Question about ASUS A7N8X-VM Motherboard
Installing extra memory causes freezing + closing down of pc
Hi , i bought 2 x 1 gb memory took out old memory 2x256 sticks and replaced with new , booted up and pc crashed , rebooted , got to windows ran a few minutes then to blue screen . tried a few more times and then started freezing windows and crashing , it also messed up my antivirus (avast) i gave in . put old memory back in had to restore to earlier date and reinstall a/virus and running ok now ,any ideas of why this is happening when upgrading memory or am i doing something wrong . do i need to change any settings etc? i have asus a7n8x-vm motherboard any help appreciated . dave
  • david_fergus Dec 15, 2008
    the memory i bought is pc2700 ddr 333mhz . so i think this is correct ram . could it be these are faulty , thanks dave
    Genius:
  • 1,061 Answers
Check these specs for your board.it will support 2gb but only if its pc2700.anything greater will not boot or become unstable quickly.here are your specs.also i am enclosing an ASUS link for any and all manuals etc. for this board.asus a7n8x-vm motherboard
Specifications www.microsoft.com/Genuine"] --> CPU Socket A for AMD Athlon XP
Thoroughbred/ Barton Core Support Chipset NVIDIA nForce2 IGP
NVIDIA nForce2 MCP Front Side Bus 400/333/266 MHz Memory -Dual Channel Memory Architecture
-Supports up to 2GB of 2700/PC2100 DDR memory
-2 DIMM sockets Expansion Slots AGP8X (1.5V only)
3 x PCI VGA -Integrated GeForce4 MX GPU
-Integrated TV encoder
-NVIDA nVIEW dual-display architecture
-Support DVI (AGP-NV-DVI) and TV out (AV/S) cards Storage/RAID 2 x UltraDMA 133/100 Audio Realtek ALC650 6-channel CODEC
S/PDIF in / out interface LAN Integrated 10/100 Mbps LAN controller + Realtek PHY USB Integrated 6 USB2.0 ports Special Features Power Loss Restart
Support S/PDIF in / out interface
ASUS MyLogo2
ASUS C.O.P. (CPU Overheating Protection)
ASUS EZ Flash Back Panel I/O Ports 1 x Parallel
1 x Serial
1 x PS/2 Keyboard
1 x PS/2 Mouse
1 x VGA
1 x Audio I/O
1 x RJ45
4 x USB 2.0/1.1 BIOS 4 Mb Flash ROM, AMI BIOS, PnP, DMI2.0, WfM2.0, SM BIOS 2.3, ACPI, ASUS EZ Flash, ASUS MyLogo2 Industrial Standard PCI 2.2, USB 2.0 Manageability WfM 2.0,DMI 2.0,WOL by PME,WOR by PME, Chassis Intrusion Support Disc Drivers
ASUS PC Probe
Trend Micro™ PC-cillin 2002 anti-virus software (OEM version)
ASUS LiveUpdate Utility Accessories User's manual
UltraDMA cable
FDD cable
I/O shield Form Factor microATX Form Factor, 9.6"x 9.6"(24.5cm x 24.5cm)RICHARDM69
Posted on Dec 15, 2008
  • Desktopsbyduck-Computers
    Yes dave they could be faulty. have you checked the bios for a memory speed setting or auto setting maybe.while in the bios also try resetting to set-up/default setting and let it recognize everything.return memory asap for replacement if none of this works.RICHARDM69.Was this solution helpful? Show your Appreciation by rating it
Bought a sony dsc h300 camera about 2 years ago...bought a Kingston Memory card for it....what do I do now ?
Have you tried formatting the new memory card? Sony suggest you format a new card using the camera.
Supported capacity:
  • Memory Stick Duo" media: up to 64 GB
  • "Memory Stick Micro" media: up to 16 GB
  • SD card: up to 64 GB
  • microSD memory card: up to 64 GB
You may also want to check the camera's user guide to narrow down what's causing the card not being detected.
http://docs.esupport.sony.com/dvimag/2014/DSCH300_guide/en/contents/12/01/04/04.html
Jul 08, 2017 | Sony Cameras
HP pc 1 short beep 1 long beep?
https://support.hp.com/us-en/document/c02222922
is the coin cell , 3v? or 2v , 2.9v and up is good, lower not.
the memory rules on all PCs is complex , just because it fits means nothing.
