Question about Indesit WA 125 Front Load Washer
Dryer starts to work and then stops working after a few minutes
We actually have the widl 103 front load, but I couldn't find a place to put this question for that one. The washer works fine. After it is done we turn the dryer on and it goes for a few minutes and then it stops and some of the lights turn on. At that point pushing buttons does nothing. We can turn it off and then back on and turn the dryer on again, but it will then do the same thing again.
  • Terry Holmes Dec 19, 2007
    troubleshooting Frigidaire FSG748GFS1 gas dryer. dryer ignites but then goes out.
    President:
  • 1,462 Answers
Doesn't usually happen so quick but may be a blockage in the air duct. take top off. if i remember right, duct runs across the back to the dryer fan. check for lint build-up. if poor air flow, an overheat stat will cut off the dryer
Posted on Apr 04, 2007
The start button on my lg tromm washer does not work
The plastic piece that you push may be broken or the switch that it pushes may be broke. Sometimes you have to hold the start button for a few seconds before the actual start will take place.
Feb 19, 2015 | LG Tromm Front Load Washer And Dryer Set
I had a bunch of verywet towels because my sink was leaking, and I put them in the dryer and it worked for a few minutes them stopped. What might be wrong?
Good Morning Friend,
I understand that you had a bunch of wet towels, and put them in your Frigidaire dryer, model# FGQ332ES. I see that your dryer worked for a few minutes and then stopped. There could be a possibility that the wet towels were too heavy from all the water in them. I suggest that you spin the towels out in your washer first and then move them over to your dryer. If you are still noticing the dryer working for a couple of minutes and then stopping, I suggest giving your appliance a hard reset. You will do this by either unplugging your appliance or shutting the power off at your homes circuit breaker for 3-5 minutes. When power is restored start it on any cycle. If your dryer is still shutting off after a few minutes, I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your appliance and determine what is causing it to shut off after a few minutes. Hope this is helpful.
-Best regards-
WP
May 14, 2014 | Frigidaire FGQ332ES Gas Dryer
I suddenly have the smell of urine in my dryer. Nothing was washed with any urine residue. I always double rinse each load and often use a little bleach with my "white" laundry. A couple of...
The only thing that I can think of that could produce a urine/ammonia smell is a shorted capacitor that is leaking. But normally when that happens the dryer motor will not start.
Jun 17, 2011 | Dryers
Dryer lights works, but when the start button is pushed the drum does not spin. the timer shows the minutes counting off, but no spinning. the dryer worked yesterday, but no today. dryer is a duet...
I am having the same problem. Dried towels last night. This morning, I loaded it, turned it on, it did not lock the door or start drying (spinning) but the timer started counting down. I pressed Cancel twice, unplugged it for a few minutes then tried again. Problem still exists. Any suggestions?
Aug 04, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Kenmore HE2 Gas Dryer Control Panel Does Not Work Properly
I have the same problem..really disappointed in this product. I bought mine in 07 as well..I found that if i hold all the buttons down and then hit start it (Sometimes starts), but after it starts it turns off after 10 seconds.
Mar 27, 2009 | Kenmore Dryers
Dryer works for few minutes then stops
clothes can open the door if door latch is weak, causing door opening and stopping the cycle, or a bad automatic sensor
Feb 17, 2009 | Kenmore 62602 Electric Dryer
Indesit WIDL 106 wont start -ON/OFF-Door Led Flashes rapidly
It is a defectiv controller pcb. I think the eeprom on the controller pcb lost its program (happens often on Indesit machines).
The only solution I know is to change the controller pcb, - not a cheap solution.
I have the same problem with WIDL 106.
Dec 01, 2008 | Indesit W 123 Front Load Washer
Whirlpool tumble dryer stopped working , took 1 load out put another load in and just stopped
check your dryer door switch, common for strike actuator to break off, not recogniziong door closed the machine will not do anything. if that sgood yo may have blown a thermal fuse
Nov 05, 2008 | Whirlpool Dryers
Indesit WIDL 102
almost certainly a new module and eprom. these modules have given a lot of problems.
not really worth doing
Jun 25, 2008 | Indesit W 123 Front Load Washer
Starting dryer
you need to replace the motor
Dec 17, 2007 | Dryers
Indesit WA 125 Front Load Washer Logo
209 people viewed this question
Top Indesit Washing Machines Experts
shaun taylor
jimorris77
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
