cover by inserting a screwdriver at the back edge
Voila
Remove the stuck label
Reassemble
Apr 01, 2011 | Office Equipment & Supplies
We have a dymo labewriter that has a label jammed in the roller. Part of the sticky part is stuck on the roller. Cannot be pulled through. What to do?
LabelWriter Label Jam
  1. Unplug your LabelWriter.
  2. Remove the spool and labels.
  3. Remove the face plate.
    • Note: The face plate is the piece with the DYMO name/logo.
  4. Using the paper release lever on the left side of the printer, move the print head away from the feed mechanism.
  5. Straighten out a paper clip and GENTLY cut away at the label caught in the printer.
  6. Using caution, begin removing the label.
    • Note: We recommend using tweezers to remove the jammed label.
  7. Reinsert the face plate back on the LabelWriter. If you need assistance reinserting the face plate:
https://dymo.custhelp.com/app/answers/detail/a_id/278/session/L2F2LzEvc2lkL2ZVOGZXRmlr
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Dec 28, 2010 | Dymo Office Equipment & Supplies
Orange light keeps blinking.How to i fix this?
1.unplug the power from printer to reboot it
2.reinstalling the drivers
3.if the lights flashing like woof said check for jammed paper or sticky label inserts in the back door of the printer.
4.clean the circuit bit of the cartridge (sometimes a thin film of ink can stop the circuit)
Oct 20, 2009 | HP DeskJet 940c InkJet Printer
Help! Sticky label stuck on roller
Carefully peel away the label from the roller.
Then, CAREFULLY apply an adhesive remover to the area on the roller where the glue is. I highly recommend a product called GOO GONE. It works great and smells like citrus.
Apply the Goo Gone with a Q-tip, being careful not to let the solution get on any other part in the printer.
Oct 08, 2009 | HP Photosmart 3310 Printer
Paper is getting jammed hence not printing
Sounds like somthing is caught in the left hand side try looking in it with a flashlight and see if you can see somthing stuck like a twistie tie/sticky label/ staple / sticky tape.... If its in far try using a ruler or a few pieces of paper stacked together to dislodge it.
May 06, 2009 | Lexmark Z2420 Printer
Reg. zebra S600 lable
I had this happen when I changed from one label to a different size label. It needs to be calibrated. There are several types of calibration to do to the S600. Here is the solution that worked for me.
  1. Check the position of the laser Media Sensor (figure 13). It may need to be moved to match the type of label that will be printed.
For CARD labels, the media sensor needs to be set at the edge of the card so it can “see through” the notch that is cut on the edge where the perforation is.
    1. For STICKY labels, it can “see through” the backing which shows between each sticky label, so the Media Sensor could be set anywhere for it to work, but will probably be set towards the middle.
Set to Factory Defaults. This is so that all of the following steps will work. I do not need to change the steps based on the type of mode that printer is set up in because it will erase all that by setting it to the factory default. (See figure 14 for buttons)
    1. Turn off the printer.
    2. Hold the FEED and PAUSE buttons down as the printer power is turned on.
    3. Press MODE button four times.
    4. When the defaults are saved to the printer, the CALIBRATE, DARKER, and POSITION lights will all flash.
Test to see if the calibration is set correctly for the label. If not, proceed to the following steps.
  1. Do a Manual Calibration.
    1. Hold the PAUSE, FEED, and CANCEL buttons down as the printer power is turned on, keeping the buttons depressed.
    2. This will run through several labels and do some printing.
    3. Release all three buttons after the CALIBRATION light comes on and then goes back off.
Put the printer into Auto-Calibration Mode.
    2. Hold PAUSE, CANCEL, and MODE down as the printer power is turned on.
    3. Release the buttons after printer is powered on.
Dec 14, 2007 | Zebra Stripe S600 Thermal Label Printer
A sticky label is stuck in the machine
i recommend you to send the printer to someone certified to repair it before you can make something you can regret about...
otherwise. i think you will have to buy a special set of screw for that matter...
those printers have many fragile and small parts, so be carefull when you open it..
Dec 06, 2007 | HP OfficeJet 6210 All-In-One InkJet...
66 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