2010 PC DT
windows 7 32bit?
do all PSU voltages read correct with a voltmeter?
they must be in spec,.
memory
240pin DDR3 DIMM 800MHz Memory
low density only maybe a limit here.
so you want 8GB up
2GB per slot.
there are 3 kinds on voltage alone, low, high and both
then speed,
sure forum factor DDR3 240s
but there are density limits and socket max limits and system max limits
if running windows 7, 32bit its limited to 3.5? GB.
so 8 is a waste there.
if running windows 7, 64bit then it can use full memory.
if the bios allows it
and the Processor MMC chip allows it.
see? there are complex limits on all PCs.
in this case AMD processor.
Athlon II X4
limits on this mobo are.
HP spec page
Supports 1 GB, 2 GB, and 4 GB DDR3 DIMMs per socket
  • Supports Dual channel memory architecture
  • Supported speeds
    • PC3-10600 @ 1333 MHz*
    • PC3-8500 @ 1066 MHz *DDR3-1333 modules run at 1066 MHz if three or more modules are installed.
  • Non-ECC memory only, unbuffered
  • Supports up to 16 GB on 64-bit PCs (DIMMs run at DDR3-1066)
  • Supports up to 4 GB* on 32-bit PCs
so what memory did you buy, and from whom.
name make model numbers exactly.
I think its coin Cell bad
or PSU bad , not memory.
if one stick fails its not that stick if
you now are buried in sticks, if all sticks fail in just slot
its not memory prob. its power.
for sure all original stick fail as one.
Mar 04, 2017 | HEWLETT-PACKARD Pavilion p6514f PC Desktop
I tried to upgrade the memory from 1 GB to 2 GB, but after that the computer's screen won't turn on, and i can hear three long beeps and two short ones
The beeps indicate memory issue.
Acer Aspire One Notebook supports upto 1.5GB of memory, so if you try to install 2GB it will not work.
Size 1.0 GB / 1.5 GB (max)
Technology DDR2 SDRAM - 533.0 MHz
Form Factor SO DIMM 200-pin
You can also Click Here to check the specs on the Cnet website.
Regards,
Shrey
May 30, 2011 | Acer Aspire One Netbook 8.9" Notebook
I have an emachine T5026. Emachine tech swears this machine only supports pc2700 ram but the stickers on the factory installed ram says pc3200 256mb x 2 so i bought 2 memory masters pc3200 1gb x 2 sticks....
PC3200 is backwards compatible with PC2700. Meaning you can install PC3200 into your motherboard but it won't run any faster than would PC2700, however it will not cause any harm and should work fine.
Emachine's would say you need PC2700 most likely because they're trying to sell you some.
One of your new memory modules or the memory slots on your computer may be defective. I recommend installing a single stick of memory and booting your system. If it is successful then shut it down, disconnect the power and install another stick. Boot again and keep doing so and by process of elimination identify the bad memory stick or the bad memory slot.
This is the "likely" cause and isn't too uncommon.
Good luck.
Sep 07, 2010 | E-Machines eMachines Desktop PC
I just installed RAM into my dell inspirion 6000 and had the caps lock and mum lock lights flash then the computer shuts off. I read the manual and I did install the RAM properly (removing the battery...
Please provide everything on the sticker of the memory. When you bought the RAM, was it a pair or did you buy individual sticks? Your system can only support a maximum of 2 GB of PC5300 DDR2 RAM, split over two 1 GB sticks of RAM per slot. If you have tried exceeding this, it will not work, and even if it were to, it would eventually cause irreparable damage to your system.
Good Luck,
NOLA Tech
Jan 29, 2010 | Dell Inspiron 6000 Notebook
Just need to know how to insert a new memory stick I bought for my dinosaur 3000. Fry's salesman said I could find a step-by-step instruction. THX!
