Question about HP OfficeJet 7410 All-In-One InkJet Printer
Trying to print envelope size 6"X9" from Publisher
I can get the machine to print this odd size envelope, help
    President:
  • 623 Answers
1. When you print, use Ctrl-P (instead of the print button) to open the printing dialog.
2. Click "Printing Preferences"
3. Then go to the "Paper/Quality" tab and click on the "Customs..." button.
4. Choose a name from the menu and enter the desired paper size. Note: Custom 1, 2, or 3. You cannot change the names;-(
5. Save your entry.
6. In "Size is..." choose the proper name from the menu.
7. Print
Please let me know if this worked for you.
Posted on Dec 16, 2008
Need help printing customized size envelopes
you need to set the preferences in the 'Page Setup" to print envelopes
try this
good luck
Apr 29, 2010 | HP Photosmart C4180 All-In-One InkJet...
Printing envelopes
HI,
Try this one.Make sure the HP paper size setting needs to be "plain paper," not "automatic.
Aug 17, 2008 | HP Photosmart 3210 All-In-One InkJet...
When trying to print #9 envelopes on our Phaser 8560, I'm not given #9 as an option. Is there a way to force it to print to #9's? It seems crazy to me that such a common envelope isn't listed.
In the envelope selection you should also have a custom size so you can input the #9 dimensions and have it print. You just select custom size and input the length and width of your envelope.
Dec 07, 2009 | Xerox Phaser 8560DN Laser Printer
Printing small envelopes
In Word 2007, use the Mailing > Envelopes > Options section.
In 2003 I think it was under Tools > Envelopes & Mailings > Options.
There you'll be able to specify if the manual feed is top first or edge first, to the left, centered, or to the right, and how far over and down to place the address and return address.
After a few adjustment runs, it works great.
Jun 09, 2009 | Dell 5110cn Laser Printer
Paper size mismatch - c5280 hp all-in-one printer
I got around this problem by tricking the printer. The paper sensor, on my printer model hp4500 seems to only sense the paper at the beggining of the print job. What I did to trick the printer to print on odd size paper is slide the paper adjuster to 8.5 and put a regular white sheet in. Then put your odd size paper under it. When you print your document set the number of copies to 2 and print. The printer is going to sense that the paper is correct, and start the job. Here is the tricky part... one the first 8.5x11 sheet is almost all the way through quickly slide the paper adjuster over to match the size of your odd width paper. The printer should pick up the odd paper and print the second copy. Fool you printa! You should be able to do batches of odd paper size under the first 8.5X11 I hope this helps.
Deny When the 8.5x11
Jun 03, 2009 | HP Photosmart C5180 All-In-One InkJet...
Pixma MP 970, how can I get manual
Here is the downlink for the Installable Manual. Download this where ever you chose so you can find it later if needed. Once it is downloaded, double click the file to unpack the data. Once that is unpacked click on Start and it will install to your Desktop. I found the below data from the manual. The manual looks very complete.
These instructions are directly from the Manual:
Printing an Envelope Printing an Envelope For details about how to load an envelope into the printer, see the user's manual.
The procedure for performing envelope printing is as follows:
1. Fold down the envelope flap.
2. Load the envelope in the printer.
When loading the envelope in the rear tray, orient the envelope so that the flap is on the left and the folded surface is facing down.
When loading the envelope in the cassette, orient the envelope so that the flap is on the left and folded surface is facing up.
3. Open the printer driver setup window, and select Envelope from the Media Type list on the Main tab.
4. Click the Page Setup tab, and select Youkei 4, Youkei 6, Comm. Env. #10, or DL Env. for Page Size.
5. Select Landscape for Orientation.
6. Click OK.
When you execute print, the information is printed on the envelope.
I hope this fixes you up and you get the manual downloaded. You many need to start here just in case and select the entry for the Manual in English.
Best Regards,
Worldvet
Jan 11, 2009 | Office Equipment & Supplies
Printing Envelopes
There is a workaround for this problem by tricking the printer.
Here is the tricky part... once the first 8.5x11 sheet is almost all the way through quickly slide the paper adjuster over to match the size of your odd width paper. The printer should pick up the odd paper and print the second copy. Fool you printa! You should be able to do batches of odd paper size under the first 8.5X11. I hope this helps.
Deny
Jan 10, 2009 | HP OfficeJet 6210 All-In-One InkJet...
Cannot print odd-sized envelope with 4250 LJ
I got to HP tech support, and they tell me that the envelope feeder is intended only for a few standard envelope sizes. If we're trying to use a different sized envelope, as in this case, it must be fed manually, and the feeder bin will not work. So that answers that. Thanks for the help, though.
Apr 29, 2008 | HP 4250 Monochrome LaserJet Printer
How to print #10 Envelopes
How to copy/print onto envelopes.
Solution
Konica Minolta does not recommend copying/printing onto envelopes, asthe MFPwas not designed to run envelopes. Additionally, envelopes do not meet the
standards set for paper specifications. Their multi-layer make-up, adhesive, and odd size make it unreliable and potently damaging to the MFP.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Nov 13, 2007 | Office Equipment & Supplies
HP OfficeJet 7410 All-In-One InkJet Printer Logo
63 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
