Question about Optics
Winchester 870 The pump sticks open and won't cycle.
    Genius:
  • 1,061 Answers
RELEASE SAFETY CATCH.ON SIDE.RICHARDM69
Posted on Dec 15, 2008
Miele 870 dishwasher..timer works but doesn't wash goes thru cycle but no evidence washing or water swishing around.
I had this happen when my "water pump" went out on my dishwasher. It wasn't pumping the water up and into the machine or pumping it out.
Jun 05, 2017 | Miele Dishwashers
I have a Winchester pump with no model number.
Identify it in the images here
https://www.google.ca/search?q=winchester+pump+shotguns&rls=com.microsoft:en-CA:IE-ContextMenu&biw=1438&bih=677&source=lnms&tbm=isch&sa=X&sqi=2&ved=0ahUKEwjdmoOSoPDQAhVB5GMKHfAkC0kQ_AUIBigB&dpr=0.95
[PDF]Winchester Firearms Manufacturing Dates by Serial Number www.winchesterguns.com/.../winchester.../serial-number.../Winchester-Manufacture-...
  1. Cached
shotguns are not complete or why they are not always verifiable. A few ... totally accurate database of serial numbers from 1866 forward that we are aware of.
What year was my Winchester manufactured Serial Number Reference
www.winchesterguns.com/support/faq/date-your-firearm.html
  1. Cached
  2. Similar
Winchester Firearms Manufacturing Dates by Serial Number and Year ... about why the historic serial number records for Winchester rifles and shotguns are not ...
Winchester Dates of Manufacture
oldguns.net/sn_php/winmods.htm
  1. Cached
  2. Similar
WINCHESTER DATES OF MANUFACTURE ... Model 24 · Model 25 · Model 36 · Model 37 & 37- A · Model 40 · Model 41 · Model 42 · Model 50 · Model 59 Shotgun.
Model 1897 - Winchester Dates of Manufacture
oldguns.net/sn_php/windateslookup.php?file=win1897.dat
  1. Cached
  2. Similar
... DATES OF MANUFACTURE. Winchester Model 1897: Covering numbers: 31608 - 1024700. Please enter a serial number and click the submit button.
McHenry Sportsmen's Club - Winchester Model 12 Serial Numbers
www.mchenry-sc.org/Engineering/Model_12.htm
  1. Cached
  2. Similar
Dec 31, 2005 - Winchester Model 12 Serial Numbers. The table below represents the serial numbers and production dates of. Winchester Model 12 Shotguns: ...
Winchester Serial Numbers - ProofHouse.com
www.proofhouse.com/win/index.html
  1. Cached
  2. Similar
Jump to Shotguns - Shotguns top. Model 1879 · Model 1887 · Model 1893 ... Ranger Pump · Ranger Semi-Auto · Shotgun-Rifle Combo · Super X Model 1. winchester pump shotguns Google Search
Dec 13, 2016 | The Optics
I have a winchester 22 cal pump rifle,SN 67106. What model is it and what is its value? It was purchaced inGreen Bay, Wisc. just before the end of WW 2.
source
Winchester Model 62 Pump Action Rifles The ultimate gallery gun
Several models of Winchester 62 pump action rifles. Top to bottom: 1906, 20-inch round barrel; 1890 octagonal barrel; prewar M62 with scope; postwar M62A.
Winchester Model 62 left side receiver. The huge "Winchester" rollmark may mean its a gallery gun.
No less than six generations of the Model 62 were made from 1932 until 1958. Three of these are pre-WWII while the other three are post-1945. The easiest way to tell postwar versions is that they have a 17-groove 8.75-inch foregrip while prewar versions have a 5.75-inch 10-groove grip. After 1940, the Model was modified with an improved hammer spring and dubbed the 62A, so if you see a 62A mark on your Winchester pump rifle, that is an easy way to tell that it was made after that year. The value of standard Model 62/62As start at about $300 for shooter grade guns and go as high as $1000.
Oct 27, 2016 | The Optics
Maytag maxima door locked
Similar problem here - pump was set for a 58 minute normal cycle, I look in and see it is now showing 67. Hmm. Attempt to shut it off because it is just sitting there pumping and pumping. Power shuts off but pump keeps running and add garment light flashing red. Cannot open door (to add garment or not) Unplug the unit and the door will not open. Anybody got a clue what's up? I have a wash in, service is closed due to a storm today. Just bugs me that it is 6 months old and seems to act up a fair bit electronically.
Dec 09, 2011 | Maytag Washing Machines
Machine stopped mid cycle, won't spin or did not drain, no error code displayed, tried unplugged and restart. no luck
next time send the model number,open the door,look around the opening where you put the clothes in and you'll see a tag with the model and serial numbers,it has to drain first before it will spin,check the pump,get a shop vac and vac out all the water,remove the bottom panel and look at the pump,if the middle of the pump can be removed turn it counter clockwise slowly until the water starts to leak out and vac it up until all the water is out,then remove the middle part of the pump and clean it out,if the middle doesn't come out remove the hoses and check the pump to see if anything is in it and check the hoses,after you remove any debries you find fill it with some water and put it into a drain to see if the water drains,if it doesn't you can check the pump again to make sure you cleaned everything out,stick your finger in and fell around the impellar to make sure it's clear,if it's clear replace the pump.usually an error code will come up but if it fills and agitiates but won't drain i would start at the pump.hope this helps.
Aug 15, 2011 | Maytag EPICz 3.7 Cu. Ft.
New 870 express is not cycling low base shells properly
When it stove pipes, does the empty get caught by the next live round coming up on the carrier?
Try firing one round in the chamber and none in the mag and pump like normal.
If it fires and ejects the empty with no ammo in the mag the ejection system is probably fine.
If when you shoot with one in the chamber one in the magazine and it stove pipes you may have a timing problem. The cartridge stop is letting the next shell come into position and start coming up on the carrier to early. This may be fixed by moving the ramp on the action bar so as to get ejection farther along before the next shell is released to the carrier.
Caution, if the cartridge stops are ok and the carrier is coming up to early it is another issue altogether and needs to be looked at by a smith.
Sep 18, 2009 | Remington Shotgun Mount 12Ga Lh, B Square...
What causes my 870 to pump and eject two shells at one time
The cartridge stop is sticking and you should give the gun a good cleaning and see if that helps...
Sep 17, 2009 | Remington Shotgun Mount 12Ga Lh, B Square...
Optics Logo
Top Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Mark Campeau
Level 1 Expert
Are you an Optic Expert? Answer questions, earn points and help others