Dinosaur, as in a old acer aspire 3000 or what?
Most likely two screws on the bottom of the laptop that hold the memory cover closed, inside you will find 1-2 memory modules, you may have to remove one of the old ones and then install the new one, or if one is free install the new one there.
Sep 11, 2009 | Acer Aspire 3000 Notebook
Add Memory
it depends, you will want to check the type of memory first, and make sure you are purchasing the correct type. Also, if you have memory slots that are different colors, you will want to put the memory in two similar colors. also, i would advise buying a set of 2 1gb sticks of ram that are dual-channel capable, and removing the old memory. Otherwise the old stick of memory will significantly slow down the speed the new stick can run at. Memory is extremely cheap at newegg.com, you can get 2gb ddr2 ram for under $30.
Jan 20, 2009 | HP Pavilion a6000n (882780985018) PC...
Dell 8400 new memory
If you are using Windows XP, go into your control panel, double click System (from classic view), and look towards the bottom where it says "Processor x.xx GHz, x.xx GB of RAM" and make sure your 2.00 GB of RAM is recognized by Windows. Next I would make sure you are using 400- or 533-MHz DDR2 unbuffered SDRAM. If you are, try removing one of the two modules and see if the computer runs smoothly. If it does, I would install a different brand of memory.
Dec 31, 2008 | Dell Dimension 8400 PC Desktop
Ram Memory
I did this 2 days ago on my gf's aspire 5315-2153 (walmart special $348). the underside panel has four tiny screws which must be removed and then the fun begins. The plastic panel is large and doesn't want to be removed. After 20 minutes of cursing, i was able to get it out with two hands and a small screwdriver. The plastic panel has about 7-8 tabs which also hold it in place. The original two memory modules must be removed and the two new ones installed in their place. i bought crucial memory from newegg.com (CT2KIT12864AC667) for $17 delivered (took a week to get) which was much cheaper than buying it direct from crucial.com Save the old memory modules just in case you have a problem with the new ones. After putting them in, I restarted the computer and it booted up fine. No BIOS changes or any of that were necessary. So for $17 and about 30 minutes, this lappy is now running strong with 2gb instead of 1gb. Initial impression is that it boots up faster and shuts down faster but that is about it in terms of improvement!!!
Aug 24, 2008 | Acer Aspire 5315 Notebook
RAM Memory upgrade: 1gb modeles recognized as 512mb
You may have incompatible memory. double check your order and use only recomended name brand memory such as Kingston, you can look up the correct memory on their website, or on newegg.com
Apr 23, 2008 | Dell OptiPlex GX270 PC Desktop
Open Questions:
I know I have a driver issue but how can I solve it???? I just installed a new motherboard asus a7n8x vm 400 I installed windows XP Sp1 but when I got done I could not get a internet connection so I upgraded to Windows 7 and still got the same problem but with a new issue. The first Issue I was having was the computer would not log online. Under the Network and sharing center I?m getting an unidentified network message keeping my system from obtaining a valid IP address. For some reason it?s stuck on public network and will not let me change it to home. I tried all of the basic trouble shooting first by turning on network discovery then I checked my network cable; reset my modem and router, and rebooted my computer. After cycling everything and still no internet connection I tried to manual assign a IP address. next I tried to go online using a different computer to find a updated driver and transfer them via flash drive with no luck just the windows is using the best driver message. I tried installing Driver Detective put when I try to launch the program it shuts down because it don?t have a internet connection. The second problem I?m having is a unknown device in device manager. When I check the device properties under general and location it say that its on my PCI standard ISA bridge. I do have a vt6421a IDE/SATA raid card in stalled in 1 of the 3 slots but when I uninstalled the device and shut down the computer and physically removed the card and rebooted the same thing popped back up. Updating the driver didn?t work I tried to go to the manufactures websites to get all driver updates with no luck. So what do you recommend?
Feb 28, 2017 | ASUS A7N8X-VM Motherboard
ASUS A7N8X-VM Motherboard Logo
245 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
