Question about Gateway Solo 5300 Notebook
My Gateway laptops display does not work
The lcd power light comes on but the laptops monitor screen remains blank and will not boot--before this offured the desktop would not stretch the entire screen it would only remain in the center no matter how I tried to adjust the display, and also the display would go blank and I would have to move the monitor back and forth before the screen would reappear---
  • 1 more comment
  • crystyleqoa
    crystyleqoa Dec 16, 2008
    what is the vga/dvi
  • Anonymous Feb 20, 2009
    THE SAME
  • imation1 Mar 24, 2009
    after boot up my screens freezes.
    gateway laptop model no.pa6a
    luis.rosario65@yahoo.com
  • 679 Answers
It sounds like a loose wire. If you are out of waurantee open it up and see if there is a wire that has come loose. Only it you feel comfortable, doing this. First check the connectors on the side and make sure the vga/dvi, is not loose. If you are going to end up paying a tech to fix it, then it would be worth your while to open it up and give it a shot. Let me know if you want to do that, and we can go through what's needed. good luck, by the way is this XP or Vista? and if you go into the properties, settings, advanced, desktop, is the desktop set to stretch or center or tile?
Posted on Dec 15, 2008
Nothing comes up on the monitor
Please check if there is power to the system.
Is this a laptop or desktop?
If it's laptop see if any light turns on in the computer and or if you can connect it to an external monitor to check if the problem is the LCD display or the Video Graphics Adapter.
If it's a desktop see if there's power to the monitor and to the system.
Do you seea any message like no signal or output out of range or is the monitor totally blank?
If you can provide additional information like if it's a desktop or a laptop, when was the last time it worked if there are any indicator of power coming to the system.
Hope to hear from you soon.
Aug 07, 2011 | Computers & Internet
Hi my screen has gone blank on my laptop advent 5431 any ideas
I have gateway mx7118 and my screen went dim when power on. I connected to a external monitor and no pic on the monitor.
Could the problem be I need to replace the LCD invertor?
Nov 29, 2009 | Acer Aspire 4720 Notebook
Gateway T-1625 Laptop won't boot up - screen blank
Yes, if the CPU/motherboard will not POST (Power On Self Test), then changing the CPU is the only thing that you have not tried.
Sep 10, 2009 | Gateway T-1625 Notebook
Turning on but remains blank screen
it may happen that your extetnal (VGA Display) is enabled, this will disable your LCD Display.
just press Fn key and look function keys where monitor symbol is drawn ( that is F7 or F8 key. (turn on laptop then press Fn + F8/F7)
Aug 20, 2009 | HP Pavilion tx1000z Notebook
Blank Display, using exernal monitor, can see display info w/flashlight, display flashes light at startup
You could have a defective screen - a defective inverter or a CCFL lamp.
To determine if you have a LCD screen or video card problem, read this and follow the instructions.
Defective CCFL backlight, it may have the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
May 03, 2009 | Toshiba Satellite A135-S4407 Notebook
Blank screen with intermittent operation
you have bad capacitors in the power board inside the monitor replace these and the monitor will work fine
Dec 09, 2008 | ViewSonic Optiquest Q9b 19" Flat Panel LCD...
Xerox XA7
ccfl tube is destroyed or fuse on inverter board
Sep 01, 2008 | Xerox XA7-192i 19" LCD Monitor
LCD monitor goes blank
It appears that the display resolution set in your display properties is out of the range that the LCD can display.
Try this.
Boot to the ENABLE VGA MODE by pressing F8 to get the Windows Boot Menu. If you can get to the desktop, then go to display properties, and see if you can change the resolution to higher settings and maintain video. (If the video blanks out, then it should revert to the previous setting in 15 seconds)
Aug 03, 2008 | Gateway FPD2275W LCD Monitor
Labtop Screen Remains Blank
connect to external monitor to rule out bad video card. (remember most laptops have to toggle between internal and external display by using the <FN>+ <F?> key, mine is FN F5.)
If the external works then the problem is
  1. Inverter board or
  2. TAB welds at LCD or
  3. CCFL Cold Cathode Florescent Lamps (backlights)
May 30, 2008 | Computers & Internet
Screen goes blank
Hi jkm007, Sounds like the back light inverter board is bad. It's a very common problem. LCD's use four small cold compact fluorescent bulbs to back light the display. (thats what gives the LCD it's brightness allowing you to see it) The inverter board runs these lights and when they go bad they will typically show symptoms like you have or the monitor power light comes on and you have either no display or a very dim display. If you ever have one that has no display but the power light is on you can check by shining a flashlight directly into the LCD from the front (right into the screen) if you can see an image then it's either the inverter board (most likely) or the CCFL bulbs have gone bad. The inverter board and CCFL's are replaceable. Good Luck, El Duderino
Nov 12, 2006 | Videoseven V7 L19PS 19" LCD Monitor
Computers & Internet Logo
381 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
