Question about Tappan TGF320 Gas Kitchen Range
Tappan oven wont turn on
We have a Tappan oven (not sure of the style) that whenever we set it to pre-heat it stays on for about a minute and then shuts off. The oven never seems to go over 75 degrees to preheat. It has done this periodically in the past, but we eventually get it to warm up and we usually hear the 'click' when the ignitor turns on. The burners all work, it is just the oven. Does this sound like an ignitor problem?
fridgetech
  • 473 Answers
SOURCE: Tappan MGF500PBW- Oven starts and lights but then goes out
Must have a bad thermostat. The part # is 5303326546 and cost is $125.50. You can get it at http://www3.sears.com/.
Posted on Nov 11, 2007
Amigaman
  • 248 Answers
SOURCE: Tappan gas kitchen oven will not heat
Almost always a weak oven igniter. Remove oven floor by removing 2 screws at rear of floor. Remove flame spreader from burner, if it has one. Turn on oven and see if igniter gets red. It's the caged thing on burner tube. If it does but doesn't light gas, replace igniter. UNPLUG UNIT FIRST!!
Put dishwashing soap on threads of 2 screws holding igniter in place. This will allow it to come out easier. Do-not use oil. It will make your oven smell like a diesel truck.
Remove screws. You will have to remove drawer in front. Underneath you can fin wires from igniter. These will be cut at igniter and connected to igniter with enclosed wire nuts. The 2 wires to igniter go either way.
Posted on Nov 22, 2007
textonor
  • 130 Answers
SOURCE: Oven takes up to 25 min. to preheat
I would suggest looking at how long before the bake burner ignites. If taking longer than 5 minutes before it ignites, then you are looking at a possible bad ignitor. The ignitors just don't last more than 5 yrs with regular use.
Posted on Jan 06, 2008
  • 187 Answers
SOURCE: Tappan ES 200 burner stays on high and not turning off.
I need to clarify a bit.... did you remove the knob and check where the metal rod inserts into the plastic knob hole? If that is chipped on the inside, it will not turn the metal rod that comes out of the stove. Take the knob off, and use a pliers to turn the metal rod. Leave me comment if you have already checked that or you do not have that type of knob on your model.
Posted on Nov 17, 2009
  • 1015 Answers
SOURCE: Oven will not heat
This can be caused by a weak/inop hot surface igniter or a defective gas control valve. First you will need to verify that the hot surface igniter is coming on(you should see it glow in the burner compartment). If it is not glowing then you will need to verify that the wiring harness has voltage to it when the oven thermostat is on. Also check the igniter for any cracks or damage and if found then replace the igniter. If it is glowing then one thing that you can try(be very careful doing this) is to give the gas control valve a light tap with something hard like a wrench when the oven is turned on,igniter is glowing but the burner is not on. You will need to remove the broiler/storage drawer at the bottom of the oven. Once you pull the drawer out you should see the gas control valve at the back of the range. Try turning on the oven and lightly tapping the valve housing after the igniter is fully on. This may loosen up any debris inside the control valve housing that might be causing the problem. If the oven burner comes on then try completely turning the oven on and back of several times. And when I say completely I mean turn it on after the igniter is not glowing and burner has shut off. This works about 30% of the time. If the burner control valve sticks again after trying this procedure then it could be the control valve and/or the hot surface igniter defective. The hot surface igniter would need to be disconnected from it's harness and tested with an OHM meter. Most igniters should have a 500 to 700 OHM reading. If you get a reading that is way off then the igniter is defective and replace it. If the igniter tests good then the gas control valve is suspect and replace it. Most appliance parts retailers will test your igniter for free. When the igniter is on it should glow very brightly. If it is dim then that is a sure sign it is bad.
Posted on Apr 01, 2010
Tappan gas oven won't stay hot
bad flame sensor or check gas pressure
Aug 24, 2017 | Tappan Ovens
I dont no how to pre heat the oven
To pre-heat an oven is to simply turn it on to the desired temperature and wait 5 to 10 minutes. If you have a timer then set the timer for the desired time you want to pre-heat then begin baking as usual.
There is no magic to pre-heating an oven and everyone that bakes has a different opinion.
Sep 23, 2010 | Ovens
Ive got a tappan gas oven that wont light. The stove top burners light, but the oven or broiler wont. There is a ''glow plug'' that turns orange but the gas never ignites. What is wrong?
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
ssgs
Feb 25, 2010 | Tappan TGF320 Gas Kitchen Range
Tappan TMV151FS over range microwave starts to work and then dies
Never run the microwave without a load (something to heat)!!! That kills the microwave generating parts.
Sounds like a 'thermal' protect switch is activating after running. Make sure that (if the unit is mounted in a cabinet) that there is sufficient space around the unit for proper air flow and that nothing is blocking the vents. Try setting it on a counter top and heat something. If it works properly and doesn't shut off, the venting space is the problem. You may have to have the cabinet that it sits in redesigned for more clearance.
Aug 19, 2009 | Tappan TMT104E1 Microwave Oven
Takes hours for my tappan gas range to light and bake
Find the bake ignitor (you may need to remove bottom drawer or oven cavity floor to get to the ignitor). Turn on the bake. If the bake ignitor comes on (starts glowing after a few seconds) - check the amperage on the bake ignitor wires when it's on. If the ignitor is a round style - amperage should be 2.5-3A, if the ignitor is rectangular - 3 - 3.6A. If less than 2.5A or 3A respectively - replace ignitor. If the ignitor does not come on - check the voltage on the ignitor, should be the line voltage 110-120v AC. If there is a line voltage on the ignitor and it's not coming on - replace.
Ignitor part numbers for round style ones: 4342528, WB2X9154, SGR403, 5304401265;
rectangular styles: 12400035, WB13K21, WB2X9998, SGR412, NR020, 5303935066, 814269, 9753108.
Ignitors of the same shape (i.e. rectangular) are interchangeable, if you can splice the wires.
Jan 15, 2009 | Tappan TGF363 Gas Kitchen Range
Oven controls
those failure codes usually mean the oven sensor is out of range or has an open circuit.
you can replace the sensor for about 50-75 bucks and that will allow the oven to heat properly again.
you wont need to do any reseting or clearing of the code, just fix the problem and that code will go away.
Jan 14, 2009 | Tappan TGF320 Gas Kitchen Range
Gas stove want heat
Nov 01, 2007 | Tappan TGF320 Gas Kitchen Range
Tappan TGF320 Gas Kitchen Range Logo
64 people viewed this question
Top Tappan Kitchen Ranges Experts
Paul Carew
Sal De
Archie Ferrarini
Archie Ferrarini
Are you a Tappan Kitchen Range Expert? Answer questions, earn points and help others
