Question about InFocus LP70+ Multimedia Projector
My computer monitor loses resolution
The data projector is connected to a desktop. I have splitter on it. I have tried different splitters and VGA cord combinations. But as soon as I plug in the VGA cord my monitor becomes very blurry. I have even tried using different monitors. Amy idea
  • hobrien Dec 18, 2008
    I am not sure how to run the graphics card in separate screen mode????
  • 3 Answers
Try running your graphics card in separate screen mode im thinking you may have it in clone mode and is running both displays at the same res, or if the projector can handle it try running the projector at higher res
Posted on Dec 15, 2008
Trying to set up 3 monitors in windows 7. using on board dvi to connect to one monitor and on board vga to connect to switch box (which then splits video signal to two vga monitors). can only get the dvi...
Sometimes it is difficult to answer a question without asking very basic questions. Using a DVI and a VGA ports will allow you to have screens with different things showing on them. If you use a splitter, the two monitors connected to the splitter will show the same thing on both screens. Is this what you want? I use a splitter at church to have Powerpoint on the main computer monitor, the program then shows on the screen on the wall and the TV monitor, as well as the second monitor at the computer. My splitter occasionally acts up, and I found that unplugging it and plugging it back in makes it work for another couple months. But a splitter for only two monitors is very cheap, no switch box involved.
Oct 01, 2017 | StarTech.com VideoView ST124 (65030772815)...
Tutorial
Hi Connect your computer monitor out VGA connector to Computer input VGA connector of projector. Select source in projector (with remote) as computer/RGB/VGA as terminology used on the projector..
The projector will work as large screen projection monitor for the projector.
If you want to use monitor and projector both, you can use 1IN-2 OUT VGA distribution amplifier (Commonly called as "VGA Splitter"
Jun 26, 2012 | NEC Np13lp - Projector Lamp - 180 Watt -...
Using the splitter i can not get windows 7 to recognize the other monitor and enable multiple monitors
Hello there,
As you've said you're using a display splitter, the result will be identical screen on both monitors. splitters main function is to split VGA signals into N of outputs. where N=number of outputs. no matter how many monitors you attach to your splitter, the windows only recognize monitors attached directly to your video card. Windows requires a video card that has two or more output VGA or DVI outputs to get second extended monitor or display link device.
If you're video card has two outputs follow the instruction below.
1. plug the VGA or DVI other cable on the unused port. 2. power on the second monitor. 3. right click on the desktop, click screen resolution.
4. click the display in gray, Multiple Displays: it depends on the user.
5. I selected extended display. 6. apply and ok.
This spreads your desktop over both monitors and lets you drag items between the two screens. This is how most people use two monitors, and it's the default setting for desktop computers. you can use your mouse to grab the title bar (the top portion) of a window and drag it to your new display.
Hopefully this information is helpful. Thank you for using FixYa..
Jul 17, 2011 | Computers & Internet
We are trying to set up a dual monitor system so that we cn watch movies via the pc [not laptop] we have plugged in all the cables but still zilch
if you want to set up a dual tv monitor system using via pc as a source you will need a VGA splitter usually 2 or more output. now how are you going to connect the 2 monitor and PC to the VGA splitter. first make sure your tv monitor is supported by service input for PC unit. then prepare the accessories needed. the VGA splitter and VGA cable. vinceisaac_30.jpg vinceisaac_31.jpg sample image for VGA splitter VGA cable or connector how are you going to hook up the splitter and VGA cable to the tv monitor and PC
  • you need 3 vga connector and 1 splitter to connect a dual monitor system.
  • connect one end of the vga connector to the pc unit and the other end to the input port of splitter.
  • now the 2 remaining vga connector connect to the output of splitter either of the port, then the 2 end wire you must connect to the input port ( pc service port ) of the 2 tv monitor. make sure you set up the right input either with the remote or at the tv unit to recognized the pc source.
  • you almost done the connections now at this point plug the tv monitors, plug the dc adapter supply of the vga splitter and lastly turn on the pc unit to view movies. i hope it will help you just ask me if you have further questions thanks for choosing the fixya.
Jun 05, 2011 | Televison & Video
Having trouble with Y-VGA splitter, connecting to both Dell 380 computer and projector at the same time - Dell monitor cuts off when connected to projector.
Sounds like the the monitor detect line is causing your issue. The Hitachi CP-X250 has VGA in & out. Hook the Dell to the VGA out port of the projector.
Apr 25, 2011 | Hitachi CP-X250 Multimedia Projector
I have bought a vga splitter to split one vga port in to 2. the other monitor isn't being registerd by th comuter when i use the splitter
The computer will only see either one monitor or the splitter itself as the monitor, it won't recognize them separately or be able to put different data onto each (if indeed it is a true "splitter")
It's like the output from a satellite receiver. Just because you put a cable splitter on it so that you can have 2 TV's hooked up, both will be on whatever single output is coming out of the receiver, it doesn't let you watch 2 different shows, one on each screen. You'd need another receiver for that.
Likewise, if you want to see 2 monitors on the computer, there has to be 2 separate video outputs (some cards provide more than 1 output, but since you got a splitter, I am assuming this isn't the case for you).
Mar 12, 2011 | Computers & Internet
I just got the Gigaware 2 port usb powered vga splitter and I have ywo monitors connected. Both monitors show the same thing but I want to extend the desktop across both screens, however Windows XP does...
A display splitter will only mirror the screens, you cannot extend the desktop via a splitter.
Most portables cannot support dual monitors without a docking station.
Jan 07, 2010 | Computers & Internet
I unhooked my AverMediaVision130 Document camera at the end of school and I didn't write down the instructions on how to hook it back up and it isn't covered in the User Manual. I have a computer,...
From the document camera first, I hooked the VGA OUT to the wall box that is connected to the projector mounted in the ceiling then I connected the VGA IN to the DATA DISPLAY on the SPLITTER. The Computer monitor cable connected to the LOCAL MONITOR connection on the SPLITTER. The connection that comes out ot the SPLITTER I connected to the PCU. Okay, that is what worked. Maybe this will help some other poor soul with this many connections. Especially when the instructions does not allow for this possibility. The books never seem to have the ones given that I need. Oh, Well, the joys of instructions. Darlene
Jul 16, 2008 | Cameras
Can't get projector and computer to connect! no image
CHECK THE VGA PORT OF THE VGA SPLITTER IT WILL BE OK IF U CONNECT A MONITER FROM THE OUTPUT END AND SEE IF THE PORT IS OK THEN LATER U CAN GO FOR CHECKING PC AND CABLES.
Apr 08, 2008 | Office Equipment & Supplies
InFocus LP70+ Multimedia Projector Logo
129 people viewed this question
Top InFocus Office Equipment & Supplies Experts
neOen
Level 1 Expert
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
